查看: 10839|回复: 3
[求助] AppDaemon无法运行
noel
发表于 2018-1-12 22:11:07 | 显示全部楼层 |阅读模式
按照http://appdaemon.readthedocs.io/en/latest/INSTALL.htmlhttps://bbs.hassbian.com/thread-388-1-1.html帖子安装好了AppDaemon,但是一直无法运行成功。不知道是怎么回事?下面是日志信息,多谢了!!!
[email protected] - AppDaemon
   Loaded: loaded (/etc/systemd/system/[email protected]; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Fri 2018-01-12 14:04:23 UTC; 3min 4s ago
Main PID: 368 (code=exited, status=217/USER)
Jan 12 14:04:22 raspberrypi systemd[1]: Started AppDaemon.
Jan 12 14:04:23 raspberrypi systemd[1]: [email protected]: Main process exited, code=exited, status=217/USER
Jan 12 14:04:23 raspberrypi systemd[1]: [email protected]: Unit entered failed state.
Jan 12 14:04:23 raspberrypi systemd[1]: [email protected]: Failed with result 'exit-code'.
发表于 2018-2-4 22:20:54 | 显示全部楼层
我跟你差不多的问题 不知道你解决了没!!!
noel
 楼主| 发表于 2018-2-5 00:53:40 | 显示全部楼层
解决了~~~是读取权限的问题。
发表于 2018-3-29 12:17:39 | 显示全部楼层
解决了~~~是读取权限的问题。
如何设定??
GMT+8, 2025-12-25 05:55 , Processed in 0.047703 second(s), 8 queries , MemCached On.
