查看: 1788|回复: 4
[求助] 请大佬帮忙看下,安装HA失败了
发表于 2024-2-25 20:10:28 | 显示全部楼层 |阅读模式
用PVE小主机装HA失败了,没搞明白哪里出问题了,镜像是Releases · home-assistant/operating-system (github.com)上找的 haos_generic-x86-64-11.5.img.xz 主机是极摩客G2
以下是访问8123给的日志,麻烦各位大佬帮忙看下,给个头绪,是没有魔法的问题吗
[10:40:38] INFO: Using udev information from host
[10:40:38] INFO: Starting local supervisor watchdog...
24-02-25 10:40:39 INFO (MainThread) [__main__] Initializing Supervisor setup
24-02-25 18:40:39 INFO (MainThread) [supervisor.bootstrap] Setting up coresys for machine: generic-x86-64
24-02-25 18:40:39 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/amd64-hassio-supervisor with version 2024.02.0
24-02-25 18:40:39 INFO (MainThread) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
24-02-25 18:40:39 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
24-02-25 18:40:39 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-02-25 18:40:39 INFO (MainThread) [__main__] Setting up Supervisor
24-02-25 18:40:40 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
24-02-25 18:40:40 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
24-02-25 18:40:40 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
24-02-25 18:40:40 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
24-02-25 18:40:40 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
24-02-25 18:40:40 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
24-02-25 18:40:40 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
24-02-25 18:40:40 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
24-02-25 18:40:40 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
24-02-25 18:40:40 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
24-02-25 18:40:40 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
24-02-25 18:40:40 INFO (MainThread) [supervisor.host.services] Updating service information
24-02-25 18:40:40 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
24-02-25 18:40:40 INFO (MainThread) [supervisor.host.network] Updating local network information
24-02-25 18:40:40 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
24-02-25 18:40:40 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
24-02-25 18:40:40 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
24-02-25 18:40:41 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2023.11.0
24-02-25 18:40:41 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2023.06.2
24-02-25 18:40:41 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
24-02-25 18:40:41 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2023.12.0
24-02-25 18:40:41 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2023.06.0
24-02-25 18:40:41 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2023.06.2
24-02-25 18:40:41 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
24-02-25 18:40:41 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/generic-x86-64-homeassistant with version landingpage
24-02-25 18:40:41 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
24-02-25 18:40:41 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 11.5 / BootSlot A
24-02-25 18:40:41 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
24-02-25 18:40:41 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository
24-02-25 18:40:41 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repository
24-02-25 18:43:33 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/home-assistant/addons repository: Cmd('git') failed due to: exit code(128)
  cmdline: git clone -v --recursive --depth=1 --shallow-submodules -- https://github.com/home-assistant/addons /data/addons/core
  stderr: 'Cloning into '/data/addons/core'...
POST git-upload-pack (175 bytes)
error: RPC failed; curl 28 Failed to connect to github.com port 443 after 130781 ms: Couldn't connect to server
fatal: expected flush after ref listing
24-02-25 18:43:33 ERROR (MainThread) [supervisor.store] Can't retrieve data from core due to
24-02-25 18:43:33 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_remove - store / core
24-02-25 18:43:33 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / core
24-02-25 18:43:33 INFO (MainThread) [supervisor.store] Loading add-ons from store: 51 all - 51 new - 0 remove
24-02-25 18:43:33 INFO (MainThread) [supervisor.addons.manager] Found 0 installed add-ons
24-02-25 18:43:33 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
24-02-25 18:43:33 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
24-02-25 18:43:33 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
24-02-25 18:43:33 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
24-02-25 18:43:33 INFO (MainThread) [supervisor.resolution.check] System checks complete
24-02-25 18:43:33 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
24-02-25 18:43:33 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-02-25 18:43:33 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
24-02-25 18:43:33 INFO (MainThread) [__main__] Running Supervisor
24-02-25 18:43:33 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
24-02-25 18:43:33 INFO (MainThread) [supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
24-02-25 18:43:33 INFO (MainThread) [supervisor.addons.manager] Phase 'system' starting 0 add-ons
24-02-25 18:43:33 INFO (MainThread) [supervisor.addons.manager] Phase 'services' starting 0 add-ons
24-02-25 18:43:33 INFO (MainThread) [supervisor.core] Skipping start of Home Assistant
24-02-25 18:43:33 INFO (MainThread) [supervisor.addons.manager] Phase 'application' starting 0 add-ons
24-02-25 18:43:33 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
24-02-25 18:43:33 INFO (MainThread) [supervisor.core] Supervisor is up and running
24-02-25 18:43:33 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
24-02-25 18:43:33 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/generic-x86-64-homeassistant:landingpage to ghcr.io/home-assistant/generic-x86-64-homeassistant:2024.2.3
24-02-25 18:43:33 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/generic-x86-64-homeassistant with tag 2024.2.3.
24-02-25 18:43:33 INFO (MainThread) [supervisor.host.info] Updating local host information
24-02-25 18:43:33 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
24-02-25 18:43:33 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
24-02-25 18:43:33 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
24-02-25 18:43:33 INFO (MainThread) [supervisor.resolution.module] Create new suggestion create_full_backup - system / None
24-02-25 18:43:33 INFO (MainThread) [supervisor.resolution.module] Create new issue no_current_backup - system / None
24-02-25 18:43:33 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
24-02-25 18:43:33 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
24-02-25 18:43:33 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
24-02-25 18:43:33 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
24-02-25 18:43:33 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
24-02-25 18:43:33 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
24-02-25 18:43:33 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
24-02-25 18:43:33 INFO (MainThread) [supervisor.host.services] Updating service information
24-02-25 18:43:33 INFO (MainThread) [supervisor.host.network] Updating local network information
24-02-25 18:43:33 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
24-02-25 18:43:33 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
24-02-25 18:43:33 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
24-02-25 18:43:33 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
24-02-25 18:43:33 INFO (MainThread) [supervisor.host.manager] Host information reload completed
24-02-25 18:43:33 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
24-02-25 18:43:33 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
24-02-25 19:43:33 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
24-02-25 19:43:33 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
24-02-25 19:43:33 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
24-02-25 19:43:33 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
24-02-25 19:43:33 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
24-02-25 19:43:34 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
24-02-25 19:43:34 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
24-02-25 19:43:34 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
24-02-25 19:43:34 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
24-02-25 19:43:34 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
24-02-25 19:43:34 INFO (MainThread) [supervisor.resolution.check] System checks complete
24-02-25 19:43:34 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
24-02-25 19:43:34 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-02-25 19:43:34 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
24-02-25 19:43:34 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
[11:58:29] INFO: Using udev information from host
[11:58:29] INFO: Starting local supervisor watchdog...
24-02-25 11:58:30 INFO (MainThread) [__main__] Initializing Supervisor setup
24-02-25 19:58:30 INFO (MainThread) [supervisor.bootstrap] Setting up coresys for machine: generic-x86-64
24-02-25 19:58:30 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/amd64-hassio-supervisor with version 2024.02.0
24-02-25 19:58:30 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
24-02-25 19:58:30 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-02-25 19:58:30 INFO (MainThread) [__main__] Setting up Supervisor
24-02-25 19:58:31 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
24-02-25 19:58:31 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
24-02-25 19:58:31 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
24-02-25 19:58:31 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
24-02-25 19:58:31 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
24-02-25 19:58:31 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
24-02-25 19:58:31 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
24-02-25 19:58:31 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
24-02-25 19:58:31 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
24-02-25 19:58:31 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
24-02-25 19:58:31 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
24-02-25 19:58:31 INFO (MainThread) [supervisor.host.services] Updating service information
24-02-25 19:58:31 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
24-02-25 19:58:31 WARNING (SyncWorker_0) [supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
24-02-25 19:58:31 INFO (MainThread) [supervisor.host.network] Updating local network information
24-02-25 19:58:31 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
24-02-25 19:58:31 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
24-02-25 19:58:31 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
24-02-25 19:58:32 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2023.11.0
24-02-25 19:58:32 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
24-02-25 19:58:32 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_cli application
24-02-25 19:58:32 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/amd64-hassio-cli with version 2023.11.0 - 172.30.32.5
24-02-25 19:58:32 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2023.06.2
24-02-25 19:58:32 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
24-02-25 19:58:32 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_dns application
24-02-25 19:58:33 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/amd64-hassio-dns with version 2023.06.2 - 172.30.32.3
24-02-25 19:58:33 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
24-02-25 19:58:33 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2023.12.0
24-02-25 19:58:33 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
24-02-25 19:58:33 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_audio application
24-02-25 19:58:33 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/amd64-hassio-audio with version 2023.12.0 - 172.30.32.4
24-02-25 19:58:33 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2023.06.0
24-02-25 19:58:33 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2023.06.2
24-02-25 19:58:33 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
24-02-25 19:58:33 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_multicast application
24-02-25 19:58:33 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/amd64-hassio-multicast with version 2023.06.2 - Host
24-02-25 19:58:33 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
24-02-25 19:58:33 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/generic-x86-64-homeassistant with version landingpage
24-02-25 19:58:33 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
24-02-25 19:58:33 INFO (SyncWorker_0) [supervisor.docker.manager] Starting homeassistant
24-02-25 19:58:34 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 11.5 / BootSlot A
24-02-25 19:58:34 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
24-02-25 19:58:34 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository
24-02-25 19:58:34 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repository
24-02-25 19:58:36 INFO (MainThread) [supervisor.store] Loading add-ons from store: 77 all - 77 new - 0 remove
24-02-25 19:58:36 INFO (MainThread) [supervisor.addons.manager] Found 0 installed add-ons
24-02-25 19:58:36 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
24-02-25 19:58:36 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
24-02-25 19:58:36 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
24-02-25 19:58:36 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
24-02-25 19:58:36 INFO (MainThread) [supervisor.resolution.check] System checks complete
24-02-25 19:58:36 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
24-02-25 19:58:36 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-02-25 19:58:36 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
24-02-25 19:58:36 INFO (MainThread) [__main__] Running Supervisor
24-02-25 19:58:36 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
24-02-25 19:58:36 INFO (MainThread) [supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
24-02-25 19:58:36 INFO (MainThread) [supervisor.addons.manager] Phase 'system' starting 0 add-ons
24-02-25 19:58:36 INFO (MainThread) [supervisor.addons.manager] Phase 'services' starting 0 add-ons
24-02-25 19:58:36 INFO (MainThread) [supervisor.core] Skipping start of Home Assistant
24-02-25 19:58:36 INFO (MainThread) [supervisor.addons.manager] Phase 'application' starting 0 add-ons
24-02-25 19:58:36 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
24-02-25 19:58:36 INFO (MainThread) [supervisor.core] Supervisor is up and running
24-02-25 19:58:36 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
24-02-25 19:58:36 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/generic-x86-64-homeassistant:landingpage to ghcr.io/home-assistant/generic-x86-64-homeassistant:2024.2.3
24-02-25 19:58:36 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/generic-x86-64-homeassistant with tag 2024.2.3.
24-02-25 19:58:36 INFO (MainThread) [supervisor.host.info] Updating local host information
24-02-25 19:58:36 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
24-02-25 19:58:36 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
24-02-25 19:58:36 INFO (MainThread) [supervisor.resolution.module] Create new suggestion create_full_backup - system / None
24-02-25 19:58:36 INFO (MainThread) [supervisor.resolution.module] Create new issue no_current_backup - system / None
24-02-25 19:58:36 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
24-02-25 19:58:36 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
24-02-25 19:58:36 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
24-02-25 19:58:36 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
24-02-25 19:58:36 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
24-02-25 19:58:36 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
24-02-25 19:58:36 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
24-02-25 19:58:36 INFO (MainThread) [supervisor.host.services] Updating service information
24-02-25 19:58:36 INFO (MainThread) [supervisor.host.network] Updating local network information
24-02-25 19:58:36 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
24-02-25 19:58:36 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
24-02-25 19:58:36 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
24-02-25 19:58:36 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
24-02-25 19:58:36 INFO (MainThread) [supervisor.host.manager] Host information reload completed
24-02-25 19:58:36 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
24-02-25 19:58:36 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
 楼主| 发表于 2024-2-25 22:53:34 | 显示全部楼层
重装了一次就解决了。。但是还是想知道前一次是哪儿的错。。
发表于 2024-2-26 06:10:14 | 显示全部楼层
没有魔法,访问GitHub失败了
 楼主| 发表于 2024-2-26 12:00:03 | 显示全部楼层
ms_jiang144 发表于 2024-2-26 06:10
没有魔法,访问GitHub失败了
所以现在访问GitHub是看脸吗
发表于 2024-2-28 21:21:10 | 显示全部楼层
meow7869 发表于 2024-2-26 12:00
所以现在访问GitHub是看脸吗
梯子就好
GMT+8, 2025-12-20 06:59 , Processed in 0.113842 second(s), 13 queries , MemCached On.
