查看: 2341|回复: 1
HB崩溃 啥情况
我就是六神
活跃会员教程狂人灌水之王
发表于 2018-1-16 01:34:43 | 显示全部楼层 |阅读模式
[2018-1-16 01:33:27] Loaded plugin: homebridge-broadlink-rm
[2018-1-16 01:33:27] Registering platform 'homebridge-broadlink-rm.BroadlinkRM'
[2018-1-16 01:33:27] ---
[2018-1-16 01:33:28] Loaded plugin: homebridge-broadlink-s1c
[2018-1-16 01:33:28] Registering platform 'homebridge-broadlink-s1c.broadlinkS1C'
[2018-1-16 01:33:28] ---
[2018-1-16 01:33:28] Loaded plugin: homebridge-config-ui
[2018-1-16 01:33:28] Registering platform 'homebridge-config-ui.config'
[2018-1-16 01:33:29] Loaded plugin: homebridge-homeassistant
[2018-1-16 01:33:29] Registering platform 'homebridge-homeassistant.HomeAssistant'
[2018-1-16 01:33:29] ---
[2018-1-16 01:33:29] Loaded config.json with 0 accessories and 4 platforms.
[2018-1-16 01:33:29] Loading 4 platforms...
[2018-1-16 01:33:29] [HomeAssistant] Initializing HomeAssistant platform...
[2018-1-16 01:33:29] [HomeAssistant] Fetching HomeAssistant devices.
[2018-1-16 01:33:29] [Visible HB] Initializing config platform...
[2018-1-16 01:33:33] [S1C] Initializing broadlinkS1C platform...
[2018-1-16 01:33:33] [S1C] Searching for S1C device... Please Wait!
/usr/lib/node_modules/homebridge/lib/api.js:122
      throw new Error("The requested platform '" + name + "' was not registered by any plugin.");
Error: The requested platform 'XiaoMiAcPartner' was not registered by any plugin.
    at API.platform (/usr/lib/node_modules/homebridge/lib/api.js:122:13)
    at Server._loadPlatforms (/usr/lib/node_modules/homebridge/lib/server.js:294:45)
    at Server.run (/usr/lib/node_modules/homebridge/lib/server.js:85:36)
    at module.exports (/usr/lib/node_modules/homebridge/lib/cli.js:40:10)
    at Object.<anonymous> (/usr/lib/node_modules/homebridge/bin/homebridge:17:22)
    at Module._compile (module.js:635:30)
    at Object.Module._extensions..js (module.js:646:10)
    at Module.load (module.js:554:32)
    at tryModuleLoad (module.js:497:12)
    at Function.Module._load (module.js:489:3)
*** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** Please fix your application to use the native API of Avahi!
*** WARNING *** For more information see <[url]http://0pointer.de/avahi-compat?s=libdns_sd&e=node>[/url]
*** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** For more information see <[url]http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister>[/url]
Withdrawing address record for 169.254.106.188 on hassio.
Withdrawing address record for 172.30.32.1 on hassio.
Withdrawing address record for fe80::e26f:ca44:e63:c5a8 on wlan0.
Withdrawing address record for 192.168.31.243 on wlan0.
Host name conflict, retrying with unknown-18
Registering new address record for fe80::9f94:3c10:cdf1:91db on hassio.*.
Registering new address record for 169.254.106.188 on hassio.*.
Registering new address record for 172.30.32.1 on hassio.*.
Registering new address record for fe80::e26f:ca44:e63:c5a8 on wlan0.*.
Registering new address record for 192.168.31.243 on wlan0.*.
[2018-1-16 01:33:43] Loaded plugin: homebridge-broadlink-rm
[2018-1-16 01:33:43] Registering platform 'homebridge-broadlink-rm.BroadlinkRM'
[2018-1-16 01:33:43] ---
[2018-1-16 01:33:43] Loaded plugin: homebridge-broadlink-s1c
[2018-1-16 01:33:43] Registering platform 'homebridge-broadlink-s1c.broadlinkS1C'
[2018-1-16 01:33:43] Loaded plugin: homebridge-config-ui
[2018-1-16 01:33:43] Registering platform 'homebridge-config-ui.config'
[2018-1-16 01:33:45] Loaded plugin: homebridge-homeassistant
[2018-1-16 01:33:45] Registering platform 'homebridge-homeassistant.HomeAssistant'
[2018-1-16 01:33:45] ---
[2018-1-16 01:33:45] Loaded config.json with 0 accessories and 4 platforms.
[2018-1-16 01:33:45] Loading 4 platforms...
[2018-1-16 01:33:45] [HomeAssistant] Initializing HomeAssistant platform...
[2018-1-16 01:33:45] [HomeAssistant] Fetching HomeAssistant devices.
[2018-1-16 01:33:45] [Visible HB] Initializing config platform...
[2018-1-16 01:33:48] [S1C] Initializing broadlinkS1C platform...
[2018-1-16 01:33:48] [S1C] Searching for S1C device... Please Wait!
我就是六神
活跃会员教程狂人灌水之王
 楼主| 发表于 2018-1-16 01:45:00 | 显示全部楼层
原来是 "platform": "XiaoMiAcPartner", 滴问题~~删了
GMT+8, 2025-9-3 07:19 , Processed in 1.165856 second(s), 7 queries , MemCached On.
