查看: 2377|回复: 4
[求助] 树莓派3b+杀进程有什么好办法吗?
发表于 2024-2-16 12:23:24 | 显示全部楼层 |阅读模式
树莓派3B+,1G内存,总是杀Addon进程,node-red,总是被杀,file editor和samba也总是重启,有什么好办法吗?
发表于 2024-2-18 11:59:02 | 显示全部楼层
交换文件和zram0
发表于 2024-2-18 12:02:08 | 显示全部楼层
ssh:
  username: root
  password: ""
  authorized_keys:
       密钥
  sftp: false
  compatibility_mode: false
  allow_agent_forwarding: true
  allow_remote_port_forwarding: true
  allow_tcp_forwarding: true
zsh: true
share_sessions: false
packages: []
init_commands:
    if [ ! -f /backup/_swap.swap ]; then fallocate -l 2G /backup/_swap.swap
    &&     mkswap /backup/_swap.swap && chmod 0600 /backup/_swap.swap &&
    swapon     /backup/_swap.swap ; elif [[ ! $(dmesg|grep _swap.swap) = *swap\
    on* ]];     then swapon /backup/_swap.swap; fi
    ssh [email protected] -p 22222 'swapoff /dev/zram0; sleep 10; zramctl
    /dev/zram0 -s 2G -t 4 -a zstd; mkswap /dev/zram0; swapon /dev/zram0 -p 5;
    echo 10 > /proc/sys/vm/swappiness'
发表于 2024-2-18 12:03:10 | 显示全部楼层
ssh需要root权限
 楼主| 发表于 2024-2-18 12:21:28 | 显示全部楼层
yuhuanfan 发表于 2024-2-18 12:02
ssh:
  username: root
  password: ""
谢谢大佬的恢复,小白实在看不懂,暂时不搞node了,先用自动化了。
GMT+8, 2025-12-17 09:28 , Processed in 1.008494 second(s), 11 queries , MemCached On.
