查看: 3828|回复: 3
[技术探讨] 求助:mushroom的template卡片怎么去边框
发表于 2024-2-21 11:14:52 | 显示全部楼层 |阅读模式
我这拼起来的mushroom template总是有个边框,求助怎么去掉呢:
配置如下:
type: custom:stack-in-card
mode: horizontal
cards:
  - type: custom:mushroom-template-card
    primary: '{{ state_attr(entity, ''friendly_name'') }}'
    secondary: '{{ states(entity) }}'
    entity: input_select.ren_lian_ji_he
    tap_action:
      action: none
    hold_action:
      action: none
    double_tap_action:
      action: none
    card_mod:
      style: |
        :host {
          border: transparent;
    icon: |
      {% if is_state(entity, '家人') %}
        mdi:numeric-1
      {% elif is_state(entity, '亲戚') %}
        mdi:numeric-2
      {% elif is_state(entity, '朋友') %}
        mdi:numeric-3
      {% elif is_state(entity, '测试') %}
        mdi:numeric-4
      {% else %}
        mdi:numeric-0
      {% endif %}
    icon_color: |
        orange
        red
        pink
        blue
      {% else %}
        grey
      {% endif %}
  - type: custom:mushroom-chips-card
    chips:
      - type: template
        tap_action:
          action: call-service
          service: input_select.select_option
          data:
            option: 家人
          target:
            entity_id: input_select.ren_lian_ji_he
        icon: mdi:numeric-1
        icon_color: |
            orange
          {% else %}
            grey
          {% endif %}
        content_info: none
      - type: template
        tap_action:
          data:
            option: 亲戚
          target:
        icon: mdi:numeric-2
        icon_color: |
          {% if is_state(entity, '亲戚') %}
            orange
          {% else %}
            grey
          {% endif %}
        content_info: none
      - type: template
        tap_action:
          data:
            option: 朋友
          target:
        icon: mdi:numeric-3
        icon_color: |
          {% if is_state(entity, '朋友') %}
            orange
          {% else %}
            grey
          {% endif %}
        content_info: none
      - type: template
        tap_action:
          data:
            option: 测试
          target:
        icon: mdi:numeric-4
        icon_color: |
          {% if is_state(entity, '测试') %}
            orange
          {% else %}
            grey
          {% endif %}
        content_info: none
    alignment: justify
    card_mod:
      style: |
        ha-card {
          margin-top: 14px;
          margin-right: 12px;
          --chip-background: rgba(var(--rgb-disabled), 0.2);
          --chip-box-shadow: none;
 楼主| 发表于 2024-2-21 17:10:39 | 显示全部楼层
搞定了,原来是stack-in-card有bug
发表于 2024-6-23 18:55:11 | 显示全部楼层
怎么修复的呀,可以请教一下嘛
道行尚浅
发表于 2024-6-25 10:44:38 | 显示全部楼层
zddontheway 发表于 2024-6-23 18:55
怎么修复的呀,可以请教一下嘛
根据issue 找到了结果,在这里留个处理方式,通过card_mod 进行解决的
加入
  card_mod:
    style:
      hui-vertical-stack-card $: |
        div#root > * {
          margin: 0px !important;
          --ha-card-border-width: 0;
解决方法的地址: https://github.com/custom-cards/stack-in-card/issues/34
道行尚浅
GMT+8, 2026-1-8 15:49 , Processed in 0.100070 second(s), 8 queries , MemCached On.
