冬瓜os小主机版node-red启动失败,配置文件:theme: defaulthttp_node:
username: user
password: user
http_static:
username: user
password: user
ssl: true
certfile: fullchain.pem
keyfile: privkey.pem
system_packages: []
npm_packages: []
init_commands: []
log_level: trace
credential_secret: user
日志信息
[14:22:11] TRACE: bashio::fs.file_exists: /ssl/fullchain.pem[14:22:11] FATAL: [14:22:11] FATAL: [color=var(--error-color)]SSL has been enabled using the 'ssl' option,[14:22:11] FATAL: [color=var(--error-color)]this requires an SSL certificate file which is[14:22:11] FATAL: [color=var(--error-color)]configured using the 'certfile' option in the[14:22:11] TRACE: bashio::config.exists: max_old_space_size[14:22:11] FATAL: [color=var(--error-color)]add-on configuration.[14:22:11] TRACE: bashio::config: max_old_space_size[14:22:11] FATAL: [14:22:11] TRACE: bashio::addon.config[14:22:11] FATAL: [color=var(--error-color)]Unfortunately, the file specified in the[14:22:11] TRACE: bashio::cache.exists: addons.self.options.config[14:22:11] FATAL: [color=var(--error-color)]'certfile' option does not exist.[14:22:11] TRACE: bashio::fs.file_exists: /tmp/.bashio/addons.self.options.config.cache[14:22:11] TRACE: bashio::cache.get: addons.self.options.config[14:22:11] FATAL: [14:22:11] TRACE: bashio::cache.exists: addons.self.options.config[14:22:11] FATAL: [color=var(--error-color)]Please ensure the certificate file exists and[14:22:11] TRACE: bashio::fs.file_exists: /tmp/.bashio/addons.self.options.config.cache[14:22:11] FATAL: [color=var(--error-color)]is placed in the '/ssl/' directory.[14:22:11] TRACE: bashio::jq: {"theme":"default","http_node":{"username":"user","password":"user"},"http_static":{"username":"user","password":"user"},"ssl":true,"certfile":"fullchain.pem","keyfile":"privkey.pem","system_packages":[],"npm_packages":[],"init_commands":[],"log_level":"trace","credential_secret":"user"} if (.max_old_space_size == null) then null elif (.max_old_space_size | type == "string") then .max_old_space_size // empty elif (.max_old_space_size | type == "boolean") then .max_old_space_size // false elif (.max_old_space_size | type == "array") then if (.max_old_space_size == []) then empty else .max_old_space_size[] end elif (.max_old_space_size | type == "object") then if (.max_old_space_size == {}) then empty else .max_old_space_size end else .max_old_space_size end[14:22:11] FATAL: [14:22:11] FATAL: [color=var(--error-color)]In case you don't have SSL yet, consider getting[14:22:11] FATAL: [color=var(--error-color)]an SSL certificate or setting the 'ssl' option[14:22:11] FATAL: [color=var(--error-color)]to 'false' in case you are not planning on using[14:22:11] FATAL: [color=var(--error-color)]SSL with this add-on.[14:22:11] FATAL: [14:22:11] FATAL: [color=var(--error-color)]Check the add-on manual for more information.[14:22:11] FATAL: [14:22:11] TRACE: bashio::config.true: safe_mode[14:22:11] TRACE: bashio::exit.nok:[14:22:11] TRACE: bashio::var.has_value: [14:22:11] TRACE: bashio::config: safe_modes6-rc: warning: unable to start service init-nginx: command exited 1/run/s6/basedir/scripts/rc.init: warning: s6-rc failed to properly bring all the services up! Check your logs (in /run/uncaught-logs/current if you have in-container logging) for more information./run/s6/basedir/scripts/rc.init: fatal: stopping the container.
求解决方法
