楼主 |
发表于 2023-12-20 13:36:12
显示全部楼层
[04:52:29] INFO: Using udev information from host
[04:52:29] INFO: Starting local supervisor watchdog...
23-12-20 04:52:31 INFO (MainThread) [__main__] Initializing Supervisor setup
23-12-20 04:52:31 INFO (MainThread) [supervisor.docker.network] Can't find Supervisor network, creating a new network
23-12-20 04:52:31 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: qemux86-64
23-12-20 04:52:31 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/amd64-hassio-supervisor with version 2023.11.6
23-12-20 04:52:31 INFO (MainThread) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
23-12-20 04:52:31 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
23-12-20 04:52:31 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-12-20 04:52:31 INFO (MainThread) [__main__] Setting up Supervisor
23-12-20 04:52:33 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
23-12-20 04:52:33 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
23-12-20 04:52:33 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
23-12-20 04:52:33 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
23-12-20 04:52:33 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
23-12-20 04:52:33 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
23-12-20 04:52:33 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
23-12-20 04:52:33 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
23-12-20 04:52:33 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
23-12-20 04:52:33 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
23-12-20 04:52:33 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
23-12-20 04:52:34 INFO (MainThread) [supervisor.host.services] Updating service information
23-12-20 04:52:34 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-12-20 04:52:34 WARNING (SyncWorker_1) [supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
23-12-20 04:52:34 INFO (MainThread) [supervisor.host.network] Updating local network information
23-12-20 04:52:34 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
23-12-20 12:52:35 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
23-12-20 12:52:35 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
23-12-20 12:52:36 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-cli versions: [<AwesomeVersion CalVer '2023.10.0'>]
23-12-20 12:52:36 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2023.10.0
23-12-20 12:52:36 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
23-12-20 12:52:37 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/amd64-hassio-cli with version 2023.10.0 - 172.30.32.5
23-12-20 12:52:37 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-dns versions: [<AwesomeVersion CalVer '2023.06.2'>]
23-12-20 12:52:37 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2023.06.2
23-12-20 12:52:37 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
23-12-20 12:52:38 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/amd64-hassio-dns with version 2023.06.2 - 172.30.32.3
23-12-20 12:52:38 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
23-12-20 12:52:38 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-audio versions: [<AwesomeVersion CalVer '2023.10.0'>]
23-12-20 12:52:38 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2023.10.0
23-12-20 12:52:38 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
23-12-20 12:52:39 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/amd64-hassio-audio with version 2023.10.0 - 172.30.32.4
23-12-20 12:52:39 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-observer versions: [<AwesomeVersion CalVer '2023.06.0'>]
23-12-20 12:52:39 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2023.06.0
23-12-20 12:52:39 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin
23-12-20 12:52:40 INFO (MainThread) [supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/amd64-hassio-observer with version 2023.06.0 - 172.30.32.6
23-12-20 12:52:40 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-multicast versions: [<AwesomeVersion CalVer '2023.06.2'>]
23-12-20 12:52:40 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2023.06.2
23-12-20 12:52:40 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
23-12-20 12:52:40 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/amd64-hassio-multicast with version 2023.06.2 - Host
23-12-20 12:52:40 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
23-12-20 12:52:40 INFO (MainThread) [supervisor.docker.interface] No version found for ghcr.io/home-assistant/qemux86-64-homeassistant
23-12-20 12:52:40 INFO (MainThread) [supervisor.homeassistant.core] No Home Assistant Docker image ghcr.io/home-assistant/qemux86-64-homeassistant found.
23-12-20 12:52:40 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
23-12-20 12:52:40 INFO (MainThread) [supervisor.homeassistant.core] Using preinstalled landingpage
23-12-20 12:52:40 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
23-12-20 12:52:40 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
23-12-20 12:52:41 INFO (MainThread) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
23-12-20 12:52:41 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 11.2 / BootSlot A
23-12-20 12:52:41 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/esphome/home-assistant-addon repository
23-12-20 12:52:41 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/hassio-addons/repository repository
23-12-20 12:52:41 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository
23-12-20 12:52:51 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/hassio-addons/repository repository: Cmd('git') failed due to: exit code(128)
cmdline: git clone -v --recursive --depth=1 --shallow-submodules -- https://github.com/hassio-addons/repository /data/addons/git/a0d7b954
stderr: 'Cloning into '/data/addons/git/a0d7b954'...
fatal: unable to access 'https://github.com/hassio-addons/repository/': Failure when receiving data from the peer
23-12-20 12:52:51 ERROR (MainThread) [supervisor.store] Can't retrieve data from https://github.com/hassio-addons/repository due to
23-12-20 12:52:51 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_remove - store / a0d7b954
23-12-20 12:52:51 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / a0d7b954
23-12-20 12:52:51 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/esphome/home-assistant-addon repository: Cmd('git') failed due to: exit code(128)
cmdline: git clone -v --recursive --depth=1 --shallow-submodules -- https://github.com/esphome/home-assistant-addon /data/addons/git/5c53de3b
stderr: 'Cloning into '/data/addons/git/5c53de3b'...
fatal: unable to access 'https://github.com/esphome/home-assistant-addon/': Failure when receiving data from the peer
23-12-20 12:52:51 ERROR (MainThread) [supervisor.store] Can't retrieve data from https://github.com/esphome/home-assistant-addon due to
23-12-20 12:52:51 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_remove - store / 5c53de3b
23-12-20 12:52:51 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / 5c53de3b
23-12-20 12:57:41 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/home-assistant/addons repository: Cmd('git') failed due to: exit code(128)
cmdline: git clone -v --recursive --depth=1 --shallow-submodules -- https://github.com/home-assistant/addons /data/addons/core
stderr: 'Cloning into '/data/addons/core'...
fatal: unable to access 'https://github.com/home-assistant/addons/': SSL connection timeout
23-12-20 12:57:41 ERROR (MainThread) [supervisor.store] Can't retrieve data from core due to
23-12-20 12:57:41 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_remove - store / core
23-12-20 12:57:41 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / core
23-12-20 12:57:41 INFO (MainThread) [supervisor.store] Loading add-ons from store: 0 all - 0 new - 0 remove
23-12-20 12:57:41 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
23-12-20 12:57:41 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
23-12-20 12:57:41 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
23-12-20 12:57:41 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
23-12-20 12:57:41 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
23-12-20 12:57:41 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-12-20 12:57:41 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
23-12-20 12:57:41 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-12-20 12:57:41 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
23-12-20 12:57:41 INFO (MainThread) [__main__] Running Supervisor
23-12-20 12:57:41 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
23-12-20 12:57:41 INFO (MainThread) [supervisor.supervisor] Fetching AppArmor profile https://version.home-assistant.io/apparmor_stable.txt
23-12-20 12:57:42 INFO (MainThread) [supervisor.host.apparmor] Adding/updating AppArmor profile: hassio-supervisor
23-12-20 12:57:43 INFO (MainThread) [supervisor.supervisor] Update Supervisor to version 2023.12.0
23-12-20 12:57:43 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/amd64-hassio-supervisor with tag 2023.12.0.
23-12-20 12:58:14 INFO (MainThread) [supervisor.core] Starting repair of Supervisor Environment
23-12-20 12:58:14 INFO (SyncWorker_2) [supervisor.docker.manager] Prune stale containers
23-12-20 12:58:14 INFO (SyncWorker_2) [supervisor.docker.manager] Prune stale images
23-12-20 12:58:14 INFO (SyncWorker_2) [supervisor.docker.manager] Prune stale builds
23-12-20 12:58:14 INFO (SyncWorker_2) [supervisor.docker.manager] Prune stale volumes
23-12-20 12:58:14 INFO (SyncWorker_2) [supervisor.docker.manager] Prune stale networks
23-12-20 12:58:14 INFO (SyncWorker_2) [supervisor.docker.manager] Fix stale container on hassio network
23-12-20 12:58:14 INFO (SyncWorker_2) [supervisor.docker.manager] Fix stale container on host network
23-12-20 12:58:14 INFO (MainThread) [supervisor.addons] Found 0 add-ons to repair
23-12-20 12:58:14 INFO (MainThread) [supervisor.supervisor] Repairing Supervisor 2023.11.6
23-12-20 13:09:45 WARNING (MainThread) [supervisor.jobs] 'Supervisor.restart' blocked from execution, system is not running - startup
s6-rc: info: service legacy-services: stopping
23-12-20 13:20:30 INFO (MainThread) [supervisor.api] Stopping API on 172.30.32.2
23-12-20 13:20:30 INFO (MainThread) [supervisor.misc.scheduler] Shutting down scheduled tasks
23-12-20 13:20:30 INFO (MainThread) [supervisor.docker.monitor] Stopped docker events monitor
23-12-20 13:20:30 INFO (MainThread) [supervisor.hardware.monitor] Stopped Supervisor hardware monitor
23-12-20 13:20:30 INFO (MainThread) [supervisor.dbus.manager] Closed conection to system D-Bus.
23-12-20 13:20:30 INFO (MainThread) [supervisor.core] Supervisor is down - 0
23-12-20 13:20:30 INFO (MainThread) [__main__] Closing Supervisor
[05:20:30] INFO: Watchdog restart after closing
[05:22:54] INFO: Using udev information from host
[05:22:54] INFO: Starting local supervisor watchdog...
23-12-20 05:22:56 INFO (MainThread) [__main__] Initializing Supervisor setup
23-12-20 05:22:56 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: qemux86-64
23-12-20 05:22:56 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/amd64-hassio-supervisor with version 2023.11.6
23-12-20 05:22:56 WARNING (SyncWorker_0) [supervisor.docker.manager] ghcr.io/home-assistant/amd64-hassio-supervisor not found for cleanup
23-12-20 05:22:56 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
23-12-20 05:22:56 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-12-20 05:22:56 INFO (MainThread) [__main__] Setting up Supervisor
23-12-20 05:22:57 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
23-12-20 05:22:57 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
23-12-20 05:22:57 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
23-12-20 05:22:57 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
23-12-20 05:22:57 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
23-12-20 05:22:57 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
23-12-20 05:22:57 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
23-12-20 05:22:57 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
23-12-20 05:22:57 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
23-12-20 05:22:57 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
23-12-20 05:22:57 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
23-12-20 05:22:57 INFO (MainThread) [supervisor.host.services] Updating service information
23-12-20 05:22:57 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-12-20 05:22:57 WARNING (SyncWorker_1) [supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
23-12-20 05:22:57 INFO (MainThread) [supervisor.host.network] Updating local network information
23-12-20 05:22:57 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
23-12-20 13:22:58 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
23-12-20 13:22:58 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
23-12-20 13:22:59 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2023.10.0
23-12-20 13:22:59 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
23-12-20 13:22:59 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_cli application
23-12-20 13:23:00 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/amd64-hassio-cli with version 2023.10.0 - 172.30.32.5
23-12-20 13:23:00 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2023.06.2
23-12-20 13:23:00 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
23-12-20 13:23:00 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning hassio_dns application
23-12-20 13:23:01 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/amd64-hassio-dns with version 2023.06.2 - 172.30.32.3
23-12-20 13:23:01 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
23-12-20 13:23:01 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2023.10.0
23-12-20 13:23:01 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
23-12-20 13:23:01 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning hassio_audio application
23-12-20 13:23:02 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/amd64-hassio-audio with version 2023.10.0 - 172.30.32.4
23-12-20 13:23:02 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2023.06.0
23-12-20 13:23:02 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2023.06.2
23-12-20 13:23:02 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
23-12-20 13:23:02 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning hassio_multicast application
23-12-20 13:23:03 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/amd64-hassio-multicast with version 2023.06.2 - Host
23-12-20 13:23:03 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
23-12-20 13:23:03 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
23-12-20 13:23:03 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
23-12-20 13:23:03 INFO (SyncWorker_0) [supervisor.docker.manager] Starting homeassistant
23-12-20 13:23:03 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 11.2 / BootSlot A
23-12-20 13:23:03 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository
23-12-20 13:23:03 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/hassio-addons/repository repository
23-12-20 13:23:03 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/esphome/home-assistant-addon repository
23-12-20 13:23:14 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/home-assistant/addons repository: Cmd('git') failed due to: exit code(128)
fatal: unable to access 'https://github.com/home-assistant/addons/': Failure when receiving data from the peer
23-12-20 13:23:14 ERROR (MainThread) [supervisor.store] Can't retrieve data from core due to
23-12-20 13:23:14 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_remove - store / core
23-12-20 13:23:14 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / core
23-12-20 13:23:14 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/esphome/home-assistant-addon repository: Cmd('git') failed due to: exit code(128)
23-12-20 13:23:14 ERROR (MainThread) [supervisor.store] Can't retrieve data from https://github.com/esphome/home-assistant-addon due to
23-12-20 13:23:14 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_remove - store / 5c53de3b
23-12-20 13:23:14 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / 5c53de3b
23-12-20 13:23:14 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/hassio-addons/repository repository: Cmd('git') failed due to: exit code(128)
23-12-20 13:23:14 ERROR (MainThread) [supervisor.store] Can't retrieve data from https://github.com/hassio-addons/repository due to
23-12-20 13:23:14 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_remove - store / a0d7b954
23-12-20 13:23:14 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / a0d7b954
23-12-20 13:23:14 INFO (MainThread) [supervisor.store] Loading add-ons from store: 0 all - 0 new - 0 remove
23-12-20 13:23:14 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
23-12-20 13:23:14 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
23-12-20 13:23:14 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
23-12-20 13:23:14 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
23-12-20 13:23:14 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
23-12-20 13:23:14 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-12-20 13:23:14 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
23-12-20 13:23:14 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-12-20 13:23:14 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
23-12-20 13:23:14 INFO (MainThread) [__main__] Running Supervisor
23-12-20 13:23:14 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
23-12-20 13:23:14 INFO (MainThread) [supervisor.supervisor] Fetching AppArmor profile https://version.home-assistant.io/apparmor_stable.txt
23-12-20 13:23:14 INFO (MainThread) [supervisor.host.apparmor] Adding/updating AppArmor profile: hassio-supervisor
23-12-20 13:23:14 INFO (MainThread) [supervisor.supervisor] Update Supervisor to version 2023.12.0
23-12-20 13:23:14 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/amd64-hassio-supervisor with tag 2023.12.0.
以上是完整log日志文件内容 |
