查看: 2238|回复: 1
[求助] HA中无法控制通过MIOT集成接入的Aqara开关
发表于 2024-1-14 22:25:01 | 显示全部楼层 |阅读模式
HA中无法控制通过MIOT集成接入的Aqara智能墙壁开关 D1零火线三键版,其他灯具、开关都没问题
Logger: custom_components.xiaomi_miot.switch
Source: custom_components/xiaomi_miot/__init__.py:1897
Integration: Xiaomi Miot Auto ([color=var(--primary-color)]documentation
, [color=var(--primary-color)]issues
First occurred: 19:38:18 (10 occurrences)
Last logged: 22:10:06
  • Aqara智能墙壁开关 D1客厅(lumi.switch.n3acn3): Set miot property {'did': 'lumi.54ef44100002fbfa', 'siid': 3, 'piid': 1, 'value': False} failed, result: {'did': 'lumi.54ef44100002fbfa', 'iid': '0.3.1', 'siid': 3, 'piid': 1, 'code': -704083036, 'exe_time': 0}
  • Aqara Smart Wall Switch D1 (No Neutral, Triple Rocker)(lumi.switch.l3acn3): Set miot property {'did': 'lumi.4cf8cdf3c8163c8', 'siid': 3, 'piid': 1, 'value': False} failed, result: {'did': 'lumi.4cf8cdf3c8163c8', 'iid': '0.3.1', 'siid': 3, 'piid': 1, 'code': -704002000, 'exe_time': 0}
  • Aqara智能墙壁开关 D1客厅(lumi.switch.n3acn3): Set miot property {'did': 'lumi.54ef44100002fbfa', 'siid': 3, 'piid': 1, 'value': False} failed, result: {'did': 'lumi.54ef44100002fbfa', 'iid': '0.3.1', 'siid': 3, 'piid': 1, 'code': -704002000, 'exe_time': 0}
  • Aqara智能墙壁开关 D1客厅(lumi.switch.n3acn3): Set miot property {'did': 'lumi.54ef44100002fbfa', 'siid': 4, 'piid': 1, 'value': False} failed, result: {'did': 'lumi.54ef44100002fbfa', 'iid': '0.4.1', 'siid': 4, 'piid': 1, 'code': -704002000, 'exe_time': 0}
  • Aqara Smart Wall Switch D1 (No Neutral, Triple Rocker)(lumi.switch.l3acn3): Set miot property {'did': 'lumi.4cf8cdf3c8163c8', 'siid': 4, 'piid': 1, 'value': True} failed, result: {'did': 'lumi.4cf8cdf3c8163c8', 'iid': '0.4.1', 'siid': 4, 'piid': 1, 'code': -704002000, 'exe_time': 0}
发表于 2024-1-14 22:38:31 | 显示全部楼层
我的情况是同一蓝牙设备,通过miot auto 接入的都不可用,在多模网关下的可用
GMT+8, 2025-12-17 07:21 , Processed in 0.098742 second(s), 9 queries , MemCached On.
