查看: 3204|回复: 2
[技术探讨] 升级到23.12版本后读取树莓派CPU的温度不可用了
发表于 2023-12-16 22:12:08 | 显示全部楼层 |阅读模式
有知道怎么改配置的大佬吗
lswq 手机认证
发表于 2024-2-13 14:29:57 | 显示全部楼层
config 结构换啦
command_line:
  - sensor:
      name: CPU Temperature
      command: "cat /sys/class/thermal/thermal_zone0/temp"
      # If errors occur, make sure configuration file is encoded as UTF-8
      unit_of_measurement: "°C"
      value_template: "{{ value | multiply(0.001) | round(1) }}"
 楼主| 发表于 2024-2-14 01:17:09 | 显示全部楼层
lswq 发表于 2024-2-13 14:29
config 结构换啦
昨天才发现的,系统已经自带温度显现了,自行启用即可
GMT+8, 2026-1-15 18:17 , Processed in 1.293117 second(s), 6 queries , MemCached On.
