查看: 1441|回复: 1
[流程系列] 求教各位大神node-RED启动不了 小白一个
发表于 2024-4-1 17:37:41 | 显示全部楼层 |阅读模式
s6-rc: info: service base-addon-banner: starting
Add-on: Node-RED
Flow-based programming for the Internet of Things
Add-on version: 17.0.11
You are running the latest version of this add-on.
System: Home Assistant OS 12.1  (aarch64 / green)
Home Assistant Core: 2024.3.3
Home Assistant Supervisor: 2024.03.1
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service init-nginx: starting
s6-rc: info: service init-customizations: starting
s6-rc: info: service init-customizations successfully started
s6-rc: info: service init-nodered: starting
[17:19:16] FATAL:
[17:19:16] FATAL: SSL has been enabled using the 'ssl' option,
[17:19:16] FATAL: this requires an SSL certificate file which is
[17:19:16] FATAL: configured using the 'certfile' option in the
[17:19:16] FATAL: add-on configuration.
[17:19:16] FATAL:
s6-rc: info: service init-nodered successfully started
s6-rc: info: service nodered: starting
[17:19:16] FATAL: Unfortunately, the file specified in the
s6-rc: info: service nodered successfully started
[17:19:16] FATAL: 'certfile' option does not exist.
[17:19:16] FATAL:
[17:19:16] FATAL: Please ensure the certificate file exists and
[17:19:16] FATAL: is placed in the '/ssl/' directory.
[17:19:16] FATAL:
[17:19:16] FATAL: In case you don't have SSL yet, consider getting
[17:19:16] FATAL: an SSL certificate or setting the 'ssl' option
[17:19:16] FATAL: to 'false' in case you are not planning on using
[17:19:16] FATAL: SSL with this add-on.
[17:19:16] FATAL:
[17:19:16] FATAL: Check the add-on manual for more information.
[17:19:16] FATAL:
s6-rc: warning: unable to start service init-nginx: command exited 1
/run/s6/basedir/scripts/rc.init: warning: s6-rc failed to properly bring all the services up! Check your logs (in /run/uncaught-logs/current if you have in-container logging) for more information.
/run/s6/basedir/scripts/rc.init: fatal: stopping the container.
s6-rc: info: service nodered: stopping
[17:19:17] INFO: Service Node-RED exited with code 256 (by signal 15)
s6-rc: info: service nodered successfully stopped
s6-rc: info: service init-nodered: stopping
s6-rc: info: service init-nodered successfully stopped
s6-rc: info: service init-customizations: stopping
s6-rc: info: service init-customizations successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service base-addon-log-level: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service base-addon-log-level successfully stopped
s6-rc: info: service base-addon-banner: stopping
s6-rc: info: service base-addon-banner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
希望各位大神给个解决方法,谢谢了
盐城智能大神
发表于 2024-4-1 18:30:12 | 显示全部楼层
把ssl  钩去掉
GMT+8, 2025-12-3 07:58 , Processed in 0.077228 second(s), 6 queries , MemCached On.
