查看: 6854|回复: 13
[技术探讨] 升级HA后,xiaomi miot auto 显示未加载,怎么办?
发表于 2024-3-11 20:41:59 | 显示全部楼层 |阅读模式
之前xiaomi miot auto显示有更新,但是更新到50%就出错,不能更新。今天升级了个HA2024.3.0版本后,重新启动xiaomi miot auto就显示未加载,怎么都不能加载了,求助求助!!! 360截图20240312122731459.jpg
[backcolor=var(--mdc-theme-surface,#fff)][color=var(--mdc-dialog-content-ink-color,rgba(0,0,0,.6))]日志: homeassistant.setup
来源: setup.py:296
首次发生: 12:43:30 (1 全部发生)
上次记录: 12:43:30
Setup failed for custom integration 'xiaomi_miot': Unable to import component: No module named 'imp'Traceback (most recent call last):  File "/usr/src/homeassistant/homeassistant/setup.py", line 296, in _async_setup_component    component = await integration.async_get_component()                ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^  File "/usr/src/homeassistant/homeassistant/loader.py", line 894, in async_get_component    comp = self.get_component()           ^^^^^^^^^^^^^^^^^^^^  File "/usr/src/homeassistant/homeassistant/loader.py", line 921, in get_component    ComponentProtocol, importlib.import_module(self.pkg_path)                       ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^  File "/usr/local/lib/python3.12/importlib/__init__.py", line 90, in import_module    return _bootstrap._gcd_import(name[level:], package, level)           ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^  File "<frozen importlib._bootstrap>", line 1387, in _gcd_import  File "<frozen importlib._bootstrap>", line 1360, in _find_and_load  File "<frozen importlib._bootstrap>", line 1331, in _find_and_load_unlocked  File "<frozen importlib._bootstrap>", line 935, in _load_unlocked  File "<frozen importlib._bootstrap_external>", line 995, in exec_module  File "<frozen importlib._bootstrap>", line 488, in _call_with_frames_removed  File "/config/custom_components/xiaomi_miot/__init__.py", line 32, in <module>    from miio import (  File "/usr/local/lib/python3.12/site-packages/miio/__init__.py", line 12, in <module>    from miio.device import Device, DeviceStatus  # isort: skip    ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^  File "/usr/local/lib/python3.12/site-packages/miio/device.py", line 13, in <module>    from .miioprotocol import MiIOProtocol  File "/usr/local/lib/python3.12/site-packages/miio/miioprotocol.py", line 13, in <module>    import construct  File "/usr/local/lib/python3.12/site-packages/construct/__init__.py", line 22, in <module>    from construct.core import *  File "/usr/local/lib/python3.12/site-packages/construct/core.py", line 3, in <module>    import struct, io, binascii, itertools, collections, pickle, sys, os, tempfile, hashlib, importlib, impModuleNotFoundError: No module named 'imp'
jjcs 手机认证
发表于 2024-3-11 20:58:00 | 显示全部楼层
没图,没日志,等于僵尸帖
 楼主| 发表于 2024-3-12 12:29:59 | 显示全部楼层
已经上图了,请帮忙看看怎么解决?
发表于 2024-3-12 12:53:59 | 显示全部楼层
先更新 xiaomi_miot,更到最新版
 楼主| 发表于 2024-3-20 10:00:25 | 显示全部楼层
现在就是更新不了,更新到50%就出错
发表于 2024-3-20 10:19:00 来自手机 | 显示全部楼层
我也你的情况一样,升级HA之后就未加载
发表于 2024-3-20 12:49:58 | 显示全部楼层
lghhome 发表于 2024-3-20 10:00
现在就是更新不了,更新到50%就出错
先手动下载覆盖呗
 楼主| 发表于 2024-3-20 13:15:44 | 显示全部楼层
Necroneco 发表于 2024-3-20 12:49
先手动下载覆盖呗
大神请教教怎么做吧?
发表于 2024-3-20 15:26:12 | 显示全部楼层
lghhome 发表于 2024-3-20 13:15
大神请教教怎么做吧?
在集成里把miot删除,去custom_components文件夹删除mito文件夹,
去HACS里下载miot,重启,集成里去配置。
发表于 2024-3-21 10:09:30 | 显示全部楼层
大神请教教怎么做吧?
https://github.com/al-one/hass-x ... .17/xiaomi_miot.zip
直接下载代码,覆盖配置目录 custom_components/ 里面的同名文件夹
参与人数 1金钱 +1 收起 理由
gangqiao + 1 感谢楼主分享!
GMT+8, 2026-1-15 13:11 , Processed in 0.412917 second(s), 15 queries , MemCached On.
