查看: 2421|回复: 1
[流程系列] node-red代码向mqtt发送switch,homeassistant不能更改状态
发表于 2023-12-23 15:00:18 | 显示全部楼层 |阅读模式
msg.payload={
   "name":"38度开关",
   "command_topic": "homeassistant/switch/wanghe_switch_38/set",
   "state_topic":"homeassistant/switch/wanghe_switch_38/state",
   "unique_id":"wh101",
   "device":{
      "identifiers":[
         "wanghe101"
      "name":"热水器"
   "payload_on": "ON",
   "payload_off": "OFF",
   "state_on": "ON",
   "state_off": "OFF",
   "qos": 0,
   "retain": true,
   "command_on_template": "ON",
   "command_off_template": "OFF",
   "state_on_template": "ON",
   "state_off_template": "OFF",
   "value_template": "{{ value_json.state }}"
msg.topic = "homeassistant/switch/wanghe_switch_38/config";
msg.retain = true; // 保留配置主题
return msg;
请问上面node-red代码向mqtt发送switch,发送ON或OFF到home
assistant/switch/wanghe_switch_38/state主题可以更改状态,但在homeassistant中mqtt生成的switch中没法点击更改状态,添加代码   "optimistic": true后可以更改状态,但显示的开关样式为turn而不是switch,
请问如何解决让按钮可以更改状态并样式为switch
flows .rar (1.46 KB, 下载次数: 4)
发表于 2023-12-23 21:53:03 | 显示全部楼层
msg.payload = {
   "name":"38度开关",
   "state_topic":"homeassistant/switch/wanghe_switch_38/set",
   "unique_id": "wh101",
   "device": {
      "identifiers": [
         "wanghe101"
      "name": "热水器"
   "payload_on": "ON",
   "state_on": "ON",
   "state_off": "OFF",
return msg;
更改状态发送到msg.topic = "homeassistant/switch/wanghe_switch_38/set";就行了
GMT+8, 2025-12-3 07:36 , Processed in 1.059281 second(s), 16 queries , MemCached On.
