查看: 28890|回复: 22
[插件集成] esp8266NodeMCU刷EspEasy固件,攀藤PMS5003ST插件源码
发表于 2018-1-17 21:58:04 | 显示全部楼层 |阅读模式
espeasy原固件只支持pmsx003,pm2.5激光传感器
看了smc326的 《新人第一原创,ESPEasy有PMS5003ST+MH-Z19B传感器可以用啦》帖子
买了攀藤PMS5003ST传感器,集成PM2.5、温湿度、甲醛传感器。
上面帖子的固件 能显示并用MQTT上传6个项目,用HTTP只能上传4个项目,温度,湿度刚好在第5第6
帖子里只有固件没有源码,只能硬着头皮自己改官方固件了
根据espeasy官网的编译指南,下载了固件源码包ATOM。
找到PMSx003.ino插件,修改后只保留了4个项目,pm2.5 温度、湿度、甲醛浓度。乐联网上传正常。
由于数据包长度不同,需要修改下字节数,和温湿度甲醛的计算方法,校验部分一样不用动。
简单的 data[14]/10 温湿度只有整数,0基础痛苦搜索了大半天,最后参考旁边DHT温湿度传感器的代码,原来小数点这么麻烦要用float。。。代码已更新,小数点终于正常了。
实测esp8266的nodemcu开发版刷了成功。
代码如下,或者下载附件,直接复制覆盖。(原文的很多PMSx003字眼没动,只改了关键数据部分)
//#################################### Plugin 053: Plantower PMSx003 ####################################
// [url=http://www.aqmd.gov/docs/default-source/aq-spec/resources-page/plantower-pms5003-manual_v2-3.pdf?sfvrsn=2]http://www.aqmd.gov/docs/default ... l_v2-3.pdf?sfvrsn=2[/url]
// The PMSx003 are particle sensors. Particles are measured by blowing air through the enclosure and,
// together with a laser, count the amount of particles. These sensors have an integrated microcontroller
// that counts particles and transmits measurement data over the serial connection.
#ifdef PLUGIN_BUILD_TESTING
#include <ESPeasySoftwareSerial.h>
#define PLUGIN_053
#define PLUGIN_ID_053 53
#define PLUGIN_NAME_053 "Dust - PMS5003ST"
#define PLUGIN_VALUENAME1_053 "pm2.5"
#define PLUGIN_VALUENAME2_053 "TEMP"
#define PLUGIN_VALUENAME3_053 "HUMI"
#define PLUGIN_VALUENAME4_053 "HCHO"
#define PMSx003_SIG1 0X42
#define PMSx003_SIG2 0X4d
#define PMSx003_SIZE 40
ESPeasySoftwareSerial *swSerial = NULL;
boolean Plugin_053_init = false;
boolean values_received = false;
// Read 2 bytes from serial and make an uint16 of it. Additionally calculate
// checksum for PMSx003. Assumption is that there is data available, otherwise
// this function is blocking.
void SerialRead16(uint16_t* value, uint16_t* checksum)
  uint8_t data_high, data_low;
  // If swSerial is initialized, we are using soft serial
  if (swSerial != NULL)
    data_high = swSerial->read();
    data_low = swSerial->read();
  else
    data_high = Serial.read();
    data_low = Serial.read();
  *value = data_low;
  *value |= (data_high << 8);
  if (checksum != NULL)
    *checksum += data_high;
    *checksum += data_low;
#if 0
  // Low-level logging to see data from sensor
  String log = F("PMSx003 : byte high=0x");
  log += String(data_high,HEX);
  log += F(" byte low=0x");
  log += String(data_low,HEX);
  log += F(" result=0x");
  log += String(*value,HEX);
  addLog(LOG_LEVEL_INFO, log);
#endif
boolean PacketAvailable(void)
  boolean success = false;
  if (swSerial != NULL) // Software serial
    // When there is enough data in the buffer, search through the buffer to
    // find header (buffer may be out of sync)
    while (swSerial->available() >= PMSx003_SIZE)
      if (swSerial->read() == PMSx003_SIG1 && swSerial->read() == PMSx003_SIG2)
        success = true;
        break;
  else // Hardware serial
    while (Serial.available() >= PMSx003_SIZE)
      if (Serial.read() == PMSx003_SIG1 && Serial.read() == PMSx003_SIG2)
        success = true;
        break;
  return success;
boolean Plugin_053(byte function, struct EventStruct *event, String& string)
  String log;
  switch (function)
    case PLUGIN_DEVICE_ADD:
        Device[++deviceCount].Number = PLUGIN_ID_053;
        Device[deviceCount].Type = DEVICE_TYPE_TRIPLE;
        Device[deviceCount].VType = SENSOR_TYPE_TRIPLE;
        Device[deviceCount].Ports = 0;
        Device[deviceCount].PullUpOption = false;
        Device[deviceCount].InverseLogicOption = true;
        Device[deviceCount].FormulaOption = true;
        Device[deviceCount].ValueCount = 4;
        Device[deviceCount].SendDataOption = true;
        Device[deviceCount].TimerOption = true;
        Device[deviceCount].GlobalSyncOption = true;
        success = true;
        break;
    case PLUGIN_GET_DEVICENAME:
        string = F(PLUGIN_NAME_053);
        success = true;
        break;
    case PLUGIN_GET_DEVICEVALUENAMES:
        strcpy_P(ExtraTaskSettings.TaskDeviceValueNames[0], PSTR(PLUGIN_VALUENAME1_053));
        strcpy_P(ExtraTaskSettings.TaskDeviceValueNames[1], PSTR(PLUGIN_VALUENAME2_053));
        strcpy_P(ExtraTaskSettings.TaskDeviceValueNames[2], PSTR(PLUGIN_VALUENAME3_053));
        strcpy_P(ExtraTaskSettings.TaskDeviceValueNames[3], PSTR(PLUGIN_VALUENAME4_053));
        success = true;
        break;
      case PLUGIN_GET_DEVICEGPIONAMES:
          event->String1 = F("GPIO ← TX");
          event->String2 = F("GPIO → RX");
          event->String3 = F("GPIO → Reset");
          break;
    case PLUGIN_INIT:
        int rxPin = Settings.TaskDevicePin1[event->TaskIndex];
        int txPin = Settings.TaskDevicePin2[event->TaskIndex];
        int resetPin = Settings.TaskDevicePin3[event->TaskIndex];
        log = F("PMSx003 : config ");
        log += rxPin;
        log += txPin;
        log += resetPin;
        addLog(LOG_LEVEL_DEBUG, log);
        // Hardware serial is RX on 3 and TX on 1
        if (rxPin == 3 && txPin == 1)
          log = F("PMSx003 : using hardware serial");
          Serial.begin(9600);
          Serial.flush();
        else
          log = F("PMSx003: using software serial");
          swSerial = new ESPeasySoftwareSerial(rxPin, txPin);
          swSerial->begin(9600);
          swSerial->flush();
        if (resetPin >= 0) // Reset if pin is configured
          // Toggle 'reset' to assure we start reading header
          log = F("PMSx003: resetting module");
          pinMode(resetPin, OUTPUT);
          digitalWrite(resetPin, LOW);
          delay(250);
          digitalWrite(resetPin, HIGH);
          pinMode(resetPin, INPUT_PULLUP);
        Plugin_053_init = true;
        success = true;
        break;
    // The update rate from the module is 200ms .. multiple seconds. Practise
    // shows that we need to read the buffer many times per seconds to stay in
    // sync.
    case PLUGIN_TEN_PER_SECOND:
        if (Plugin_053_init)
          uint16_t checksum = 0, checksum2 = 0;
          uint16_t framelength = 0;
          uint16_t data[17];
          // byte data_low, data_high;
          int i = 0;
          // Check if a packet is available in the UART FIFO.
          if (PacketAvailable())
            log = F("PMSx003 : Packet available");
            addLog(LOG_LEVEL_DEBUG_MORE, log);
            checksum += PMSx003_SIG1 + PMSx003_SIG2;
            SerialRead16(&framelength, &checksum);
            if (framelength != (PMSx003_SIZE - 4))
              log = F("PMSx003 : invalid framelength - ");
              log += framelength;
              addLog(LOG_LEVEL_ERROR, log);
              break;
            for (i = 0; i < 17; i++)
              SerialRead16(&data[i], &checksum);
            log = F("PMSx003 : pm1.0=");
            log += data[0];
            log += F(", pm2.5=");
            log += data[1];
            log += F(", pm10=");
            log += data[2];
            log += F(", pm1.0a=");
            log += data[3];
            log += F(", pm2.5a=");
            log += data[4];
            log += F(", pm10a=");
            log += data[5];
            log = F("PMSx003 : count/0.1L : 0.3um=");
            log += data[6];
            log += F(", 0.5um=");
            log += data[7];
            log += F(", 1.0um=");
            log += data[8];
            log += F(", 2.5um=");
            log += data[9];
            log += F(", 5.0um=");
            log += data[10];
            log += F(", 10um=");
            log += data[11];
            log += F(", HCHO=");
            log += data[12];
            log += F(", TEMP=");
            log += float(data[13]/10.00);
            log += F(", HUMI=");
            log += float(data[14]/10.00);
            // Compare checksums
            SerialRead16(&checksum2, NULL);
            if (checksum == checksum2)
              // Data is checked and good, fill in output
              UserVar[event->BaseVarIndex]     = data[4];
              UserVar[event->BaseVarIndex + 1] = float(data[13]/10.00);//data[13]/10;
              UserVar[event->BaseVarIndex + 2] = float(data[14]/10.00);//data[14]/10;
              UserVar[event->BaseVarIndex + 3] = float(data[12]/1000.000);//data[12]/1000;
              values_received = true;
              success = true;
        break;
    case PLUGIN_READ:
        // When new data is available, return true
        success = values_received;
  return success;
#endif // PLUGIN_BUILD_TESTING
_P053_PMSx003.ino
8.67 KB, 下载次数: 67
ESPEasy固件_mega-20180114_PMS5003ST_4096m.rar
426.93 KB, 下载次数: 140
参与人数 3金钱 +37 收起 理由
smc326 + 7 赠人玫瑰,手留余香!
+ 20 膜拜大神!
windgo + 10 谢谢分享!
发表于 2018-1-18 10:26:33 | 显示全部楼层
赞 多谢分享
发表于 2018-1-18 20:57:22 | 显示全部楼层
厉害了东哥,感谢分享!
发表于 2018-1-21 14:31:32 | 显示全部楼层
谢谢分享!
发表于 2018-1-29 15:53:29 来自手机 | 显示全部楼层
这个插件,PMS5003.ico,用什么工具,怎么刷?
 楼主| 发表于 2018-1-30 00:34:17 | 显示全部楼层
这个插件ino放入espeasy官网下载的源码文件夹里替换掉原插件,用ATOM软件打开载入espeasy项目编译成你需要的版本,我编译成4m测试版刷入成功运行。
1楼有教程链接,可以去看看
发表于 2018-1-30 11:50:51 | 显示全部楼层
阿东 发表于 2018-1-30 00:34
这个插件ino放入espeasy官网下载的源码文件夹里替换掉原插件,用ATOM软件打开载入espeasy项目编译成你需要 ...
那你另外一个附件是不是可以直接用了,已经包含了你这个ico插件了。谢谢
 楼主| 发表于 2018-1-31 13:23:15 | 显示全部楼层
cced000 发表于 2018-1-30 11:50
那你另外一个附件是不是可以直接用了,已经包含了你这个ico插件了。谢谢 ...
是的,第二个附件,已经修改过了,支持pms5003st
发表于 2018-2-2 15:47:10 | 显示全部楼层
再请教一下,espeasy是搞定了如何将数据传到HA,然后显示到手机上呢,用的是自带的mqtt,
Description An Open Source MQTT broker
Version 1.0
MQTT及EASPeasy要如何设置内,谢谢
 楼主| 发表于 2018-2-2 18:52:59 | 显示全部楼层
Descri ...
这个得搜索下论坛里 mqtt ha,相关的教程,我只上传到乐联网没有上传到HA。
GMT+8, 2025-12-31 23:34 , Processed in 0.057299 second(s), 9 queries , MemCached On.
