查看: 1396|回复: 1
[新手导航] 树莓派3安装HA失败
发表于 2024-2-25 09:42:14 | 显示全部楼层 |阅读模式
各位大佬,小弟用树莓派安装haos_rpi3-64-12.0.rc1一直失败,麻烦看看什么是什么原因。谢谢。
[10:58:51] INFO: Using udev information from host
[10:58:51] INFO: Starting local supervisor watchdog...
23-04-04 10:59:07 INFO (MainThread) [__main__] Initializing Supervisor setup
23-04-04 10:59:07 INFO (MainThread) [supervisor.docker.network] Can't find Supervisor network, creating a new network
23-04-04 10:59:09 INFO (MainThread) [supervisor.bootstrap] Setting up coresys for machine: raspberrypi3-64
23-04-04 10:59:09 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/aarch64-hassio-supervisor with version 2024.01.1
23-04-04 10:59:09 INFO (MainThread) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
23-04-04 10:59:10 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
23-04-04 10:59:10 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-04-04 10:59:10 INFO (MainThread) [__main__] Setting up Supervisor
23-04-04 10:59:15 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
23-04-04 10:59:16 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
23-04-04 10:59:16 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
23-04-04 10:59:16 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
23-04-04 10:59:16 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
23-04-04 10:59:16 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
23-04-04 10:59:16 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
23-04-04 10:59:16 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
23-04-04 10:59:16 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
23-04-04 10:59:16 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
23-04-04 10:59:16 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
23-04-04 10:59:18 INFO (MainThread) [supervisor.host.services] Updating service information
23-04-04 10:59:18 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-04-04 10:59:18 WARNING (SyncWorker_0) [supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
23-04-04 10:59:19 INFO (MainThread) [supervisor.host.network] Updating local network information
23-04-04 10:59:19 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
23-04-04 10:59:24 WARNING (MainThread) [supervisor.utils.whoami] Can't fetch Whoami data: Cannot connect to host services.home-assistant.io:443 ssl:default [Try again]
23-04-04 10:59:24 WARNING (MainThread) [supervisor.core] Can't adjust Time/Date settings: Can't fetch Whoami data: Cannot connect to host services.home-assistant.io:443 ssl:default [Try again]
23-04-04 10:59:24 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
23-04-04 10:59:29 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 10:59:29 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-cli versions: [<AwesomeVersion CalVer '2023.11.0'>]
23-04-04 10:59:29 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2023.11.0
23-04-04 10:59:29 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
23-04-04 10:59:39 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/aarch64-hassio-cli with version 2023.11.0 - 172.30.32.5
23-04-04 10:59:40 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-dns versions: [<AwesomeVersion CalVer '2023.06.2'>]
23-04-04 10:59:40 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-dns with version 2023.06.2
23-04-04 10:59:40 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
23-04-04 10:59:50 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/aarch64-hassio-dns with version 2023.06.2 - 172.30.32.3
23-04-04 10:59:50 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
23-04-04 10:59:56 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-audio versions: [<AwesomeVersion CalVer '2023.12.0'>]
23-04-04 10:59:56 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0
23-04-04 10:59:56 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
23-04-04 11:00:05 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0 - 172.30.32.4
23-04-04 11:00:05 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-observer versions: [<AwesomeVersion CalVer '2023.06.0'>]
23-04-04 11:00:05 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-observer with version 2023.06.0
23-04-04 11:00:05 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin
23-04-04 11:00:14 INFO (MainThread) [supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/aarch64-hassio-observer with version 2023.06.0 - 172.30.32.6
23-04-04 11:00:14 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-multicast versions: [<AwesomeVersion CalVer '2023.06.2'>]
23-04-04 11:00:14 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-multicast with version 2023.06.2
23-04-04 11:00:14 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
23-04-04 11:00:24 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/aarch64-hassio-multicast with version 2023.06.2 - Host
23-04-04 11:00:24 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
23-04-04 11:00:24 INFO (MainThread) [supervisor.docker.interface] No version found for ghcr.io/home-assistant/raspberrypi3-64-homeassistant
23-04-04 11:00:24 INFO (MainThread) [supervisor.homeassistant.core] No Home Assistant Docker image ghcr.io/home-assistant/raspberrypi3-64-homeassistant found.
23-04-04 11:00:24 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/raspberrypi3-64-homeassistant with version landingpage
23-04-04 11:00:24 INFO (MainThread) [supervisor.homeassistant.core] Using preinstalled landingpage
23-04-04 11:00:24 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
23-04-04 11:00:24 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
23-04-04 11:00:38 INFO (MainThread) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/raspberrypi3-64-homeassistant with version landingpage
23-04-04 11:00:38 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 12.0.rc1 / BootSlot A
23-04-04 11:00:43 WARNING (MainThread) [supervisor.jobs] 'GitRepo.clone' blocked from execution, no supervisor internet connection
23-04-04 11:00:43 ERROR (MainThread) [supervisor.store] Can't add repository https://github.com/hassio-addons/repository due to 'GitRepo.clone' blocked from execution, no supervisor internet connection
23-04-04 11:00:43 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_reload - store / a0d7b954
23-04-04 11:00:43 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / a0d7b954
23-04-04 11:00:43 ERROR (MainThread) [supervisor.store] Can't add repository core due to 'GitRepo.clone' blocked from execution, no supervisor internet connection
23-04-04 11:00:43 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_reload - store / core
23-04-04 11:00:43 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / core
23-04-04 11:00:43 ERROR (MainThread) [supervisor.store] Can't add repository https://github.com/esphome/home-assistant-addon due to 'GitRepo.clone' blocked from execution, no supervisor internet connection
23-04-04 11:00:43 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_reload - store / 5c53de3b
23-04-04 11:00:43 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / 5c53de3b
23-04-04 11:00:43 INFO (MainThread) [supervisor.store] Loading add-ons from store: 0 all - 0 new - 0 remove
23-04-04 11:00:43 INFO (MainThread) [supervisor.addons.manager] Found 0 installed add-ons
23-04-04 11:00:43 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
23-04-04 11:00:43 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
23-04-04 11:00:43 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
23-04-04 11:00:43 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
23-04-04 11:00:43 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-04-04 11:00:43 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
23-04-04 11:00:43 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-04-04 11:00:43 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
23-04-04 11:00:43 INFO (MainThread) [__main__] Running Supervisor
23-04-04 11:00:43 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
23-04-04 11:00:43 INFO (MainThread) [supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
23-04-04 11:00:43 INFO (MainThread) [supervisor.addons.manager] Phase 'system' starting 0 add-ons
23-04-04 11:00:43 INFO (MainThread) [supervisor.addons.manager] Phase 'services' starting 0 add-ons
23-04-04 11:00:43 INFO (MainThread) [supervisor.core] Skipping start of Home Assistant
23-04-04 11:00:43 INFO (MainThread) [supervisor.addons.manager] Phase 'application' starting 0 add-ons
23-04-04 11:00:43 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
23-04-04 11:00:43 INFO (MainThread) [supervisor.core] Supervisor is up and running
23-04-04 11:00:43 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
23-04-04 11:00:43 INFO (MainThread) [supervisor.host.info] Updating local host information
23-04-04 11:00:43 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
23-04-04 11:00:43 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
23-04-04 11:00:43 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
23-04-04 11:00:43 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
23-04-04 11:00:43 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
23-04-04 11:00:46 INFO (MainThread) [supervisor.host.services] Updating service information
23-04-04 11:00:46 INFO (MainThread) [supervisor.host.network] Updating local network information
23-04-04 11:00:47 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-04-04 11:00:47 INFO (MainThread) [supervisor.host.manager] Host information reload completed
23-04-04 11:00:48 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 11:00:48 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 11:00:48 INFO (MainThread) [supervisor.jobs] 'CheckAddonPwned.run_check' blocked from execution, no supervisor internet connection
23-04-04 11:00:48 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
23-04-04 11:00:53 INFO (MainThread) [supervisor.jobs] 'CheckDNSServer.run_check' blocked from execution, no supervisor internet connection
23-04-04 11:00:53 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
23-04-04 11:00:58 INFO (MainThread) [supervisor.jobs] 'CheckDNSServerIPv6.run_check' blocked from execution, no supervisor internet connection
23-04-04 11:00:58 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
23-04-04 11:00:58 INFO (MainThread) [supervisor.resolution.module] Create new suggestion create_full_backup - system / None
23-04-04 11:00:58 INFO (MainThread) [supervisor.resolution.module] Create new issue no_current_backup - system / None
23-04-04 11:00:58 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
23-04-04 11:00:58 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
23-04-04 11:00:58 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
23-04-04 11:00:58 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-04-04 11:00:58 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
23-04-04 11:01:00 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-04-04 11:01:00 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
23-04-04 11:01:05 WARNING (MainThread) [supervisor.jobs] 'FixupStoreExecuteReload.process_fixup' blocked from execution, no supervisor internet connection
23-04-04 11:01:05 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
23-04-04 11:01:23 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 11:01:23 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 11:01:58 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 11:01:58 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 11:02:33 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 11:02:33 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 11:03:08 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 11:03:08 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 11:03:43 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 11:03:43 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 11:04:19 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 11:04:19 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 11:04:54 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 11:04:54 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 11:05:29 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 11:05:29 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 11:06:04 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 11:06:04 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 11:06:39 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 11:06:39 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 11:07:14 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 11:07:14 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 11:07:49 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 11:07:49 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 11:08:24 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 11:08:24 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
发表于 2024-3-27 11:57:04 | 显示全部楼层
我和你一样的问题,我也想找解决办法
GMT+8, 2025-12-8 09:20 , Processed in 0.734296 second(s), 13 queries , MemCached On.
