查看: 12126|回复: 9
[求助] hassio处于loading界面一天一夜了,求解决方案
发表于 2018-1-17 19:38:25 | 显示全部楼层 |阅读模式
点击升级之后就一直处于这个界面 一天一夜了 不知道是哪里出现问题,求解决方案
2018-01-17 12:28:36 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=21 from 2018-01-16 15:56:27.597227)
2018-01-17 12:28:44 WARNING (MainThread) [homeassistant.components.updater] Running on 'dev', only analytics will be submitted
2018-01-17 12:56:14 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-01-17 12:56:20 ERROR (MainThread) [homeassistant.loader] Unable to find component broadlink
2018-01-17 12:56:21 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
  File "/usr/lib/python3.6/asyncio/tasks.py", line 180, in _step
    result = coro.send(None)
  File "/usr/lib/python3.6/site-packages/homeassistant/components/websocket_api.py", line 473, in get_services_helper
    descriptions = yield from async_get_all_descriptions(self.hass)
  File "/usr/lib/python3.6/site-packages/homeassistant/helpers/service.py", line 153, in async_get_all_descriptions
    yaml_file = domain_yaml_file(domain)
  File "/usr/lib/python3.6/site-packages/homeassistant/helpers/service.py", line 137, in domain_yaml_file
    component_path = path.dirname(get_component(domain).__file__)
AttributeError: 'NoneType' object has no attribute '__file__'
2018-01-17 13:28:49 ERROR (MainThread) [homeassistant.components.updater] Could not contact Home Assistant Update to check for updates
2018-01-17 15:07:31 WARNING (MainThread) [homeassistant.components.cloud.iot] Connection closed: Connection cancelled.
2018-01-17 16:29:21 ERROR (MainThread) [homeassistant.loader] Unable to find component broadlink
2018-01-17 16:29:21 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2018-01-17 19:29:27 ERROR (MainThread) [homeassistant.loader] Unable to find component broadlink
2018-01-17 19:29:27 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
发表于 2018-1-17 19:41:08 | 显示全部楼层
网络问题。
 楼主| 发表于 2018-1-17 19:43:07 | 显示全部楼层
点击升级之后就一直处于这个界面,没有变过,我把log贴上来了,可否帮忙看看
seyf
发表于 2018-1-17 20:09:04 | 显示全部楼层
支持一席
发表于 2018-1-17 20:29:59 | 显示全部楼层
论坛搜索,替换broadlink.py文件,还有就是custom_ui更新下,然后就可以了。亲测
发表于 2018-1-17 22:18:42 | 显示全部楼层
还有就是0.61,如果有彩云SE,也是一直转圈
发表于 2018-1-19 00:51:53 来自手机 | 显示全部楼层
我也一样,你解决了那,手贱升级……
发表于 2018-1-19 10:20:09 | 显示全部楼层
应该是数据库之前有未完成的session被锁住了。
1. 重新启动过机器吗?
2. 可以ssh登入Home Assistant吗?
发表于 2018-1-19 21:15:43 来自手机 | 显示全部楼层
收藏起來
发表于 2021-2-7 22:14:38 | 显示全部楼层
qq412498569 发表于 2018-1-17 20:29
论坛搜索,替换broadlink.py文件,还有就是custom_ui更新下,然后就可以了。亲测 ...
关键词是啥
GMT+8, 2025-12-22 23:13 , Processed in 0.057341 second(s), 9 queries , MemCached On.
