楼主: lidicn
[插件集成] 百度人脸识别【更新V126】【适配HA0.73】
发表于 2018-10-14 17:45:34 | 显示全部楼层
支持一下 能不能支持从rstp截图
发表于 2018-10-15 20:46:38 | 显示全部楼层
厉害,谢谢分享!
发表于 2018-10-16 08:52:30 | 显示全部楼层
厉害了、、、
发表于 2018-10-17 00:02:22 | 显示全部楼层
竟然还能用人脸识别 好强
发表于 2018-10-18 10:14:20 | 显示全部楼层
谢谢分享 ~
发表于 2018-10-18 12:09:36 | 显示全部楼层
学习一下
E5-2650L-V2+华南X79+16GB*2
发表于 2018-10-18 16:10:33 | 显示全部楼层
学习学习,谢谢
严重灌水用户
发表于 2018-10-22 16:32:48 | 显示全部楼层
阿萨德海索后啊 我及打击私  阿萨德加上就嗲松紧带
发表于 2018-10-26 21:32:12 | 显示全部楼层
L大,求助下,以下是报错
注册人脸服务
2018-10-26T13:27:35.799877641Z 2018-10-26 13:27:35 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=persistent_notification, service=create, service_data=title=百度人脸识别, message=人脸数据注册失败>
查询人脸数据服务
2018-10-26T13:25:42.671184596Z Exception in thread Thread-12:
2018-10-26T13:25:42.671439238Z Traceback (most recent call last):
2018-10-26T13:25:42.671539141Z   File "/usr/local/lib/python3.6/threading.py", line 916, in _bootstrap_inner
2018-10-26T13:25:42.671628148Z     self.run()
2018-10-26T13:25:42.671704473Z   File "/usr/local/lib/python3.6/threading.py", line 864, in run
2018-10-26T13:25:42.671797674Z     self._target(*self._args, **self._kwargs)
2018-10-26T13:25:42.671880565Z   File "/config/custom_components/image_processing/baidu_face_indentify.py", line 205, in userinfo
2018-10-26T13:25:42.672116729Z     if resultjson['result_num'] == 0:
2018-10-26T13:25:42.672258421Z KeyError: 'result_num'
2018-10-26T13:25:42.672367368Z
人脸检测【颜值】服务
2018-10-26T13:21:39.733945529Z 2018-10-26 13:21:39 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_executed[L]>
2018-10-26T13:21:40.263815183Z Exception in thread Thread-11:
2018-10-26T13:21:40.446182522Z Traceback (most recent call last):
2018-10-26T13:21:40.446446691Z   File "/usr/local/lib/python3.6/threading.py", line 916, in _bootstrap_inner
2018-10-26T13:21:40.446581431Z     self.run()
2018-10-26T13:21:40.446660522Z   File "/usr/local/lib/python3.6/threading.py", line 864, in run
2018-10-26T13:21:40.446749307Z     self._target(*self._args, **self._kwargs)
2018-10-26T13:21:40.446830744Z   File "/config/custom_components/image_processing/baidu_face_indentify.py", line 277, in detect
2018-10-26T13:21:40.447038227Z     if resultjson['result_num'] == 0:
2018-10-26T13:21:40.447148205Z KeyError: 'result_num'
2018-10-26T13:21:40.447247210Z
发表于 2018-10-31 11:32:06 | 显示全部楼层
666学习了
GMT+8, 2026-1-15 03:24 , Processed in 1.790299 second(s), 12 queries , MemCached On.
