查看: 2287|回复: 1
[求助] 小爱音响一代黑板刷机怎么弄啊?
5 金钱 回复本帖可获得 1 金钱奖励! 每人限 1 次
发表于 2024-3-9 21:05:16 | 显示全部楼层 |阅读模式
手里的是黑板一代,ttl下只能进这个模式,不像绿板可以进uboot模式传固件刷机,这个只能进这个安全模式,命令也不一样。格dota分区也不允许,不知道怎么下手了,请教下各位大神刷机途径。
跑马图如下:
root@(none):/# ubiformat /dev/mtd6þGXL:BL1:9ac50e:bb16dc;FEAT:ADFC318C:0OC:3;RCY:0;EMMC:800;NAND:0;READ:0;0.0;CHK:0;
TE: 28002
BL2 Built : 18:43:23, Sep  8 2017.
gxl g5190619 - xiaobo.gu@droid12
rn5t618_power_init
Board ID = 0
CPU clk: 1200MHz
DQS calibration enabled
DDR scramble enabled
DDR3 chl: Rank0 @ 792MHz
af_vref ddr_training_win: rank: 0 23 00 52 47 12 7c 1e 00 4f 4d 1d 7d 1e 00 4e 4e 18 85 23 00 56 4a 13 82 612  rank: 1 34 00 52 0c 12 7c 34 00 4f 0c 1d 7d 34 00 4e 13 18 85 35 00 56 0e 13 82 612
af_vref ddr_bist_window:  rank: 0 21 00 42 35 1d 60 1c 08 41 39 2c 52 1c 04 41 3a 22 59 21 00 42 37 21 5b 612   - PASS
Rank0: 256MB(auto)-2T-11
AddrBus test pass!
NAND init
read start page:00000000
page :00000500
succeed in getting one bbt block!
page :00000540
page :00000580
page :000005c0
select bbt block:00000014
select page:00000001
select page:00000000
bbt status: 00000000000000000000000000000000
Load fip header from NAND, src: 0x00020000, des: 0x01400000, size: 0x00004000
read start page:00000041
New fip structure!
Load bl30 from NAND, src: 0x00024000, des: 0x01100000, size: 0x0000d600
read start page:00000049
Load bl31 from NAND, src: 0x00034000, des: 0x05100000, size: 0x00017400
read start page:00000069
Load bl33 from NAND, src: 0x0004c000, des: 0x01000000, size: 0x00081c00
read start page:00000099
NOTICE:  BL3-1: v1.0(debug):2da3090
NOTICE:  BL3-1: Built : 16:05:52, Jan 19 2017
aml log : bl31 normal boot !
mpu_config_enablek
[Image: gxl_v1.1.3170-f392be9 2017-01-04 10:51:57 yun.cai@droid06]
OPS=0xf4
24 ef 88 20 21 70 b 5c fb 51 c0 61 [0.473690 Inits done]
secure task start!
high task start!
low task start!
INFO:    BL3-1: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL3-1: Preparing for EL3 exit to normal world
INFO:    BL3-1: Next image address = 0x1000000
INFO:    BL3-1: Next image spsr = 0x3c9
U-Boot 2015.01-g85a2387-dirty (Sep 19 2017 - 19:00:12)
DRAM:  256 MiB
Relocation Offset is: 0ef38000
register usb cfg[0][1] = 000000000ffa1290
NAND:  nand id: 44 218
256MiB, SLC, page size: 2048, OOB size: 64
Creating 1 MTD partitions on "A revision NAND 2Gib MT29F2G08-A":
0x000000000000-0x000000200000 : "nandboot"
nand id: 44 218
Creating 5 MTD partitions on "A revision NAND 2Gib MT29F2G08-A":
0x000000800000-0x000001800000 : "boot0"
0x000001800000-0x000002800000 : "boot1"
0x000002800000-0x000008800000 : "system0"
0x000008800000-0x00000e800000 : "system1"
0x00000e800000-0x000010000000 : "data"
MMC:   In:    serial
Out:   serial
Err:   serial
[burnup]Rd:Up sz 0x800 to align 0x1000
[burnup]run cmd[store  read boot1 0x1000000  0x0  0x1000]
[burnup]Read end.
[burnup]run cmd[store  read boot1 0x18b2800  0x8b2800  0x8000]
[burnup]Read end.
amlkey_init() enter!
amlkey_init() storagekey_info.buffer=0000000005080000, storagekey_info.size = 7ffc!
[KM]Error:f[key_unify_init]L177evice[1] init failed, err=-22
InUsbBurn
noSof
Hit Enter or space or Ctrl+C key to stop autoboot -- :  0
HAVE SN Code ...
Saving Environment to aml-storage...
[burnup]run cmd[store  read boot1 0x1080000  0x0  0x100000]
[burnup]Read end.
[burnup]Rd:Up sz 0x7ba5be to align 0x1000
[burnup]run cmd[store  read boot1 0x1180000  0x100000  0x7bb000]
[burnup]Read end.
ee_gate_off ...
## Booting Android Image at 0x01080000 ...
load dtb from 0x1000000 ......
   Loading Kernel Image(COMP_NONE) ... OK
   kernel loaded at 0x01080000, end = 0x017ecc58
[rsvmem] no check for rsvmem, should check int kernel
   Loading Ramdisk to 0bde1000, end 0bf25ed1 ... OK
   Loading Device Tree to 000000000bdd6000, end 000000000bde0dbd ... OK
Starting kernel ...
uboot time: 1419311 us
[    0.115569@0] genirq: Setting trigger mode 8 for irq 241 failed (gic_set_type+0x0/0xb4)
[    0.118039@0] genirq: Setting trigger mode 8 for irq 242 failed (gic_set_type+0x0/0xb4)
[    0.126246@0] genirq: Setting trigger mode 8 for irq 241 failed (gic_set_type+0x0/0xb4)
[    0.134137@0] genirq: Setting trigger mode 8 for irq 242 failed (gic_set_type+0x0/0xb4)
domain-0 init dvfs: 4
[    0.289625@0] nand: Could not find valid ONFI parameter page; aborting
[    0.297517@0] nand: Could not find valid ONFI parameter page; aborting
[BL31]: tee size: 0
[BL31]: tee size: 0
[BL31]: tee size: 0
[BL31]: tee size: 0
WARNING: Unimplemented Sip Call: 0x82000036
[ get key is 0x00 , curr_boot is boot1
Booting from boot1
^C^CUBI device number 0, total 768 LEBs (97517568 bytes, 93.0 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
/dev/mtd4 is ready now.
^C^C^C^C^C^C^C^C^CPress the [f] key and hit [enter] to enter failsafe mode
Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
^C^C^C^C^C^C^CPlease press Enter to activate this console.
MSTC_R_SystemInitDone
BusyBox v1.23.2 (2017-04-27 11:27:43 CST) built-in shell (ash)
  _______                     ________        __
|       |.-----.-----.-----.|  |  |  |.----.|  |_
|   -   ||  _  |  -__|     ||  |  |  ||   _||   _|
|_______||   __|_____|__|__||________||__|  |____|
          |__| W I R E L E S S   F R E E D O M
CHAOS CALMER (Chaos Calmer, unknown)
  * 1 1/2 oz Gin            Shake with a glassful
  * 1/4 oz Triple Sec       of broken ice and pour
  * 3/4 oz Lime Juice       unstrained into a goblet.
  * 1 1/2 oz Orange Juice
  * 1 tsp. Grenadine Syrup
root@(none):/# ubiformat /dev/mtd5
ubiformat: error!: please, first detach mtd5 (/dev/mtd5) from ubi1
发表于 2025-2-4 18:14:36 | 显示全部楼层
回帖奖励 +1 金钱
同样的问题,求救大佬
GMT+8, 2025-12-18 19:04 , Processed in 0.153528 second(s), 14 queries , MemCached On.
