查看: 2533|回复: 3
[求助] UIOT 设备接入 Z2M 日志报错,求大佬帮忙~
发表于 2024-3-9 14:36:40 | 显示全部楼层 |阅读模式
设备在启动的时候报错,其他功能已经配置了可以正常操作
Failed to configure '0x00158d0006398104', attempt 3 (Error: Bind 0x00158d0006398104/1 genOnOff from '0x00124b0030c3087e/1' failed (AREQ - ZDO - bindRsp after 10000ms) at Object.start (/app/node_modules/zigbee-herdsman/src/utils/waitress.ts:63:23) at /app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:692:28 at processTicksAndRejections (node:internal/process/task_queues:95:5) at Queue.execute (/app/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20) at Endpoint.bind (/app/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:551:13) at Object.bind (/app/node_modules/zigbee-herdsman-converters/src/lib/reporting.ts:43:9) at configure (/app/data/extension/externally-loaded.js:27:9) at Object.configure (/app/node_modules/zigbee-herdsman-converters/src/index.ts:141:25) at Configure.configure (/app/lib/extension/configure.ts:122:13) at EventEmitter.wrappedCallback (/app/lib/eventBus.ts:174:17))
发表于 2024-3-11 14:57:16 | 显示全部楼层
老哥,怎么接入的,买的是哪款Z2M的转换器呢
发表于 2024-3-13 10:39:01 | 显示全部楼层
同求大佬怎么配置的能教教大家么
发表于 2024-8-15 18:18:21 | 显示全部楼层
大佬,怎么接入uiot的zigbee呢
GMT+8, 2025-12-18 10:54 , Processed in 1.120657 second(s), 13 queries , MemCached On.
