查看: 2478|回复: 4
[求助] 涂鸦ZigBee开关接入ZigBee2mqtt响应迟钝或者完全不响应。
发表于 2024-3-25 14:58:03 | 显示全部楼层 |阅读模式
求助涂鸦ZigBee开关接入ZigBee2mqtt响应迟钝或者完全不响应。但是接入ZHA就很灵敏。
发表于 2024-3-26 00:00:17 | 显示全部楼层
找到zigbee2mqttdata\data文件夹里面database.db,把对应设备json完整发一下。
调整Z2M日志等级为debug,抓一下通讯消息数据。
 楼主| 发表于 2024-3-28 11:58:23 | 显示全部楼层
调整Z2M日志等级为debug,抓 ...
{"id":1,"type":"Coordinator","ieeeAddr":"0x60a423fffe10f09b","nwkAddr":0,"manufId":0,"epList":[1,242],"endpoints":{"1":{"profId":260,"epId":1,"devId":48879,"inClusterList":[0,3,6,10,25,26,768],"outClusterList":[0,3,4,5,6,8,32,768,1024,1026,1029,1030,1280,2817,2819,2820,1794,4096,64513,64514],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}},"242":{"profId":41440,"epId":242,"devId":97,"inClusterList":[],"outClusterList":[33],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"interviewCompleted":true,"meta":{},"lastSeen":1711549570733}
{"id":2,"type":"Router","ieeeAddr":"0x000d6f001280b782","nwkAddr":42862,"manufId":4451,"manufName":"REXENSE","powerSource":"Mains (single phase)","modelId":"TY0002","epList":[1,2],"endpoints":{"1":{"profId":260,"epId":1,"devId":256,"inClusterList":[0,3,4,5,6],"outClusterList":[],"clusters":{"65024":{"attributes":{"0":4294967295,"1":{"type":"Buffer","data":[97,100,54,52,51,54,51,52,51,51,51,54,51,51,51,52]},"2":{"type":"Buffer","data":[54,102,97,49,57,50,50,49,97,101,54,100,53,101,102,102]},"3":300}},"genOnOff":{"attributes":{"onOff":0}}},"binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x60a423fffe10f09b","endpointID":1}],"configuredReportings":[{"cluster":6,"attrId":0,"minRepIntval":0,"maxRepIntval":65000,"repChange":1,"manufacturerCode":null}],"meta":{}},"2":{"profId":260,"epId":2,"devId":256,"inClusterList":[0,3,4,5,6],"outClusterList":[],"clusters":{"genOnOff":{"attributes":{"onOff":0}}},"binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x60a423fffe10f09b","endpointID":1}],"configuredReportings":[{"cluster":6,"attrId":0,"minRepIntval":0,"maxRepIntval":65000,"repChange":1,"manufacturerCode":null}],"meta":{}}},"appVersion":3,"stackVersion":87,"hwVersion":3,"dateCode":"20180820","swBuildId":"20180820 11:51","zclVersion":2,"interviewCompleted":true,"meta":{"configured":1324213189},"lastSeen":1711549625093}
{"id":3,"type":"Router","ieeeAddr":"0x000d6f001280d4f1","nwkAddr":7753,"manufId":4451,"manufName":"REXENSE","powerSource":"Mains (single phase)","modelId":"TY0002","epList":[1,2],"endpoints":{"1":{"profId":260,"epId":1,"devId":256,"inClusterList":[0,3,4,5,6],"outClusterList":[],"clusters":{"65024":{"attributes":{"0":4294967295,"1":{"type":"Buffer","data":[98,98,54,50,51,54,51,50,51,51,51,54,51,51,51,50]},"2":{"type":"Buffer","data":[102,57,101,49,52,55,97,97,97,53,97,101,50,99,53,49]},"3":300}},"genOnOff":{"attributes":{"onOff":1}}},"binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x60a423fffe10f09b","endpointID":1}],"configuredReportings":[{"cluster":6,"attrId":0,"minRepIntval":0,"maxRepIntval":65000,"repChange":1,"manufacturerCode":null}],"meta":{}},"2":{"profId":260,"epId":2,"devId":256,"inClusterList":[0,3,4,5,6],"outClusterList":[],"clusters":{"genOnOff":{"attributes":{"onOff":1}}},"binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x60a423fffe10f09b","endpointID":1}],"configuredReportings":[{"cluster":6,"attrId":0,"minRepIntval":0,"maxRepIntval":65000,"repChange":1,"manufacturerCode":null}],"meta":{}}},"appVersion":3,"stackVersion":87,"hwVersion":3,"dateCode":"20180820","swBuildId":"20180820 11:51","zclVersion":2,"interviewCompleted":true,"meta":{"configured":1324213189},"lastSeen":1711549263723}
{"id":4,"type":"EndDevice","ieeeAddr":"0x00158d000200940b","nwkAddr":57461,"manufId":4478,"manufName":"feibit","powerSource":"Battery","modelId":"FNB56-THM14FB2.4","epList":[1],"endpoints":{"1":{"profId":260,"epId":1,"devId":770,"inClusterList":[0,1026,3,10,1029,25,1,4096],"outClusterList":[4,3,4096],"clusters":{"genBasic":{"attributes":{"modelId":"FNB56-THM14FB2.4","manufacturerName":"feibit","powerSource":3,"zclVersion":2}},"msTemperatureMeasurement":{"attributes":{"measuredValue":2221}},"msRelativeHumidity":{"attributes":{"measuredValue":1896}},"genPowerCfg":{"attributes":{"batteryVoltage":24,"batteryPercentageRemaining":80,"batteryAlarmState":0}}},"binds":[],"configuredReportings":[],"meta":{}}},"zclVersion":2,"interviewCompleted":true,"meta":{},"lastSeen":1711549342895}
{"id":5,"type":"Router","ieeeAddr":"0x000d6f001280bfdf","nwkAddr":17972,"manufId":4451,"manufName":"REXENSE","powerSource":"Mains (single phase)","modelId":"TY0002","epList":[1,2],"endpoints":{"1":{"profId":260,"epId":1,"devId":256,"inClusterList":[0,3,4,5,6],"outClusterList":[],"clusters":{"65024":{"attributes":{"0":4294967295,"1":{"type":"Buffer","data":[99,102,54,54,51,54,51,54,51,51,51,54,51,51,51,54]},"2":{"type":"Buffer","data":[101,52,53,52,99,52,54,97,101,98,55,48,53,102,101,54]},"3":300}},"genOnOff":{"attributes":{"onOff":0}}},"binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x60a423fffe10f09b","endpointID":1}],"configuredReportings":[{"cluster":6,"attrId":0,"minRepIntval":0,"maxRepIntval":65000,"repChange":1,"manufacturerCode":null}],"meta":{}},"2":{"profId":260,"epId":2,"devId":256,"inClusterList":[0,3,4,5,6],"outClusterList":[],"clusters":{"genOnOff":{"attributes":{"onOff":1}}},"binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x60a423fffe10f09b","endpointID":1}],"configuredReportings":[{"cluster":6,"attrId":0,"minRepIntval":0,"maxRepIntval":65000,"repChange":1,"manufacturerCode":null}],"meta":{}}},"appVersion":3,"stackVersion":87,"hwVersion":3,"dateCode":"20180820","swBuildId":"20180820 11:51","zclVersion":2,"interviewCompleted":true,"meta":{"configured":1324213189},"lastSeen":1711549677815}
{"id":6,"type":"Router","ieeeAddr":"0x000d6f001281172f","nwkAddr":30675,"manufId":4451,"manufName":"REXENSE","powerSource":"Mains (single phase)","modelId":"TY0002","epList":[1,2],"endpoints":{"1":{"profId":260,"epId":1,"devId":256,"inClusterList":[0,3,4,5,6],"outClusterList":[],"clusters":{"65024":{"attributes":{"0":4294967295,"1":{"type":"Buffer","data":[49,101,54,53,51,54,51,53,51,51,51,54,51,51,51,53]},"2":{"type":"Buffer","data":[48,55,54,102,55,50,48,51,52,98,52,53,97,53,52,99]},"3":300}},"genBasic":{"attributes":{"modelId":"TY0002","manufacturerName":"REXENSE","powerSource":1,"zclVersion":2,"appVersion":3,"stackVersion":87,"hwVersion":3,"dateCode":"20180820","swBuildId":"20180820 11:51"}},"genOnOff":{"attributes":{"onOff":1}}},"binds":[],"configuredReportings":[],"meta":{}},"2":{"profId":260,"epId":2,"devId":256,"inClusterList":[0,3,4,5,6],"outClusterList":[],"clusters":{"genOnOff":{"attributes":{"onOff":1}}},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":3,"stackVersion":87,"hwVersion":3,"dateCode":"20180820","swBuildId":"20180820 11:51","zclVersion":2,"interviewCompleted":true,"meta":{},"lastSeen":1711549679080}
{"id":7,"type":"EndDevice","ieeeAddr":"0x00158d00020091ea","nwkAddr":41624,"manufId":4478,"manufName":"feibit","powerSource":"Battery","modelId":"FNB56-BOT06FB2.3","epList":[1],"endpoints":{"1":{"profId":260,"epId":1,"devId":1026,"inClusterList":[0,3,10,25,1,1280,1281,4096],"outClusterList":[4,3,1,1280,1281],"clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":160,"batteryVoltage":28,"batteryAlarmState":0}},"genBasic":{"attributes":{"modelId":"FNB56-BOT06FB2.3","manufacturerName":"feibit","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":2,"hwVersion":1,"dateCode":"20171215","swBuildId":"\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x60a423fffe10f09b","zoneState":1}}},"binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x60a423fffe10f09b","endpointID":1}],"configuredReportings":[{"cluster":1,"attrId":33,"minRepIntval":3600,"maxRepIntval":65000,"repChange":0,"manufacturerCode":null}],"meta":{}}},"appVersion":1,"stackVersion":2,"hwVersion":1,"dateCode":"20171215","swBuildId":"\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","zclVersion":2,"interviewCompleted":true,"meta":{},"lastSeen":1711548701519}
{"id":8,"type":"Router","ieeeAddr":"0x000d6f00128110ce","nwkAddr":55771,"manufId":4451,"manufName":"REXENSE","powerSource":"Mains (single phase)","modelId":"TY0003","epList":[1,2,3],"endpoints":{"1":{"profId":260,"epId":1,"devId":256,"inClusterList":[0,3,4,5,6],"outClusterList":[],"clusters":{"65024":{"attributes":{"0":4294967295,"1":{"type":"Buffer","data":[98,53,51,53,51,51,51,53,51,51,51,51,51,51,51,53]},"2":{"type":"Buffer","data":[49,100,55,52,98,57,48,99,102,55,57,98,99,100,49,56]},"3":300}},"genBasic":{"attributes":{"modelId":"TY0003","manufacturerName":"REXENSE","powerSource":1,"zclVersion":2,"appVersion":3,"stackVersion":87,"hwVersion":3,"dateCode":"20180820","swBuildId":"20180820 11:49"}},"genOnOff":{"attributes":{"onOff":0}}},"binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x60a423fffe10f09b","endpointID":1}],"configuredReportings":[{"cluster":6,"attrId":0,"minRepIntval":0,"maxRepIntval":65000,"repChange":1,"manufacturerCode":null}],"meta":{}},"2":{"profId":260,"epId":2,"devId":256,"inClusterList":[0,3,4,5,6],"outClusterList":[],"clusters":{"genOnOff":{"attributes":{"onOff":0}}},"binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x60a423fffe10f09b","endpointID":1}],"configuredReportings":[{"cluster":6,"attrId":0,"minRepIntval":0,"maxRepIntval":65000,"repChange":1,"manufacturerCode":null}],"meta":{}},"3":{"profId":260,"epId":3,"devId":256,"inClusterList":[0,3,4,5,6],"outClusterList":[],"clusters":{"genOnOff":{"attributes":{"onOff":0}}},"binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x60a423fffe10f09b","endpointID":1}],"configuredReportings":[{"cluster":6,"attrId":0,"minRepIntval":0,"maxRepIntval":65000,"repChange":1,"manufacturerCode":null}],"meta":{}}},"appVersion":3,"stackVersion":87,"hwVersion":3,"dateCode":"20180820","swBuildId":"20180820 11:49","zclVersion":2,"interviewCompleted":true,"meta":{"configured":1324213189},"lastSeen":1711549687515}
{"id":9,"type":"Router","ieeeAddr":"0x000d6f001280ba8b","nwkAddr":56393,"manufId":4451,"manufName":"REXENSE","powerSource":"Mains (single phase)","modelId":"TY0003","epList":[1,2,3],"endpoints":{"1":{"profId":260,"epId":1,"devId":256,"inClusterList":[0,3,4,5,6],"outClusterList":[],"clusters":{"65024":{"attributes":{"0":4294967295,"1":{"type":"Buffer","data":[54,98,54,50,51,54,51,50,51,51,51,54,51,51,51,50]},"2":{"type":"Buffer","data":[99,100,55,52,49,50,100,97,99,99,48,56,55,57,101,57]},"3":300}},"genBasic":{"attributes":{"modelId":"TY0003","manufacturerName":"REXENSE","powerSource":1,"zclVersion":2,"appVersion":3,"stackVersion":87,"hwVersion":3,"dateCode":"20180820","swBuildId":"20180820 11:49"}},"genOnOff":{"attributes":{"onOff":0}}},"binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x60a423fffe10f09b","endpointID":1}],"configuredReportings":[{"cluster":6,"attrId":0,"minRepIntval":0,"maxRepIntval":65000,"repChange":1,"manufacturerCode":null}],"meta":{}},"2":{"profId":260,"epId":2,"devId":256,"inClusterList":[0,3,4,5,6],"outClusterList":[],"clusters":{"genOnOff":{"attributes":{"onOff":0}}},"binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x60a423fffe10f09b","endpointID":1}],"configuredReportings":[{"cluster":6,"attrId":0,"minRepIntval":0,"maxRepIntval":65000,"repChange":1,"manufacturerCode":null}],"meta":{}},"3":{"profId":260,"epId":3,"devId":256,"inClusterList":[0,3,4,5,6],"outClusterList":[],"clusters":{"genOnOff":{"attributes":{"onOff":0}}},"binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x60a423fffe10f09b","endpointID":1}],"configuredReportings":[{"cluster":6,"attrId":0,"minRepIntval":0,"maxRepIntval":65000,"repChange":1,"manufacturerCode":null}],"meta":{}}},"appVersion":3,"stackVersion":87,"hwVersion":3,"dateCode":"20180820","swBuildId":"20180820 11:49","zclVersion":2,"interviewCompleted":true,"meta":{"configured":1324213189},"lastSeen":1711549620447}
{"id":10,"type":"Router","ieeeAddr":"0xa4c138cabdf4c37e","nwkAddr":28763,"manufId":4417,"manufName":"_TZ3210_zdrhqmo0","powerSource":"Mains (single phase)","modelId":"TS0502B","epList":[1,242],"endpoints":{"1":{"profId":260,"epId":1,"devId":268,"inClusterList":[3,4,5,6,4096,8,768,61184,0],"outClusterList":[25,10],"clusters":{"genBasic":{"attributes":{"65503":"\u0001\u0000\u0000\u0000\u0012\u0001\u0000\u0000\u0000\u0012\u0001\u0000\u0000\u0000\u0012","65506":53,"65508":1,"65534":0,"modelId":"TS0502B","manufacturerName":"_TZ3210_zdrhqmo0","powerSource":1,"zclVersion":3,"appVersion":100,"stackVersion":0,"hwVersion":1,"dateCode":""}},"lightingColorCtrl":{"attributes":{"57344":1000,"57600":[1000,0],"61447":[],"61448":[],"61449":[],"61453":0,"colorCapabilities":16,"colorTempPhysicalMin":153,"colorTempPhysicalMax":500,"tuyaRgbMode":0,"currentHue":null,"colorMode":0,"colorTemperature":153}},"genOnOff":{"attributes":{"61440":0,"onOff":1}},"genLevelCtrl":{"attributes":{"61440":1000,"currentLevel":254}}},"binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x60a423fffe10f09b","endpointID":1},{"cluster":8,"type":"endpoint","deviceIeeeAddress":"0x60a423fffe10f09b","endpointID":1}],"configuredReportings":[{"cluster":6,"attrId":0,"minRepIntval":0,"maxRepIntval":3600,"repChange":0,"manufacturerCode":null},{"cluster":8,"attrId":0,"minRepIntval":1,"maxRepIntval":3600,"repChange":1,"manufacturerCode":null}],"meta":{}},"242":{"profId":41440,"epId":242,"devId":97,"inClusterList":[],"outClusterList":[33],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":100,"stackVersion":0,"hwVersion":1,"dateCode":"","zclVersion":3,"interviewCompleted":true,"meta":{"configured":-2027012541},"lastSeen":1711549677240}
{"id":11,"type":"Router","ieeeAddr":"0xa4c1387841a6f934","nwkAddr":11685,"manufId":4417,"manufName":"_TZ3210_zdrhqmo0","powerSource":"Mains (single phase)","modelId":"TS0502B","epList":[1,242],"endpoints":{"1":{"profId":260,"epId":1,"devId":268,"inClusterList":[3,4,5,6,4096,8,768,61184,0],"outClusterList":[25,10],"clusters":{"genBasic":{"attributes":{"65503":"\u0001\u0000\u0000\u0000\u0012","65506":53,"65508":1,"65534":0,"modelId":"TS0502B","manufacturerName":"_TZ3210_zdrhqmo0","powerSource":1,"zclVersion":3,"appVersion":100,"stackVersion":0,"hwVersion":1,"dateCode":""}},"lightingColorCtrl":{"attributes":{"57344":1000,"61447":[],"61448":[],"61449":[],"61453":0,"colorCapabilities":16,"colorTempPhysicalMin":153,"colorTempPhysicalMax":500,"tuyaRgbMode":0,"currentHue":null}},"genOnOff":{"attributes":{"61440":0,"onOff":1}},"genLevelCtrl":{"attributes":{"61440":1000,"currentLevel":254}}},"binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x60a423fffe10f09b","endpointID":1},{"cluster":8,"type":"endpoint","deviceIeeeAddress":"0x60a423fffe10f09b","endpointID":1}],"configuredReportings":[{"cluster":6,"attrId":0,"minRepIntval":0,"maxRepIntval":3600,"repChange":0,"manufacturerCode":null},{"cluster":8,"attrId":0,"minRepIntval":1,"maxRepIntval":3600,"repChange":1,"manufacturerCode":null}],"meta":{}},"242":{"profId":41440,"epId":242,"devId":97,"inClusterList":[],"outClusterList":[33],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":100,"stackVersion":0,"hwVersion":1,"dateCode":"","zclVersion":3,"interviewCompleted":true,"meta":{"configured":-2027012541},"lastSeen":1711549679891}
{"id":12,"type":"Router","ieeeAddr":"0xa4c138de6215cfbb","nwkAddr":62785,"manufId":4417,"manufName":"_TZ3210_zdrhqmo0","powerSource":"Mains (single phase)","modelId":"TS0502B","epList":[1,242],"endpoints":{"1":{"profId":260,"epId":1,"devId":268,"inClusterList":[3,4,5,6,4096,8,768,61184,0],"outClusterList":[25,10],"clusters":{"genBasic":{"attributes":{"65503":"\u0001\u0000\u0000\u0000\u0012\u0001\u0000\u0000\u0000\u0012\u0001\u0000\u0000\u0000\u0012\u0001\u0000\u0000\u0000\u0012\u0001\u0000\u0000\u0000\u0012","65506":53,"65508":1,"65534":0,"modelId":"TS0502B","manufacturerName":"_TZ3210_zdrhqmo0","powerSource":1,"zclVersion":3,"appVersion":100,"stackVersion":0,"hwVersion":1,"dateCode":""}},"lightingColorCtrl":{"attributes":{"57344":1000,"61447":[],"61448":[],"61449":[],"61453":0,"colorCapabilities":16,"colorTempPhysicalMin":153,"colorTempPhysicalMax":500,"tuyaRgbMode":0,"currentHue":null}},"genOnOff":{"attributes":{"61440":0,"onOff":1}},"genLevelCtrl":{"attributes":{"61440":1000,"currentLevel":254}}},"binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x60a423fffe10f09b","endpointID":1},{"cluster":8,"type":"endpoint","deviceIeeeAddress":"0x60a423fffe10f09b","endpointID":1}],"configuredReportings":[{"cluster":6,"attrId":0,"minRepIntval":0,"maxRepIntval":3600,"repChange":0,"manufacturerCode":null},{"cluster":8,"attrId":0,"minRepIntval":1,"maxRepIntval":3600,"repChange":1,"manufacturerCode":null}],"meta":{}},"242":{"profId":41440,"epId":242,"devId":97,"inClusterList":[],"outClusterList":[33],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":100,"stackVersion":0,"hwVersion":1,"dateCode":"","zclVersion":3,"interviewCompleted":true,"meta":{"configured":-2027012541},"lastSeen":1711549679866}
{"id":13,"type":"Router","ieeeAddr":"0xa4c138ad1a23474c","nwkAddr":42398,"manufId":4417,"manufName":"_TZ3210_zdrhqmo0","powerSource":"Mains (single phase)","modelId":"TS0502B","epList":[1,242],"endpoints":{"1":{"profId":260,"epId":1,"devId":268,"inClusterList":[3,4,5,6,4096,8,768,61184,0],"outClusterList":[25,10],"clusters":{"genBasic":{"attributes":{"modelId":"TS0502B","manufacturerName":"_TZ3210_zdrhqmo0","powerSource":1,"zclVersion":3,"appVersion":100,"stackVersion":0}},"lightingColorCtrl":{"attributes":{"colorCapabilities":16}},"genOnOff":{"attributes":{"onOff":1}},"genLevelCtrl":{"attributes":{"currentLevel":254}}},"binds":[],"configuredReportings":[],"meta":{}},"242":{"epId":242,"inClusterList":[],"outClusterList":[],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":100,"stackVersion":0,"zclVersion":3,"interviewCompleted":false,"meta":{},"lastSeen":1711549673971}
{"id":14,"type":"Unknown","ieeeAddr":"0xa4c1386a8a971b98","nwkAddr":2612,"epList":[1],"endpoints":{"1":{"epId":1,"inClusterList":[],"outClusterList":[],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"interviewCompleted":false,"meta":{},"lastSeen":1711549673157}
 楼主| 发表于 2024-3-28 12:00:17 | 显示全部楼层
json
    "0x00158d000200940b": {
        "temperature": 22.21,
        "humidity": 18.96,
        "linkquality": 80,
        "battery": 0,
        "voltage": 2400,
        "battery_low": false
    "0x000d6f001281172f": {
        "linkquality": 192,
        "state_1": "ON",
        "state_2": "ON"
    "0x000d6f001280b782": {
        "state_1": "OFF",
        "state_2": "OFF",
        "linkquality": 192
    "0x000d6f001280d4f1": {
        "state_1": "ON",
        "state_2": "ON",
        "linkquality": 192
    "0x000d6f001280bfdf": {
        "state_1": "OFF",
        "state_2": "ON",
        "linkquality": 192
    "0xa4c138cabdf4c37e": {
        "color_mode": "color_temp",
        "state": "ON",
        "brightness": 254,
        "linkquality": 192,
        "color": {
            "hue": 0,
            "h": 0
        "color_temp": 500
    "0x00158d00020091ea": {
        "battery": 80,
        "linkquality": 172,
        "occupancy": false,
        "tamper": false,
    "0x000d6f00128110ce": {
        "linkquality": 76,
        "state_1": "OFF",
        "state_2": "OFF",
        "state_3": "OFF"
    "0x000d6f001280ba8b": {
        "state_1": "OFF",
        "state_2": "OFF",
        "state_3": "OFF",
        "linkquality": 192
    "0xa4c1387841a6f934": {
        "color_mode": "xy",
        "state": "ON",
        "brightness": 254,
        "color": {
            "hue": 0,
            "h": 0
        "linkquality": 192,
        "do_not_disturb": true
    "0xa4c138de6215cfbb": {
        "state": "ON",
        "brightness": 254,
        "color": {
            "hue": 0,
            "h": 0
        "linkquality": 116,
        "color_temp": 153,
        "do_not_disturb": false
    "0xa4c138ad1a23474c": {
        "state": "ON",
        "linkquality": 48,
        "brightness": 254
 楼主| 发表于 2024-3-28 14:20:24 | 显示全部楼层
大神,抱歉了,日志等级调好了,但是目前不在家,抓不到数据。
GMT+8, 2025-12-18 17:38 , Processed in 0.589944 second(s), 12 queries , MemCached On.
