查看: 6551|回复: 31
[已解决] 滚动栏消息
发表于 2024-4-2 11:04:38 | 显示全部楼层 |阅读模式
求助,在界面中 一直循环滚动播放一些消息,是用什么卡片实现的呢?
发表于 2024-4-2 16:19:33 来自手机 | 显示全部楼层
持续关注
 楼主| 发表于 2024-4-2 16:41:41 | 显示全部楼层
搞定了。
自定义了一个 滚动栏的卡片,然后在绑定要显示的实体到这个卡片就好了。
这个实体可以是静态的,也可以是捕捉家中某个实体,如温度,开灯数量
 楼主| 发表于 2024-4-2 16:44:45 | 显示全部楼层
benlky 发表于 2024-4-2 16:41
搞定了。
class ScrollingTextCard extends HTMLElement {
  setConfig(config) {
    if (!config.entity) {
      throw new Error('You need to define an entity');
    const root = this.attachShadow({ mode: 'open' });
    const cardConfig = Object.assign({}, config);
    const style = document.createElement('style');
    style.textContent = `
      .scrolling-text-container {
        width: 100%; /* Set the width of the container */
        height: 50px; /* Set the height of the container */
        overflow: hidden; /* Hide overflowing content */
        position: relative; /* Position relative to allow absolute positioning of the scrolling text */
      .scrolling-text {
        white-space: nowrap;
        overflow: hidden;
        text-overflow: ellipsis;
        animation: scroll-left 15s linear infinite;
        position: absolute; /* Position the text absolutely within the container */
        top: 0; /* Position the text at the top of the container */
        left: 0; /* Position the text at the left of the container */
      @keyframes scroll-left {
        0% { transform: translateX(100%); }
        100% { transform: translateX(-100%); }
    root.appendChild(style);
    const container = document.createElement('div');
    container.className = 'scrolling-text-container';
    root.appendChild(container);
    const textElement = document.createElement('div');
    textElement.className = 'scrolling-text';
    container.appendChild(textElement);
    this._config = cardConfig;
    this._root = root;
    this._textElement = textElement;
  set hass(hass) {
    const entityId = this._config.entity.split('.')[1];
    const state = hass.states[this._config.entity];
    this._textElement.textContent = state ? state.state : 'Entity not found';
  disconnectedCallback() {
    this._root.innerHTML = '';
customElements.define('scrolling-text-card', ScrollingTextCard);
发表于 2024-4-2 17:06:12 | 显示全部楼层
太强了吧这么快就解决了问题,可以说详细一点这些代码写在哪里吗
 楼主| 发表于 2024-4-2 17:30:50 | 显示全部楼层
创建一个JavaScript文件: scrolling-text-card.js,并保存到你的Home Assistant配置文件夹中的www目录下。
然后在仪表盘的资源里面添加好路劲.
之后在configuration.yaml 中添加一个input_text 的实体
input_text:
  scrolling_text:
    initial: "Your scrolling text here"
之后就可以像其他卡片一样使用了
发表于 2024-4-2 17:31:15 | 显示全部楼层
这个是自定义卡片吧?需要用自定义UI界面调用,原始UI面板无法使用的
发表于 2024-4-2 18:19:55 | 显示全部楼层
大佬你看这是哪里出错了
发表于 2024-4-2 18:21:24 | 显示全部楼层
明明洋洋 发表于 2024-4-2 18:19
大佬你看这是哪里出错了
 楼主| 发表于 2024-4-2 22:54:41 | 显示全部楼层
你发的图片吗? 一直无法加载出来
GMT+8, 2025-12-20 09:48 , Processed in 0.672801 second(s), 6 queries , MemCached On.
