查看: 3017|回复: 5
[求助] frigate存储问题
发表于 2024-2-15 10:51:29 | 显示全部楼层 |阅读模式
RT,请问使用frigate做NVR,可以把视频都存在HA的安装盘吗?frigate有没有循环删除的机制?(有个4T的闲置硬盘和一块N2600,打算物理安装HAOS)
发表于 2024-2-16 12:01:22 | 显示全部楼层
系统默认10天
snapshots:
  # Optional: Enable writing jpg snapshot to /media/frigate/clips (default: shown below)
  enabled: False
  # Optional: save a clean PNG copy of the snapshot image (default: shown below)
  clean_copy: True
  # Optional: print a timestamp on the snapshots (default: shown below)
  timestamp: False
  # Optional: draw bounding box on the snapshots (default: shown below)
  bounding_box: True
  # Optional: crop the snapshot (default: shown below)
  crop: False
  # Optional: height to resize the snapshot to (default: original size)
  height: 175
  # Optional: Restrict snapshots to objects that entered any of the listed zones (default: no required zones)
  required_zones: []
  # Optional: Camera override for retention settings (default: global values)
  retain:
    # Required: Default retention days (default: shown below)
    default: 10  #这里就是截图的默认覆盖时间
    # Optional: Per object retention days
    objects:
      person: 15
  # Optional: quality of the encoded jpeg, 0-100 (default: shown below)
  quality: 70
如果是录像的时间
record:
  # Optional: Enable recording (default: shown below)
  # WARNING: If recording is disabled in the config, turning it on via
  #          the UI or MQTT later will have no effect.
  enabled: False
  # Optional: Number of minutes to wait between cleanup runs (default: shown below)
  # This can be used to reduce the frequency of deleting recording segments from disk if you want to minimize i/o
  expire_interval: 60
  # Optional: Sync recordings with disk on startup and once a day (default: shown below).
  sync_recordings: False
  # Optional: Retention settings for recording
  retain:
    # Optional: Number of days to retain recordings regardless of events (default: shown below)
    # NOTE: This should be set to 0 and retention should be defined in events section below
    #       if you only want to retain recordings of events.
    days: 10  #这里为录像的保存时间
发表于 2024-2-16 12:09:03 | 显示全部楼层
frigate的存储都是在frigate的配置目录里面,还有N2600配置太老,建议用6代以上的CPU,有条件直接上N100这玩意新能贼强。8路1080P,ffmpeg硬解,ov推理,整个CPU使用率也不会很高。性价比非常高
jole 手机认证
发表于 2024-2-18 11:57:37 | 显示全部楼层
trz0332 发表于 2024-2-16 12:09
frigate的存储都是在frigate的配置目录里面,还有N2600配置太老,建议用6代以上的CPU,有条件直接上N100这 ...
n100核显给haos吗?
发表于 2024-2-19 17:05:24 | 显示全部楼层
jole 发表于 2024-2-18 11:57
n100核显给haos吗?
我是直接在pev里面装了docker,创建docker容器的时候把核显给了frigate的容器就行了。
发表于 2024-2-20 16:21:38 | 显示全部楼层
trz0332 发表于 2024-2-19 17:05
我是直接在pev里面装了docker,创建docker容器的时候把核显给了frigate的容器就行了。 ...
n100 如何将核显直通给lxc docker呢
GMT+8, 2025-12-17 09:28 , Processed in 1.001885 second(s), 6 queries , MemCached On.
