查看: 4446|回复: 8
[硬件DIY] Lenovo smartPlug se-341a智能插座刷固件接入HomeAssistant
发表于 2024-2-6 16:25:54 | 显示全部楼层 |阅读模式
在咸鱼上买的联想插座,App已不能用,到手拆机后刷esphome固件,已可以接入HomeAssistant,还要完善,时间控制功能还没有。
gpio5是控制继电器,gpio12是控制蓝色LED,gpio4是按键。
<font _mstmutation="1"><font _mstmutation="1">esphome:
  friendly_name: smartplug2
esp8266:
  board: esp07
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "****************" #esphome自动生成
ota:
  password: "88888888"  #自己设置的密码
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Smartplug2"   #自己设置的AP名称
captive_portal:
# web_server调试时用,可取消。
web_server:
  port: 80
binary_sensor:
- platform: gpio
  pin:
    number: GPIO4
    mode:
      input: true
      pullup: true
    inverted: true
  on_press:
    - switch.toggle: relay
- platform: status
switch:
  - platform: gpio
    pin: GPIO5
output:
  # Register the green LED as a dimmable output ....
  - platform: esp8266_pwm
    pin:
      number: GPIO12
      inverted: true
light:
  # ... and then make a light out of it.
  - platform: monochromatic
    name: "smartplug Green LED"
    output: smartplug_blue_led</font></font></font></font></font>
插座由10个卡扣固定
插座由10个卡扣固定
发现插座
发现插座
输入AP密码
输入AP密码
连接上插座
连接上插座
选择WiFi进行配网
选择WiFi进行配网
输入WiFi密码
输入WiFi密码
发表于 2024-2-6 17:39:39 来自手机 | 显示全部楼层
时间控制功能用hh自动化不就好了
xjol 手机认证
发表于 2024-4-4 19:09:05 | 显示全部楼层
开关状态和灯不联动
发表于 2024-4-4 19:23:34 | 显示全部楼层
这个我也有
web_server:
  port: 80
  auth:
    username: !secret web_server_username
    password: !secret web_server_password
time:
  - platform: homeassistant
    timezone: "Asia/Shanghai"
text_sensor:
  - platform: wifi_info
    ip_address:
      icon: mdi:ip
  - platform: wifi_signal
    name: "WiFi Signal Sensor"
    update_interval: 60s
button:
  - platform: restart
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO4
      mode: INPUT_PULLUP
      inverted: True
    name: "Smart Plug Button"
    on_press:
switch:
  - platform: gpio
    pin: GPIO5
    on_turn_on:
     then:
      - light.turn_on: indicator_light
    on_turn_off:
      then:
        - light.turn_off: indicator_light
light:
  - platform: binary
    output: relay_led
  - platform: status_led
    pin:
      number: GPIO14 #红色指示灯
      inverted: true
output:
  - platform: gpio
    pin:
      number: GPIO12 ##蓝色指示灯
      inverted: true
xjol 手机认证
发表于 2024-4-4 21:06:16 | 显示全部楼层
xjol 发表于 2024-4-4 19:09
开关状态和灯不联动
我的问题搞定
xjol 手机认证
发表于 2024-4-4 21:09:11 | 显示全部楼层
谢谢提供
jjcs 手机认证
发表于 2024-4-4 21:43:31 | 显示全部楼层
时间可以用esphome输入配合time组件,实现输入控制
发表于 2024-6-6 16:53:54 | 显示全部楼层
请问这个卖家有提供代码应该怎么刷入让插座能接入米家小爱呢?谢谢。
发表于 2025-2-7 15:35:20 | 显示全部楼层
怎么拆开的,硬翘么?
GMT+8, 2025-11-30 08:15 , Processed in 1.121463 second(s), 15 queries , MemCached On.
