查看: 13525|回复: 13
[已解决] win10环境打不开homeassistant
发表于 2018-1-10 16:27:22 | 显示全部楼层 |阅读模式
333.png C:\Windows\system32>python -m homeassistant --open-ui
Config directory: C:\Users\馒头\AppData\Roaming\.homeassistant
  File "D:\Python\Python35\lib\site-packages\homeassistant\__main__.py", line 374, in <module>
    sys.exit(main())
  File "D:\Python\Python35\lib\site-packages\homeassistant\__main__.py", line 366, in main
    exit_code = setup_and_run_hass(config_dir, args)
  File "D:\Python\Python35\lib\site-packages\homeassistant\__main__.py", line 272, in setup_and_run_hass
    log_rotate_days=args.log_rotate_days, log_file=args.log_file)
  File "D:\Python\Python35\lib\site-packages\homeassistant\bootstrap.py", line 182, in from_config_file
    config_path, hass, verbose, skip_pip, log_rotate_days, log_file)
  File "D:\Python\Python35\lib\asyncio\base_events.py", line 466, in run_until_complete
    return future.result()
  File "D:\Python\Python35\lib\asyncio\futures.py", line 293, in result
    raise self._exception
  File "D:\Python\Python35\lib\asyncio\tasks.py", line 239, in _step
    result = coro.send(None)
  File "D:\Python\Python35\lib\site-packages\homeassistant\bootstrap.py", line 203, in async_from_config_file
    yield from async_mount_local_lib_path(config_dir, hass.loop)
  File "D:\Python\Python35\lib\site-packages\homeassistant\bootstrap.py", line 319, in async_mount_local_lib_path
    lib_dir = yield from async_get_user_site(deps_dir, loop=loop)
  File "D:\Python\Python35\lib\site-packages\homeassistant\util\package.py", line 103, in async_get_user_site
    lib_dir = stdout.decode().strip()
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xc2 in position 9: invalid continuation byte
输入python -m homeassistant --open-ui显示代码如上,在代码里面提示到的所有的文件添加默认gbk和utf-8也不行。
已解决,解决方法是取消中文路径!
发表于 2018-1-10 17:01:09 | 显示全部楼层
資料夾路徑不要有中文看看
 楼主| 发表于 2018-1-10 17:11:18 | 显示全部楼层
windgo 发表于 2018-1-10 17:01
資料夾路徑不要有中文看看
是不要user是中文的意思吗
 楼主| 发表于 2018-1-10 18:19:18 | 显示全部楼层
資料夾路徑不要有中文看看
大神啊,我千辛万苦改了馒头这中文路径,不提示这个问题了,现在在重新捣鼓中,不知道能不能成功
发表于 2018-1-10 18:55:47 | 显示全部楼层
翻滚吧暖菌 发表于 2018-1-10 18:19
大神啊,我千辛万苦改了馒头这中文路径,不提示这个问题了,现在在重新捣鼓中,不知道能不能成功 ...
我也怀疑路径中有中文导致的。
 楼主| 发表于 2018-1-10 19:00:56 | 显示全部楼层
Jones 发表于 2018-1-10 18:55
我也怀疑路径中有中文导致的。
是的是的,我解决好了,所以发了个帖子警示后来者。帖子贴上了。
Windows安装HomeAssistant菜鸟教程
 楼主| 发表于 2018-1-10 19:02:00 | 显示全部楼层
資料夾路徑不要有中文看看
非常感谢,已经安装成功,困扰我两天了。非常感谢!!!
 楼主| 发表于 2018-1-10 19:03:44 | 显示全部楼层
此贴已结,后来者如果有和我相同问题可以来我发的帖子看看,避免入同种坑。ps听说win下装homeassistant比较耗电?不解。
https://bbs.hassbian.com/thread-2396-1-1.html
发表于 2018-1-10 19:54:14 | 显示全部楼层
翻滚吧暖菌 发表于 2018-1-10 19:03
此贴已结,后来者如果有和我相同问题可以来我发的帖子看看,避免入同种坑。ps听说win下装homeassistant比较 ...
刚看到你贴吧的留言,问题应该是解决了。
HomeAssistant或者homebridge都是要24小时开机的,你说装在电脑里费不费电?
探索体验在windows上没问题,等你研究多了就会发现windows上限制太多,终归要到linux上搞。。
 楼主| 发表于 2018-1-10 19:58:57 | 显示全部楼层
25989406 发表于 2018-1-10 19:54
刚看到你贴吧的留言,问题应该是解决了。
HomeAssistant或者homebridge都是要24小时开机的,你说装在电脑 ...
那我用天猫精灵控制小米家居的时候电脑都要打开homeassistant吗?
GMT+8, 2025-8-28 14:59 , Processed in 0.058648 second(s), 7 queries , MemCached On.
