查看: 3903|回复: 8
[技术探讨] 想用群晖玩frigate,请问这样的配置可以么?
发表于 2024-3-20 10:28:11 | 显示全部楼层 |阅读模式
群晖信息.png 白群晖,尝试了安装,安装不上,dsm7.2系统。如果不行,请问用什么配置比较好?
还有一台freenas 在,配置如下:
发表于 2024-3-20 10:31:42 | 显示全部楼层
黑裙按这个配置成功链接
发表于 2024-3-20 10:39:54 | 显示全部楼层
ARM盒子都能玩了,利用NPU还蛮快
 楼主| 发表于 2024-3-20 10:48:13 | 显示全部楼层
hcr-io-blakeblackshear-frigate-1
date        stream        content
2024/03/20 10:44:48        stdout        s6-rc: info: service s6rc-oneshot-runner successfully stopped
2024/03/20 10:44:48        stdout        s6-rc: info: service s6rc-oneshot-runner: stopping
2024/03/20 10:44:48        stdout        s6-rc: info: service fix-attrs successfully stopped
2024/03/20 10:44:48        stdout        s6-rc: info: service fix-attrs: stopping
2024/03/20 10:44:48        stdout        s6-rc: info: service legacy-cont-init successfully stopped
2024/03/20 10:44:48        stdout        s6-rc: info: service s6rc-fdholder successfully stopped
2024/03/20 10:44:48        stdout        s6-rc: info: service legacy-cont-init: stopping
2024/03/20 10:44:48        stdout        s6-rc: info: service log-prepare successfully stopped
2024/03/20 10:44:48        stdout        s6-rc: info: service s6rc-fdholder: stopping
2024/03/20 10:44:48        stdout        s6-rc: info: service log-prepare: stopping
2024/03/20 10:44:48        stdout        s6-rc: info: service go2rtc-log successfully stopped
2024/03/20 10:44:48        stdout        s6-rc: info: service frigate-log successfully stopped
2024/03/20 10:44:48        stdout        s6-rc: info: service go2rtc-log: stopping
2024/03/20 10:44:48        stdout        s6-rc: info: service go2rtc successfully stopped
2024/03/20 10:44:48        stdout        s6-rc: info: service nginx-log successfully stopped
2024/03/20 10:44:48        stdout        2024-03-20 02:44:48.554693147  [INFO] The go2rtc service exited with code 256 (by signal 15)
2024/03/20 10:44:48        stdout        s6-rc: info: service frigate-log: stopping
2024/03/20 10:44:48        stdout        s6-rc: info: service go2rtc: stopping
2024/03/20 10:44:48        stdout        s6-rc: info: service frigate successfully stopped
2024/03/20 10:44:48        stdout        s6-rc: info: service frigate: stopping
2024/03/20 10:44:48        stdout        s6-rc: info: service nginx-log: stopping
2024/03/20 10:44:48        stdout        s6-rc: info: service nginx successfully stopped
2024/03/20 10:44:48        stdout        s6-rc: info: service go2rtc-healthcheck successfully stopped
2024/03/20 10:44:48        stdout        2024-03-20 02:44:48.502403563  [INFO] Service NGINX exited with code 256 (by signal 15)
2024/03/20 10:44:48        stdout        2024-03-20 02:44:48.498471945  [INFO] The go2rtc-healthcheck service exited with code 256 (by signal 15)
2024/03/20 10:44:48        stdout        s6-rc: info: service go2rtc-healthcheck: stopping
2024/03/20 10:44:48        stdout        s6-rc: info: service nginx: stopping
2024/03/20 10:44:48        stdout        s6-rc: info: service legacy-services successfully stopped
2024/03/20 10:44:48        stdout        s6-rc: info: service legacy-services: stopping
2024/03/20 10:44:48        stdout        s6-rc: info: service legacy-services successfully started
2024/03/20 10:44:48        stdout        2024-03-20 02:44:48.433930218  [INFO] Service Frigate exited with code 1 (by signal 0)
2024/03/20 10:44:48        stdout        s6-rc: info: service legacy-services: starting
2024/03/20 10:44:48        stdout        2024-03-20 02:44:48.423685304  [INFO] Starting NGINX...
2024/03/20 10:44:48        stdout        2024-03-20 02:44:48.420601531  [ERROR] Frigate config file not found
2024/03/20 10:44:48        stdout        2024-03-20 02:44:48.420063244  [INFO] Preparing Frigate...
2024/03/20 10:44:48        stdout        s6-rc: info: service nginx successfully started
2024/03/20 10:44:48        stdout        2024-03-20 02:44:48.403708983  [INFO] Preparing new go2rtc config...
2024/03/20 10:44:48        stdout        s6-rc: info: service nginx: starting
2024/03/20 10:44:48        stdout        s6-rc: info: service frigate successfully started
2024/03/20 10:44:48        stdout        s6-rc: info: service go2rtc-healthcheck successfully started
2024/03/20 10:44:48        stdout        s6-rc: info: service frigate: starting
2024/03/20 10:44:48        stdout        s6-rc: info: service go2rtc-healthcheck: starting
2024/03/20 10:44:48        stdout        s6-rc: info: service go2rtc successfully started
2024/03/20 10:44:48        stdout        s6-rc: info: service nginx-log successfully started
2024/03/20 10:44:48        stdout        s6-rc: info: service frigate-log successfully started
2024/03/20 10:44:48        stdout        s6-rc: info: service go2rtc: starting
2024/03/20 10:44:48        stdout        s6-rc: info: service go2rtc-log successfully started
2024/03/20 10:44:48        stdout        s6-rc: info: service frigate-log: starting
2024/03/20 10:44:48        stdout        s6-rc: info: service go2rtc-log: starting
2024/03/20 10:44:48        stdout        s6-rc: info: service nginx-log: starting
2024/03/20 10:44:48        stdout        s6-rc: info: service log-prepare successfully started
2024/03/20 10:44:48        stdout        s6-rc: info: service log-prepare: starting
2024/03/20 10:44:48        stdout        s6-rc: info: service legacy-cont-init successfully started
2024/03/20 10:44:48        stdout        s6-rc: info: service legacy-cont-init: starting
2024/03/20 10:44:48        stdout        s6-rc: info: service fix-attrs successfully started
2024/03/20 10:44:48        stdout        s6-rc: info: service s6rc-fdholder successfully started
2024/03/20 10:44:48        stdout        s6-rc: info: service fix-attrs: starting
2024/03/20 10:44:48        stdout        s6-rc: info: service s6rc-oneshot-runner successfully started
2024/03/20 10:44:48        stdout        s6-rc: info: service s6rc-oneshot-runner: starting
2024/03/20 10:44:48        stdout        s6-rc: info: service s6rc-fdholder: starting
2024/03/20 10:44:40        stdout        s6-rc: info: service s6rc-fdholder successfully stopped
2024/03/20 10:44:40        stdout        s6-rc: info: service s6rc-oneshot-runner successfully stopped
2024/03/20 10:44:40        stdout        s6-rc: info: service s6rc-oneshot-runner: stopping
2024/03/20 10:44:40        stdout        s6-rc: info: service fix-attrs successfully stopped
2024/03/20 10:44:40        stdout        s6-rc: info: service fix-attrs: stopping
2024/03/20 10:44:40        stdout        s6-rc: info: service legacy-cont-init successfully stopped
2024/03/20 10:44:40        stdout        s6-rc: info: service legacy-cont-init: stopping
2024/03/20 10:44:40        stdout        s6-rc: info: service log-prepare successfully stopped
2024/03/20 10:44:40        stdout        s6-rc: info: service s6rc-fdholder: stopping
2024/03/20 10:44:40        stdout        s6-rc: info: service log-prepare: stopping
2024/03/20 10:44:40        stdout        s6-rc: info: service go2rtc-log successfully stopped
2024/03/20 10:44:40        stdout        s6-rc: info: service frigate-log successfully stopped
2024/03/20 10:44:40        stdout        s6-rc: info: service go2rtc-log: stopping
2024/03/20 10:44:40        stdout        s6-rc: info: service go2rtc successfully stopped
2024/03/20 10:44:40        stdout        2024-03-20 02:44:40.877565040  [INFO] The go2rtc service exited with code 256 (by signal 15)
2024/03/20 10:44:40        stdout        s6-rc: info: service nginx-log successfully stopped
2024/03/20 10:44:40        stdout        s6-rc: info: service frigate-log: stopping
2024/03/20 10:44:40        stdout        s6-rc: info: service go2rtc: stopping
2024/03/20 10:44:40        stdout        s6-rc: info: service frigate successfully stopped
2024/03/20 10:44:40        stdout        s6-rc: info: service go2rtc-healthcheck successfully stopped
2024/03/20 10:44:40        stdout        s6-rc: info: service frigate: stopping
2024/03/20 10:44:40        stdout        s6-rc: info: service nginx-log: stopping
2024/03/20 10:44:40        stdout        s6-rc: info: service nginx successfully stopped
2024/03/20 10:44:40        stdout        2024-03-20 02:44:40.729128031  [INFO] Service NGINX exited with code 256 (by signal 15)
2024/03/20 10:44:40        stdout        2024-03-20 02:44:40.726909213  [INFO] The go2rtc-healthcheck service exited with code 256 (by signal 15)
2024/03/20 10:44:40        stdout        s6-rc: info: service go2rtc-healthcheck: stopping
2024/03/20 10:44:40        stdout        s6-rc: info: service nginx: stopping
2024/03/20 10:44:40        stdout        s6-rc: info: service legacy-services successfully stopped
2024/03/20 10:44:40        stdout        s6-rc: info: service legacy-services: stopping
2024/03/20 10:44:40        stdout        s6-rc: info: service legacy-services successfully started
2024/03/20 10:44:40        stdout        s6-rc: info: service legacy-services: starting
2024/03/20 10:44:40        stdout        s6-rc: info: service nginx successfully started
2024/03/20 10:44:40        stdout        2024-03-20 02:44:40.595198214  [INFO] Service Frigate exited with code 1 (by signal 0)
2024/03/20 10:44:40        stdout        2024-03-20 02:44:40.593533173  [INFO] Starting NGINX...
2024/03/20 10:44:40        stdout        s6-rc: info: service nginx: starting
2024/03/20 10:44:40        stdout        s6-rc: info: service frigate successfully started
2024/03/20 10:44:40        stdout        s6-rc: info: service go2rtc-healthcheck successfully started
2024/03/20 10:44:40        stdout        s6-rc: info: service nginx-log successfully started
2024/03/20 10:44:40        stdout        2024-03-20 02:44:40.435745665  [ERROR] Frigate config file not found
2024/03/20 10:44:40        stdout        2024-03-20 02:44:40.417957623  [INFO] Preparing Frigate...
2024/03/20 10:44:40        stdout        s6-rc: info: service frigate: starting
2024/03/20 10:44:40        stdout        s6-rc: info: service frigate-log successfully started
2024/03/20 10:44:40        stdout        s6-rc: info: service go2rtc-healthcheck: starting
2024/03/20 10:44:40        stdout        s6-rc: info: service go2rtc successfully started
2024/03/20 10:44:40        stdout        s6-rc: info: service go2rtc: starting
2024/03/20 10:44:40        stdout        s6-rc: info: service go2rtc-log successfully started
2024/03/20 10:44:40        stdout        s6-rc: info: service frigate-log: starting
2024/03/20 10:44:40        stdout        s6-rc: info: service go2rtc-log: starting
2024/03/20 10:44:40        stdout        s6-rc: info: service nginx-log: starting
2024/03/20 10:44:40        stdout        s6-rc: info: service log-prepare successfully started
2024/03/20 10:44:40        stdout        s6-rc: info: service log-prepare: starting
2024/03/20 10:44:40        stdout        s6-rc: info: service legacy-cont-init successfully started
2024/03/20 10:44:40        stdout        s6-rc: info: service legacy-cont-init: starting
2024/03/20 10:44:40        stdout        s6-rc: info: service fix-attrs successfully started
2024/03/20 10:44:40        stdout        s6-rc: info: service fix-attrs: starting
2024/03/20 10:44:40        stdout        s6-rc: info: service s6rc-oneshot-runner successfully started
2024/03/20 10:44:40        stdout        s6-rc: info: service s6rc-fdholder successfully started
2024/03/20 10:44:40        stdout        s6-rc: info: service s6rc-oneshot-runner: starting
2024/03/20 10:44:40        stdout        s6-rc: info: service s6rc-fdholder: starting
是白群晖 ,docker运行不断重启
发表于 2024-3-20 10:53:17 | 显示全部楼层
twfjcn 发表于 2024-3-20 10:39
ARM盒子都能玩了,利用NPU还蛮快
你用的什么盒子?
 楼主| 发表于 2024-3-20 11:05:32 | 显示全部楼层
zmqo1234 发表于 2024-3-20 10:31
黑裙按这个配置成功链接
感谢,配置成功了
发表于 2024-3-20 14:02:16 | 显示全部楼层
三尺寒 发表于 2024-3-20 10:53
你用的什么盒子?
git上面就有rk模型
发表于 2024-3-20 18:45:04 | 显示全部楼层
twfjcn 发表于 2024-3-20 14:02
git上面就有rk模型
我的是黑豹X2,不会编译系统,也没找到支持npu的armbian
发表于 2024-3-20 19:43:29 | 显示全部楼层
你这不是运行不起来,是没有正确的配置文件。。。。日志里稍微看一下知道了
GMT+8, 2026-1-3 03:09 , Processed in 1.314493 second(s), 12 queries , MemCached On.
