楼主: Awe7
[已解决] 求个esphome配置文件
发表于 2024-2-24 16:14:45 | 显示全部楼层
Awe7 发表于 2024-2-24 16:07
INFO ESPHome 2024.2.0
INFO Reading configuration /config/esphome/32.yaml...
ERROR Error while read ...
binary_sensor:
  - platform: gpio
    pin:
      number: 14
      mode: INPUT_PULLUP
    on_state:
      - if:
          condition:
            and:
              - binary_sensor.is_on: pir501
              - binary_sensor.is_on: kaiguan
          then:
              - binary_sensor.template.publish:
                  state: on
          else:
                  state: off
  - platform: gpio
    pin:
      number: 12
      mode: INPUT_PULLUP
    device_class: motion
    filters:
      - delayed_off: 10s
    on_press:
      then:
        - if:
            condition:
              and:
            then:
              - logger.log: "Detected somebody activity"
                  state: on
            else:
              - logger.log: "There is no one around"
                  state: on
    on_release:
      then:
        - switch.turn_off: relay
  - platform: template
    on_press:
    on_release:
switch:
  - platform: gpio
    pin: GPIO4
Awe7 手机认证
 楼主| 发表于 2024-2-25 17:50:02 | 显示全部楼层
kjjuhfv 发表于 2024-2-24 16:14
binary_sensor:
  - platform: gpio
    pin:
老哥,按照你这个配置翘板开关无法打开继电器,(翘板开关切换状态)pir触发也无法打开,只能用ha里面的开关打开继电器.0.0
发表于 2024-2-25 18:12:00 | 显示全部楼层
Awe7 发表于 2024-2-25 17:50
老哥,按照你这个配置翘板开关无法打开继电器,(翘板开关切换状态)pir触发也无法打开,只能用ha里面的 ...
哈哈忘记修改几处了
晚上回去再帮你改
发表于 2024-2-25 20:05:47 | 显示全部楼层
其实我还是没有搞清楚你到底什么要求 我加上注释了 你自己看着理解吧
binary_sensor:
  - platform: gpio
    pin:
      number: 14
      mode: INPUT_PULLUP
    on_state:
      - if:
          condition:   #检查条件
            and:
          then:   #id为pir501和kaiguan同时状态为on的时候 执行发布id为trigger的传感器状态为on
                  state: on
          else:   #id为pir501和kaiguan没有同时状态为on的时候 执行发布id为trigger的传感器状态为off
                  state: off
  - platform: gpio
    pin:
      number: 12
      mode: INPUT_PULLUP
    filters:
      - delayed_off: 10s      #延迟10秒发布状态为off
    on_press:   #按下时 对id为trigger的传感器发布状态on
            then:
                  state: on
    on_release:     #松开时 对id为trigger的传感器发布状态off
                  state: on
    on_press:
      - switch.turn_on: relay
    on_release:
switch:
  - platform: gpio
    pin: GPIO4
Awe7 手机认证
 楼主| 发表于 2024-2-25 21:07:46 | 显示全部楼层
binary_sensor:
  - platform: gpio
    pin:
      number: 14
      mode: INPUT_PULLUP
    on_press:
      - switch.toggle: relay
  - platform: gpio
    pin:
      number: 12
      mode: INPUT_PULLUP
    filters:
      - invert:
      - delayed_on: 800ms
      - delayed_off: 10s          #延时关闭
    on_press:
      then:
        - if:
            condition:
              and:
            then:
            else:
    on_release:                                   #感应不到人关闭开关
      then:
switch:
  - platform: gpio
    pin: GPIO4
按照上面配置  当感应到有人时继电器会开启,延迟10s后关闭。   id:kaiguan可以手动控制继电器开关。 但通过id;kaiguan开启继电器后 (若没有继续触发感应器就会延迟10s后自动关闭),
现需求是  当id:kaiguan  手动打开时, 感应器不能控制继电器关闭状态。
               当id:kaiguan手动打开时,感应器正常控制继电器,正常开关(感应到人自动开,无人时延迟10s关闭继电器)
以上
发表于 2024-2-25 21:35:54 | 显示全部楼层
Awe7 发表于 2024-2-25 21:07
binary_sensor:
  - platform: gpio
    pin:
binary_sensor:
  - platform: gpio
    pin:
      number: 14
      mode: INPUT_PULLUP
    on_press:  #只有按下时切换开关 松开没有行动
  - platform: gpio
    pin:
      number: 12
      mode: INPUT_PULLUP
    filters:
      #- invert:   反转数值
      #- delayed_on: 800ms
    on_press:
      then:
        - if:
            condition:
            then:  #检查到id为kaiguan的状态打开时 只输出log
            else:  #检查到id为kaiguan的状态未打开时 关闭开关
switch:
  - platform: gpio
    pin: GPIO4
重新发过了
Awe7 手机认证
 楼主| 发表于 2024-2-25 23:02:01 | 显示全部楼层
kjjuhfv 发表于 2024-2-25 21:35
重新发过了
好的老哥 ,我测试下
谢谢
Awe7 手机认证
 楼主| 发表于 2024-3-1 18:20:53 | 显示全部楼层
重新发过了
已解决问题,再次感谢
GMT+8, 2025-11-4 07:12 , Processed in 0.417825 second(s), 7 queries , MemCached On.
