查看: 4449|回复: 3
[求助] 1求大佬解答HomeKit一直搜索不到homeassistant
发表于 2018-1-12 15:26:17 | 显示全部楼层 |阅读模式
我开启了homebridge
starting version 3.2.4
[services.d] done.
Found user 'avahi' (UID 86) and group 'avahi' (GID 86).
Successfully dropped root privileges.
avahi-daemon 0.6.32 starting up.
WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
Successfully called chroot().
Successfully dropped remaining capabilities.
No service file found in /etc/avahi/services.
*** WARNING: Detected another IPv4 mDNS stack running on this host. This makes mDNS unreliable and is thus not recommended. ***
*** WARNING: Detected another IPv6 mDNS stack running on this host. This makes mDNS unreliable and is thus not recommended. ***
Joining mDNS multicast group on interface hassio.IPv6 with address fe80::42:89ff:fecd:b72.
New relevant interface hassio.IPv6 for mDNS.
Joining mDNS multicast group on interface hassio.IPv4 with address 172.30.32.1.
New relevant interface hassio.IPv4 for mDNS.
Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::7c96:5ad1:8349:c478.
New relevant interface wlan0.IPv6 for mDNS.
Joining mDNS multicast group on interface wlan0.IPv4 with address 192.168.1.105.
New relevant interface wlan0.IPv4 for mDNS.
Network interface enumeration completed.
Registering new address record for fe80::42:89ff:fecd:b72 on hassio.*.
Registering new address record for 172.30.32.1 on hassio.*.
Registering new address record for fe80::7c96:5ad1:8349:c478 on wlan0.*.
Registering new address record for 192.168.1.105 on wlan0.*.
Server startup complete. Host name is hassio.local. Local service cookie is 3349234212.
*** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** Please fix your application to use the native API of Avahi!
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
*** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** For more information see <http://0pointer.de/avahi-compat? ... =DNSServiceRegister>
[2018-1-12 15:19:53] Loaded plugin: homebridge-homeassistant
[2018-1-12 15:19:53] Registering platform 'homebridge-homeassistant.HomeAssistant'
[2018-1-12 15:19:53] ---
[2018-1-12 15:19:53] Loaded config.json with 0 accessories and 1 platforms.
[2018-1-12 15:19:53] Loading 1 platforms...
[2018-1-12 15:19:53] [HomeAssistant] Initializing HomeAssistant platform...
[2018-1-12 15:19:53] [HomeAssistant] Fetching HomeAssistant devices.
[2018-1-12 15:19:53] Loading 0 accessories...
[2018-1-12 15:19:53] [HomeAssistant] Received event: ping
[2018-1-12 15:19:53] [HomeAssistant] Initializing platform accessory 'hay_lamp'...
[2018-1-12 15:19:53] [HomeAssistant] Initializing platform accessory 'all lights'...
Setup Payload:
X-HM://0024YD3WTCJG9
Scan this code with your HomeKit app on your iOS device to pair with Homebridge:
Or enter this code with your HomeKit app on your iOS device to pair with Homebridge:
打开HomeKit一直在搜索。。。
发表于 2018-1-12 19:41:13 | 显示全部楼层
這問題我也發生過
而我的 homeassistant IP 是 192.168.1.3
但是 homebridge 卻一直連線到 192.168.1.4
即使重開機也沒用
最後是把 homebridge 移除重新安裝後才恢復正常
发表于 2018-1-26 08:53:58 来自手机 | 显示全部楼层
楼主解决了吗,我也搜索不到!
发表于 2018-1-29 20:08:39 来自手机 | 显示全部楼层
群晖系统的话,打开bonjour服务试试
GMT+8, 2026-1-7 22:14 , Processed in 0.187941 second(s), 14 queries , MemCached On.
