查看: 5154|回复: 8
[技术探讨] Airx设备最新接入方法-2024
发表于 2024-2-13 23:38:58 | 显示全部楼层 |阅读模式
Airx的设备目前已经全系列接入了涂鸦智能,并且非标准指令的模式比较多,这里以 Airx 加湿器H8为例来大概描述下如何加入HA。
1、下载涂鸦 "智能生活" APP并给设备重新配网
目前涂鸦平台的设备均可使用其智能生活 APP重新配网,将加湿器进入配网模式(本型号是长按电源键),打开涂鸦的 智能生活  APP添加设备,即可扫描到新设备,配网即可,这个是下面获取所有id和key的基础。
2、注册涂鸦Iot平台开发者,并绑定 "智能生活"APP
按照  官方文档 的方式注册开发者平台,新建应用,绑定智能生活APP并将Airx设备绑定到平台。
3、获取localkey
由于Airx设备非标控制指令比较懂,涂鸦官方的hass插件对其支持的不太好,所以我们还是以localtuya的方式进行接入,就需要获取localkey来进行。
此篇文档 直接给出了在线获取localkey的方式,当然通过tuya-cli等也可以获取,不过还是在线比较方便。需要的设备id可以在涂鸦开发者控制台上项目的设备页面看到。
4、安装localtuya
localtuya目前有很多社区分支,我选用的是 https://github.com/xZetsubou/hass-localtuya  的分支,目前更新比较快,而且对加湿器支持最好。根据文档进行安装即可,我们主要直接做本地接入,无需配置云端API。
5、获取DP ID
由于airx的设备dp大多不标准,所以建议用"查询设备物理模型"的API进行获取实际的dp_id,否则添加设备时可能出现无响应错误。
API在线地址  这里可以直接点击使用,填入之前获取到的设备ID即可,最后返回类似结果:
  "result": {
    "model": "{"modelId":"000004ewl4","services":[{"actions":[],"code":"","description":"","events":[],"name":"默认服务","properties":[{"abilityId":1,"accessMode":"rw","code":"switch","description":"","extensions":{"iconName":"icon-dp_power","attribute":"128"},"name":"总开关","typeSpec":{"type":"bool","typeDefaultValue":false}},{"abilityId":5,"accessMode":"rw","code":"switch_led","description":"","extensions":{"iconName":"icon-dp_light","attribute":"128"},"name":"灯光","typeSpec":{"type":"bool","typeDefaultValue":false}},{"abilityId":8,"accessMode":"rw","code":"sound","description":"","extensions":{"iconName":"icon-dp_voice","attribute":"128"},"name":"声音","typeSpec":{"type":"bool","typeDefaultValue":false}},{"abilityId":13,"accessMode":"rw","code":"humidity_set","description":"","extensions":{"iconName":"icon-a_mode_dry","attribute":"128"},"name":"湿度设置","typeSpec":{"max":80,"min":30,"scale":0,"step":5,"type":"value","typeDefaultValue":30,"unit":"%RH"}},{"abilityId":14,"accessMode":"ro","code":"humidity_current","description":"","extensions":{"iconName":"icon-shidu","attribute":"128"},"name":"当前湿度","typeSpec":{"max":90,"min":10,"scale":0,"step":1,"type":"value","typeDefaultValue":10,"unit":"%RH"}},{"abilityId":22,"accessMode":"ro","code":"fault","description":"","extensions":{"iconName":"icon-Panic","scope":"fault","attribute":"1152"},"name":"机头分离告警","typeSpec":{"label":["break_off"],"maxlen":1,"type":"bitmap","typeDefaultValue":0}},{"abilityId":24,"accessMode":"rw","code":"mode","description":"","extensions":{"attribute":"128"},"name":"工作模式","typeSpec":{"range":["AUTO","LOW","MIDDLE","HIGH","SLEEP"],"type":"enum","typeDefaultValue":"AUTO"}},{"abilityId":25,"accessMode":"rw","code":"anion","description":"","extensions":{"attribute":"128"},"name":"负离子","typeSpec":{"type":"bool","typeDefaultValue":false}},{"abilityId":29,"accessMode":"rw","code":"child_lock","description":"","extensions":{"attribute":"128"},"name":"童锁","typeSpec":{"type":"bool","typeDefaultValue":false}},{"abilityId":101,"accessMode":"ro","code":"water_level","description":"","name":"当前水位","typeSpec":{"range":["No_water","Have_water","Full_water","Have_water2"],"type":"enum","typeDefaultValue":"No_water"}},{"abilityId":102,"accessMode":"rw","code":"uv_light","description":"","extensions":{"iconName":"icon-dp_power2","attribute":"4096"},"name":"UV灯","typeSpec":{"type":"bool","typeDefaultValue":false}}]}]}"
  "success": true,
  "t": 1707835567705,
  "tid": "9ef05dc8ca7e11ee9b96ba916b56a9a0"
其中的abilityID 就是我们需要的DP ID,可以看到每个也都有取值解释。
6、配置本地设备
根据localtuya文档的指示,在集成配置中添加新设备,如下填写内容:
之后点击提交。
然后稍等一会儿会让你做一个hass中设备类型的适配,我这里直接让他做自动检测就可以自动适配为加湿器,如果无法自动配置,需要选择合适的设备模型后填入对应属性的DP ID或对每个DP ID配置为switch input等实体,会比较麻烦。然后就可以正常在hass中使用了。
最后接入效果:
发表于 2024-2-24 20:23:56 | 显示全部楼层
我的空气净化器, 传感器(滤芯寿命,PM2.5)好像数值都拿不到  全是0
 楼主| 发表于 2024-2-28 22:29:30 | 显示全部楼层
要看下涂鸦的调试页面上能不能拿到。
发表于 2024-4-14 22:26:59 | 显示全部楼层
老的airx A7可以吗?用的好像是Marvell的芯片。
发表于 2024-6-22 00:43:22 | 显示全部楼层
那个模式怎么加上去的,是什么属性
发表于 2024-10-16 08:00:31 | 显示全部楼层
localkey现在还有办法获取么?
发表于 2024-12-25 10:58:16 | 显示全部楼层
每个DP ID都应该选择什么实体啊
发表于 2025-2-18 13:14:17 | 显示全部楼层
我之前秒新加湿器,秒新就跑路了,幸好论坛有大佬搞定了HA接入控制,请问,airX H8可以完全摆脱云端吗?我还想入个 H8 pro加湿器
另外,京东售前说airX是接入自己的APP 不知道涂鸦啥的
发表于 2025-7-4 12:59:09 | 显示全部楼层
airx除湿机D6可以接入ha吗?
GMT+8, 2026-1-15 21:43 , Processed in 0.344414 second(s), 15 queries , MemCached On.
