查看: 3337|回复: 0
[技术探讨] ads1115 接8266的代码
发表于 2024-1-29 14:24:36 | 显示全部楼层 |阅读模式
https://esphome.io/components/sensor/ads1115.html
The ads1115 sensor allows you to use your ADS1115 sigma-delta ADC sensors (datasheet, Adafruit_ADS1115) or your ADS1015 sigma-delta ADC sensors (datasheet, Adafruit_ADS1015) with ESPHome. First, setup an ADS1115 Hub for your ADS1115 sensor and then use this sensor platform to create individual sensors that will report the voltage to Home Assistant.
ads1115:  - address: 0x48sensor:  - platform: ads1115    multiplexer: 'A0_GND'    gain: 6.144    name: "ADS1115 Channel A0-GND"
GMT+8, 2026-1-15 18:25 , Processed in 0.175867 second(s), 8 queries , MemCached On.
