查看: 1763|回复: 1
[求助] 關於mqtt橋接
发表于 2023-12-25 22:32:38 | 显示全部楼层 |阅读模式
各位大大好
小弟想把區網的mqtt與外網的mqttT橋接在一起
但出現這行錯誤
2023-12-25 22:07:22.637 ERROR (MainThread) [homeassistant.config] Invalid config for [mqtt]: The 'broker' option near /config/configuration.yaml:12 has been removed, please remove it from your configuration @ data['mqtt'][0]. Got None. (See /config/configuration.yaml, line 12). Please check the docs at https://www.home-assistant.io/integrations/mqtt
2023-12-25 22:07:22.637 ERROR (MainThread) [homeassistant.setup] Setup failed for mqtt: Invalid config.
然後mqtt與tasmota會變成未載入
請問有人遇過嗎?
yybl 手机认证
发表于 2023-12-27 16:18:40 | 显示全部楼层
我用的是ui界面配置,没这个问题。你试试用ui界面配置mqtt呢
GMT+8, 2025-12-17 07:29 , Processed in 1.082057 second(s), 8 queries , MemCached On.
