楼主: DDDear
[基础教程] 自动备份到阿里云盘
发表于 2024-1-19 14:24:06 | 显示全部楼层
735473216 发表于 2024-1-19 08:10
docker的数据都映射到/usr/mydocker下
webdav挂载跟楼主的方式类似,但是我用的是davfs2
定时运行下 ...
发表于 2024-1-19 15:39:46 | 显示全部楼层
DDDear 发表于 2024-1-19 08:20
你的体积这么大,压缩的时候可以把大体积的数据排除下
是的,我在tar中已经添加了exclude
我这个是备份了15、6个docker和docker-compose文件
HomeAssistant
 楼主| 发表于 2024-1-19 15:47:45 | 显示全部楼层
我这个是备份了15、6个docker和docker-compose文件 ...
原来如此,我也去搞一下
HomeAssistant
 楼主| 发表于 2024-1-19 15:50:26 | 显示全部楼层
定时运行下 ...
刚看到,感谢分享,学习一下
发表于 2024-1-22 11:31:53 | 显示全部楼层
大佬,目前我已自动备份,并且Rclone Backup可以看到添加的备份文件夹(图2)。但文件夹中看不到备份文件
日志:
[2024-01-22] [03:55:00] [INFO]: running "Sync Daily Backups"; /backup -> Alist:/阿里云盘(个人)/HA备份
[2024-01-22] [03:55:00] [INFO]: renamed 1 backups
2024/01/22 03:55:01 NOTICE: Automatic_Backup_2024-01-22.tar: Skipped copy as --dry-run is set (size 891.738Mi)
2024/01/22 03:55:01 NOTICE: Automatic_Backup_2024-01-20.tar: Skipped copy as --dry-run is set (size 716.348Mi)
2024/01/22 03:55:01 NOTICE: Automatic_Backup_2024-01-21.tar: Skipped copy as --dry-run is set (size 733.418Mi)
2024/01/22 03:55:01 NOTICE: .sync/FolderType: Skipped delete as --dry-run is set (size 81)
2024/01/22 03:55:01 NOTICE: .sync/IgnoreList: Skipped delete as --dry-run is set (size 805)
2024/01/22 03:55:01 NOTICE: .sync/StreamsList: Skipped delete as --dry-run is set (size 283)
2024/01/22 03:55:01 NOTICE: .sync/root_acl_entry: Skipped delete as --dry-run is set (size 0)
2024/01/22 03:55:01 NOTICE: 63c663d5.tar: Skipped delete as --dry-run is set (size 263.906Mi)
2024/01/22 03:55:01 NOTICE: .sync/Archive: Skipped remove directory as --dry-run is set
2024/01/22 03:55:01 NOTICE: .sync: Skipped remove directory as --dry-run is set
2024/01/22 03:55:01 NOTICE: .qsyncclient: Skipped remove directory as --dry-run is set
Transferred:               2.287 GiB / 2.287 GiB, 100%, 0 B/s, ETA -
Checks:                 5 / 5, 100%
Deleted:                5 (files), 3 (dirs)
Transferred:            3 / 3, 100%
Elapsed time:         1.1s
[2024-01-22] [03:55:01] [INFO]: unrenamed 1 backups
[2024-01-22] [03:55:01] [INFO]: finished in 1.47s
折腾好几天了,一直不知道是啥毛病。
HomeAssistant
 楼主| 发表于 2024-1-22 13:21:05 | 显示全部楼层
看日志是不是把dry_run开了,关上试试。
官网文档
--dry-run
Do a trial run with no permanent changes. Use this to see what rclone would do without actually doing it. Useful when setting up the sync command which deletes files in the destination.
进行一次试运行,不进行任何永久性更改。使用这个来看看rclone会做什么,而不实际去做。在设置同步命令时很有用,可避免删除目标中的文件。
发表于 2024-1-22 20:58:16 | 显示全部楼层
官网文档
--dry-run
目前web UI里默认配置是关闭的
HomeAssistant
 楼主| 发表于 2024-1-23 08:05:53 | 显示全部楼层
加载项设置那里呢
HomeAssistant
 楼主| 发表于 2024-1-23 08:24:16 | 显示全部楼层
623604438 发表于 2024-1-22 20:58
目前web UI里默认配置是关闭的
加载项设置那里呢
发表于 2024-1-23 13:28:24 | 显示全部楼层
DDDear 发表于 2024-1-23 08:24
加载项设置那里呢
可以了, 感谢大佬指点
GMT+8, 2025-11-9 08:06 , Processed in 0.263666 second(s), 10 queries , MemCached On.
