查看: 2344|回复: 2
[进阶教程] ESP32读取德力西仪表DT(S)SU6606VCRf型三相电子式电能表数据教程
发表于 2024-3-6 11:10:28 | 显示全部楼层 |阅读模式
网上大多教程为ESP32读取正泰单相电能表的教程,未找到读取ESP32读取德力西仪表DT(S)SU6606VCRf型三相电子式电能表数据的教程,在参考了相关教程并结合实际情况研究后,终于成功实现了ESP32与德力西仪表DT(S)SU6606VCRf型三相电子式电能表的数据通讯,并成功在Homeassistant上显示。先附上成果图:
所用的硬件为:esp32-wroom-32e
软件平台:ESPHome+Home Assistant
电能表型号:德力西仪表DT(S)SU6606VCRf型三相电子式电能表
通讯方式:Modbus RTU 485
YAML文件供参考:
substitutions:
  device_name: meter-delixi #替换成想要的设备名称
  friendly_name: meter_delixi
esphome:
  friendly_name: ${friendly_name}
  area: Asia/Shanghai
esp32:
  board: esp-wrover-kit
  framework:
    type: arduino
# Enable logging
logger:
  level: DEBUG
api:
  encryption:
    key: !secret api_encryption_key
#Web OTA Update Choose ‘firmware.bin’
ota:
  password: !secret ota_password
  on_progress:
    then:
      - logger.log:
          format: "OTA progress %0.1f%%"
          args: ["x"]
# Example configuration
network:
    enable_ipv6: true
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: ${friendly_name}_Hotspot
    password: !secret ap_wifi_password
captive_portal:
web_server:
  port: 80
button:
  - platform: restart
time:
  - platform: sntp
uart:
  rx_pin: 16
  tx_pin: 17
  baud_rate: 9600
  data_bits: 8
  stop_bits: 1
  #parity: even
modbus:
  send_wait_time: 250ms
  uart_id: ${friendly_name}_uart
modbus_controller:
  - id: ${friendly_name}_modbus_controller
    modbus_id: ${friendly_name}_modbus
    address: 0x01 #设备地址码(一般是1根据实际情况填)
    command_throttle: 200ms
    setup_priority: -10
    update_interval: 10s
  - platform: uptime
  - platform: internal_temperature
  - platform: wifi_signal # Reports the WiFi signal strength/RSSI in dB
    update_interval: 60s
    entity_category: "diagnostic"
  - platform: copy # Reports the WiFi signal strength in %
    source_id: ${friendly_name}_wifi_signal_db
    filters:
      - lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
    unit_of_measurement: "PCT"
#delixi_dtsu6606vcrf 电表地址
#电压
  - platform: modbus_controller
    modbus_controller_id: ${friendly_name}_modbus_controller
    address: 0x0300
    register_count: 1
    unit_of_measurement: "V"
    register_type: holding
    value_type: S_WORD
    accuracy_decimals: 2
    device_class: voltage
    filters:
     - multiply: 0.1
    address: 0x0301
    register_count: 1
    value_type: S_WORD
    filters:
     - multiply: 0.1
    address: 0x0302
    register_count: 1
    value_type: S_WORD
    filters:
     - multiply: 0.1
#电流
    address: 0x0303
    register_count: 1
    unit_of_measurement: "A"
    value_type: S_WORD
    accuracy_decimals: 3
    device_class: current
    filters:
      - multiply: 0.01
    address: 0x0304
    register_count: 1
    value_type: S_WORD
    filters:
      - multiply: 0.01
    address: 0x0305
    register_count: 1
    value_type: S_WORD
    filters:
      - multiply: 0.01
#有功功率
    address: 0x0306
    register_count: 1
    unit_of_measurement: "kW"
    value_type: S_WORD
    device_class: power
    filters:
      - multiply: 0.01
    address: 0x0307
    register_count: 1
    value_type: S_WORD
    device_class: power
    filters:
      - multiply: 0.01
    address: 0x0308
    register_count: 1
    value_type: S_WORD
    device_class: power
    filters:
      - multiply: 0.01
    address: 0x0309
    register_count: 1
    value_type: S_WORD
    device_class: power
    filters:
      - multiply: 0.01
#无功功率
    address: 0x030A
    register_count: 1
    unit_of_measurement: "kVar"
    value_type: S_WORD
    device_class: power
    filters:
      - multiply: 0.01
    address: 0x030B
    register_count: 1
    value_type: S_WORD
    device_class: power
    filters:
      - multiply: 0.01
    address: 0x030C
    register_count: 1
    value_type: S_WORD
    device_class: power
    filters:
      - multiply: 0.01
    address: 0x030D
    register_count: 1
    value_type: S_WORD
    device_class: power
    filters:
      - multiply: 0.01
#视在功率
    address: 0x030E
    register_count: 1
    unit_of_measurement: "kVA"
    value_type: S_WORD
    device_class: power
    filters:
      - multiply: 0.01
    address: 0x030F
    register_count: 1
    value_type: S_WORD
    device_class: power
    filters:
      - multiply: 0.01
    address: 0x0310
    register_count: 1
    value_type: S_WORD
    device_class: power
    filters:
      - multiply: 0.01
    address: 0x0311
    register_count: 1
    value_type: S_WORD
    device_class: power
    filters:
      - multiply: 0.01
#功率因数
    address: 0x0312
    register_count: 1
    unit_of_measurement: "cosphi"
    value_type: S_WORD
    device_class: power_factor
    filters:
      - multiply: 0.001
    address: 0x0313
    register_count: 1
    value_type: S_WORD
    filters:
      - multiply: 0.001
    address: 0x0314
    register_count: 1
    value_type: S_WORD
    filters:
      - multiply: 0.001
    address: 0x0315
    register_count: 1
    value_type: S_WORD
    filters:
      - multiply: 0.001
#频率
    address: 0x0316
    register_count: 1
    unit_of_measurement: "Hz"
    value_type: S_WORD
    filters:
      - multiply: 0.01
#电能量
#当前组合有功总电能
    address: 0x0000
    register_count: 2
    unit_of_measurement: "kWh"
    value_type: S_DWORD
    device_class: energy
    state_class: total_increasing
    filters:
      - multiply: 0.01
      - median:
          window_size: 3
          send_every: 3
#当前正向有功总电能
    address: 0x000A
    register_count: 2
    value_type: S_DWORD
    filters:
      - multiply: 0.01
      - median:
          window_size: 3
          send_every: 3
#当前反向有功总电能
    address: 0x0014
    register_count: 2
    value_type: S_DWORD
    filters:
      - multiply: 0.01
      - median:
          window_size: 3
          send_every: 3
#当前无功总电能
    address: 0x0186
    register_count: 2
    value_type: S_DWORD
    filters:
      - multiply: 0.01
      - median:
          window_size: 3
          send_every: 3
interval:
  - interval: 5min
    then:
      - if:
          condition:
            or:
              - not: wifi.connected
              - lambda: 'return id(${friendly_name}_wifi_signal_db).state < -70;'
          then:
            - logger.log: WiFi signal is too weak or not connected. Reconnecting...
            - wifi.disable
            - delay: 5s
            - wifi.enable
参与人数 1金钱 +16 收起 理由
sorrypqa + 16 大神666!
发表于 2024-3-6 11:21:14 | 显示全部楼层
学习学习!谢谢分享!
发表于 2024-3-6 12:46:57 | 显示全部楼层
有没单相的
GMT+8, 2026-1-15 10:15 , Processed in 1.654512 second(s), 16 queries , MemCached On.
