楼主: 冬瓜HA
pe安装x86原生HAOS的方法(虚拟机可用)内有PVE安装教程(16.3.2)
 楼主| 发表于 2024-3-31 15:16:09 | 显示全部楼层
qwe123zxc 发表于 2024-3-29 23:47
谢谢大佬分享,请问通过 VirtualBox 能不能安装呢,可以的话能不能出个教程。十分感谢。 ...
pe是万能版。
发表于 2024-4-1 19:49:15 | 显示全部楼层
安装完重启出现了这个,咋办啊
发表于 2024-4-1 20:03:28 | 显示全部楼层
发表于 2024-4-1 20:09:28 | 显示全部楼层
LETIT 发表于 2024-4-1 20:03
重装输入指令看进度又是这个
INFO: Using udev information from host
INFO: Starting local supervisor watchdog...
[__main__] Initializing Supervisor setup
[supervisor.bootstrap] Setting up coresys for machine: generic-x86-64
[supervisor.docker.supervisor] Attaching to Supervisor ghcr.nju.edu.cn/home-assistant/amd64-hassio-supervisor with version 2024.02.0
[supervisor.docker.supervisor] Connecting Supervisor to hassio-network
[supervisor.resolution.evaluate] Starting system evaluation with state initialize
[supervisor.resolution.evaluate] System evaluation complete
[__main__] Setting up Supervisor
[supervisor.api] Starting API on 172.30.32.2
[supervisor.hardware.monitor] Started Supervisor hardware monitor
[supervisor.dbus.manager] Connected to system D-Bus.
[supervisor.dbus.agent] Load dbus interface io.hass.os
[supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
[supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
[supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
[supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
[supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
[supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
[supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
[supervisor.host.services] Updating service information
[supervisor.host.sound] Updating PulseAudio information
[supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
[supervisor.host.network] Updating local network information
[supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
[supervisor.docker.monitor] Started docker events monitor
[supervisor.updater] Fetching update data from https://version.wghaos.com/x86-64-pc-release.json
[supervisor.docker.interface] Found ghcr.nju.edu.cn/home-assistant/amd64-hassio-cli versions: []
[supervisor.docker.interface] Attaching to ghcr.nju.edu.cn/home-assistant/amd64-hassio-cli with version 2023.11.0
[supervisor.plugins.cli] Starting CLI plugin
[supervisor.docker.cli] Starting CLI ghcr.nju.edu.cn/home-assistant/amd64-hassio-cli with version 2023.11.0 - 172.30.32.5
[supervisor.docker.interface] Found ghcr.nju.edu.cn/home-assistant/amd64-hassio-dns versions: []
[supervisor.docker.interface] Attaching to ghcr.nju.edu.cn/home-assistant/amd64-hassio-dns with version 2023.06.2
[supervisor.plugins.dns] Starting CoreDNS plugin
[supervisor.docker.dns] Starting DNS ghcr.nju.edu.cn/home-assistant/amd64-hassio-dns with version 2023.06.2 - 172.30.32.3
[supervisor.plugins.dns] Updated /etc/resolv.conf
[supervisor.docker.interface] Found ghcr.nju.edu.cn/home-assistant/amd64-hassio-audio versions: []
[supervisor.docker.interface] Attaching to ghcr.nju.edu.cn/home-assistant/amd64-hassio-audio with version 2023.12.0
[supervisor.plugins.audio] Starting Audio plugin
[supervisor.docker.audio] Starting Audio ghcr.nju.edu.cn/home-assistant/amd64-hassio-audio with version 2023.12.0 - 172.30.32.4
[supervisor.docker.interface] Found ghcr.nju.edu.cn/home-assistant/amd64-hassio-observer versions: []
[supervisor.docker.interface] Attaching to ghcr.nju.edu.cn/home-assistant/amd64-hassio-observer with version 2023.06.0
[supervisor.plugins.observer] Starting observer plugin
[supervisor.docker.observer] Starting Observer ghcr.nju.edu.cn/home-assistant/amd64-hassio-observer with version 2023.06.0 - 172.30.32.6
[supervisor.docker.interface] Found ghcr.nju.edu.cn/home-assistant/amd64-hassio-multicast versions: []
[supervisor.docker.interface] Attaching to ghcr.nju.edu.cn/home-assistant/amd64-hassio-multicast with version 2023.06.2
[supervisor.plugins.multicast] Starting Multicast plugin
[supervisor.docker.multicast] Starting Multicast ghcr.nju.edu.cn/home-assistant/amd64-hassio-multicast with version 2023.06.2 - Host
[supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
[supervisor.docker.interface] No version found for ghcr.nju.edu.cn/home-assistant/generic-x86-64-homeassistant
[supervisor.homeassistant.core] No Home Assistant Docker image ghcr.nju.edu.cn/home-assistant/generic-x86-64-homeassistant found.
[supervisor.docker.interface] Attaching to ghcr.nju.edu.cn/home-assistant/generic-x86-64-homeassistant with version landingpage
[supervisor.homeassistant.core] Using preinstalled landingpage
[supervisor.homeassistant.core] Starting HomeAssistant landingpage
[supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
[supervisor.docker.homeassistant] Starting Home Assistant ghcr.nju.edu.cn/home-assistant/generic-x86-64-homeassistant with version landingpage
[supervisor.os.manager] Detect Home Assistant Operating System 12.0 / BootSlot A
[supervisor.store.git] Cloning add-on https://gitcode.com/waxgourd/ha-core-addons repository
[supervisor.store.git] Cloning add-on https://gitcode.com/waxgourd/ha-git-addons repository
[supervisor.store.git] Cloning add-on https://gitcode.com/waxgourd/ha-esphome-addons repository
[supervisor.store] Loading add-ons from store: 80 all - 80 new - 0 remove
[supervisor.addons.manager] Found 0 installed add-ons
[supervisor.backups.manager] Found 0 backup files
[supervisor.discovery] Loaded 0 messages
[supervisor.ingress] Loaded 0 ingress sessions
[supervisor.resolution.check] Starting system checks with state setup
[supervisor.resolution.check] System checks complete
[supervisor.resolution.evaluate] Starting system evaluation with state setup
[supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
[__main__] Running Supervisor
[supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
[supervisor.supervisor] Fetching AppArmor profile https://version.wghaos.com/apparmor_stable.txt
[supervisor.host.apparmor] Adding/updating AppArmor profile: hassio-supervisor
[supervisor.supervisor] Update Supervisor to version 2024.03.1
[supervisor.docker.interface] Downloading docker image ghcr.nju.edu.cn/home-assistant/amd64-hassio-supervisor with tag 2024.03.1.
[supervisor.docker.interface] Can't install ghcr.nju.edu.cn/home-assistant/amd64-hassio-supervisor:2024.03.1: 500 Server Error for http+docker://localhost/v1.43/images/create?tag=2024.03.1&fromImage=ghcr.nju.edu.cn%2Fhome-assistant%2Famd64-hassio-supervisor&platform=linux%2Famd64: Internal Server Error ("received unexpected HTTP status: 500 Server Error")
[supervisor.resolution.module] Create new issue update_failed - supervisor / None
[supervisor.supervisor] Update of Supervisor failed: Can't install ghcr.nju.edu.cn/home-assistant/amd64-hassio-supervisor:2024.03.1: 500 Server Error for http+docker://localhost/v1.43/images/create?tag=2024.03.1&fromImage=ghcr.nju.edu.cn%2Fhome-assistant%2Famd64-hassio-supervisor&platform=linux%2Famd64: Internal Server Error ("received unexpected HTTP status: 500 Server Error")
CRITICAL (MainThread) [supervisor.core] Can't update Supervisor! This will break some Add-ons or affect future versions of Home Assistant!
[supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
[supervisor.addons.manager] Phase 'system' starting 0 add-ons
[supervisor.addons.manager] Phase 'services' starting 0 add-ons
[supervisor.core] Skipping start of Home Assistant
[supervisor.addons.manager] Phase 'application' starting 0 add-ons
[supervisor.misc.tasks] All core tasks are scheduled
[supervisor.core] Supervisor is up and running
[supervisor.homeassistant.core] Home Assistant setup
[supervisor.docker.interface] Updating image ghcr.nju.edu.cn/home-assistant/generic-x86-64-homeassistant:landingpage to ghcr.nju.edu.cn/home-assistant/generic-x86-64-homeassistant:2024.3.3
[supervisor.docker.interface] Downloading docker image ghcr.nju.edu.cn/home-assistant/generic-x86-64-homeassistant with tag 2024.3.3.
[supervisor.host.info] Updating local host information
[supervisor.resolution.check] Starting system checks with state running
[supervisor.resolution.checks.base] Run check for multiple_data_disks/system
[supervisor.resolution.checks.base] Run check for trust/supervisor
[supervisor.resolution.checks.base] Run check for docker_config/system
[supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
[supervisor.resolution.checks.base] Run check for no_current_backup/system
[supervisor.resolution.module] Create new suggestion create_full_backup - system / None
[supervisor.resolution.module] Create new issue no_current_backup - system / None
[supervisor.resolution.checks.base] Run check for security/core
[supervisor.resolution.checks.base] Run check for pwned/addon
[supervisor.resolution.checks.base] Run check for free_space/system
[supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
[supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
[supervisor.resolution.evaluate] Starting system evaluation with state running
[supervisor.host.manager] Host information reload completed
[supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not healthy - supervisor
[supervisor.docker.interface] Can't install ghcr.nju.edu.cn/home-assistant/generic-x86-64-homeassistant:2024.3.3: 500 Server Error for http+docker://localhost/v1.43/images/create?tag=2024.3.3&fromImage=ghcr.nju.edu.cn%2Fhome-assistant%2Fgeneric-x86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("received unexpected HTTP status: 500 Server Error")
[supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
发表于 2024-4-1 20:20:38 | 显示全部楼层
大佬,安装pve,都好,就是追踪不到家里的wifi设备了,有办法解决吗
 楼主| 发表于 2024-4-2 10:38:15 | 显示全部楼层
检查一下是否在一个网段
发表于 2024-4-2 12:43:11 | 显示全部楼层
冬瓜HA 发表于 2024-4-2 10:38
检查一下是否在一个网段
在一个网段,原来用docker装的可以用
 楼主| 发表于 2024-4-2 13:05:34 | 显示全部楼层
要用桥接的方式。
发表于 2024-4-2 18:06:22 | 显示全部楼层
大神好,我的ha主机系统这几天非常卡顿的厉害!重启到安全模式非常快,恢复到以前的正常时的备份也是卡!固件是硬件哪里出问题了呢?x86构架的HAOS系统!用的的英特尔NUC小主机,8G内存,64G固态硬盘,ping主机IP主机延时也不大
发表于 2024-4-2 18:08:36 | 显示全部楼层
换了主板和内存,用原来的硬盘还是相同的问题!有可能是硬盘,硬盘线的问题吗?不知道换块硬盘重做你的12.1的系统!再导入原来的备份行不行啊?还有就是你11.4的镜像730+兆,12.1系统只有不到500兆,功能有什么区别吗?在线等!麻烦看到请回复一下!
GMT+8, 2026-1-17 15:25 , Processed in 0.324995 second(s), 14 queries , MemCached On.
