查看: 3175|回复: 7
[新手导航] 『求助』esphome 无法在web页面编译,只能命令行编译
发表于 2023-12-16 21:01:24 | 显示全部楼层 |阅读模式
求各位大佬指点迷津
进入docker内部的命令行敲命令可以运行,但是在web页 点 install 就不行,现在只能去build目录拿到编译完成的固件在https://web.esphome.io/手动烧录这两个日志是前后脚生成的,网络环境啥的都没变,也没有开代理
yaml文件内容
esphome:
  friendly_name: ESPHome Web 74dd2c
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "HYGE5n0+a0xrDttpNPcIucnD9pPQKN6fireuoHoWwME="
ota:
  password: "6ba69c8e9a7e00ebc166c37f23deaba1"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Esphome-Web-74Dd2C"
    password: "u8ZCO5pH8nCA"
captive_portal:
命令行
<blockquote>root@esphome:/config# esphome run esphome-web-74dd2c.yaml
在web页面
INFO ESPHome 2023.11.6
INFO Reading configuration /config/esphome-web-74dd2c.yaml...
INFO Generating C++ source...
INFO Core config or version changed, cleaning build files...
INFO Deleting /config/.esphome/build/esphome-web-74dd2c/.pioenvs
INFO Deleting /config/.esphome/build/esphome-web-74dd2c/.piolibdeps
INFO Compiling app...
Processing esphome-web-74dd2c (board: esp32dev; framework: arduino; platform: platformio/[email protected])
Library Manager: Installing esphome/AsyncTCP-esphome @ 2.0.1
INFO Installing esphome/AsyncTCP-esphome @ 2.0.1
Unpacking  [####################################]  100%
Library Manager: [email protected] has been installed!
INFO [email protected] has been installed!
Library Manager: Installing esphome/ESPAsyncWebServer-esphome @ 3.1.0
INFO Installing esphome/ESPAsyncWebServer-esphome @ 3.1.0
Library Manager: Resolving dependencies...
INFO Resolving dependencies...
Library Manager: Installing esphome/noise-c @ 0.1.4
INFO Installing esphome/noise-c @ 0.1.4
Library Manager: Installing esphome/libsodium @ 1.10018.1
INFO Installing esphome/libsodium @ 1.10018.1
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
 - toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
Library Manager: Installing WiFi
Library Manager: Warning! More than one package has been found by WiFi requirements:
Library Manager:  - arduino-libraries/[email protected]
Library Manager:  - mbed-zrem/[email protected]+sha.a446a6e2d3ce
Library Manager: Please specify detailed REQUIREMENTS using package owner and version (shown above) to avoid name conflicts
Unpacking 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100%
Library Manager: Installing FS
Warning! Could not find the package with 'FS' requirements for your system 'linux_x86_64'
Library Manager: Installing Update
Warning! Could not find the package with 'Update' requirements for your system 'linux_x86_64'
Library Manager: Installing DNSServer
Library Manager: Installing ESPmDNS
Warning! Could not find the package with 'ESPmDNS' requirements for your system 'linux_x86_64'
Dependency Graph
|-- AsyncTCP-esphome @ 2.0.1
|-- WiFi @ 1.2.7
|-- ESPAsyncWebServer-esphome @ 3.1.0
|-- DNSServer @ 1.1.0
|-- noise-c @ 0.1.4
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/components/api/api_connection.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/components/api/api_frame_helper.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/components/api/api_pb2.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/components/api/api_pb2_service.cpp.o
In file included from src/esphome/components/socket/socket.h:6,
                 from src/esphome/components/api/api_frame_helper.h:14,
                 from src/esphome/components/api/api_connection.h:3,
                 from src/esphome/components/api/api_connection.cpp:1:
src/esphome/components/socket/headers.h:156:10: fatal error: sys/ioctl.h: No such file or directory
 #include <sys/ioctl.h>
                 from src/esphome/components/api/api_frame_helper.cpp:1:
compilation terminated.
In file included from src/esphome/components/api/proto.h:4,
                 from src/esphome/components/api/api_pb2.h:5,
                 from src/esphome/components/api/api_pb2.cpp:3:
src/esphome/core/log.h:14:10: fatal error: esp_err.h: No such file or directory
* Looking for esp_err.h dependency? Check our library registry!
* CLI  > platformio lib search "header:esp_err.h"
* Web  > https://registry.platformio.org/search?q=header:esp_err.h
 #include <esp_err.h>
                 from src/esphome/components/api/api_pb2_service.h:5,
                 from src/esphome/components/api/api_pb2_service.cpp:3:
*** [.pioenvs/esphome-web-74dd2c/src/esphome/components/api/api_pb2.cpp.o] Error 1
*** [.pioenvs/esphome-web-74dd2c/src/esphome/components/api/api_frame_helper.cpp.o] Error 1
*** [.pioenvs/esphome-web-74dd2c/src/esphome/components/api/api_pb2_service.cpp.o] Error 1
*** [.pioenvs/esphome-web-74dd2c/src/esphome/components/api/api_connection.cpp.o] Error 1
========================= [FAILED] Took 24.78 seconds =========================
 楼主| 发表于 2023-12-16 21:04:07 | 显示全部楼层
命令行的日志怎么老是发不出来,单独发到二楼吧
INFO Reading configuration esphome-web-74dd2c.yaml...
INFO Deleting .esphome/build/esphome-web-74dd2c/.pioenvs
INFO Deleting .esphome/build/esphome-web-74dd2c/.piolibdeps
Dependency Graph
|-- WiFi @ 2.0.0
|-- FS @ 2.0.0
|-- Update @ 2.0.0
|-- DNSServer @ 2.0.0
|-- ESPmDNS @ 2.0.0
|-- noise-c @ 0.1.4
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/components/api/api_server.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/components/api/list_entities.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/components/api/proto.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/components/api/subscribe_state.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/components/api/user_services.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/components/captive_portal/captive_portal.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/components/esp32/core.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/components/esp32/gpio.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/components/esp32/preferences.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/components/logger/logger.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/components/md5/md5.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/components/mdns/mdns_component.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/components/mdns/mdns_esp32.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/components/mdns/mdns_esp8266.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/components/mdns/mdns_host.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/components/mdns/mdns_libretiny.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/components/mdns/mdns_rp2040.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/components/network/util.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/components/ota/ota_backend_arduino_esp32.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/components/ota/ota_backend_arduino_esp8266.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/components/ota/ota_backend_arduino_libretiny.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/components/ota/ota_backend_arduino_rp2040.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/components/ota/ota_backend_esp_idf.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/components/ota/ota_component.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/components/socket/bsd_sockets_impl.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/components/socket/lwip_raw_tcp_impl.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/components/socket/lwip_sockets_impl.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/components/socket/socket.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/components/web_server_base/web_server_base.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/components/wifi/wifi_component.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/components/wifi/wifi_component_esp32_arduino.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/components/wifi/wifi_component_esp8266.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/components/wifi/wifi_component_esp_idf.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/components/wifi/wifi_component_libretiny.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/components/wifi/wifi_component_pico_w.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/core/application.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/core/color.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/core/component.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/core/component_iterator.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/core/controller.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/core/entity_base.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/core/helpers.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/core/log.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/core/scheduler.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/core/string_ref.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/core/time.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/esphome/core/util.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/src/main.cpp.o
Building .pioenvs/esphome-web-74dd2c/bootloader.bin
Generating partitions .pioenvs/esphome-web-74dd2c/partitions.bin
Creating esp32 image...
Successfully created esp32 image.
Compiling .pioenvs/esphome-web-74dd2c/lib17b/AsyncTCP-esphome/AsyncTCP.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/lib789/WiFi/WiFi.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/lib789/WiFi/WiFiAP.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/lib789/WiFi/WiFiClient.cpp.o
Archiving .pioenvs/esphome-web-74dd2c/lib17b/libAsyncTCP-esphome.a
Compiling .pioenvs/esphome-web-74dd2c/lib789/WiFi/WiFiGeneric.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/lib789/WiFi/WiFiMulti.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/lib789/WiFi/WiFiSTA.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/lib789/WiFi/WiFiScan.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/lib789/WiFi/WiFiServer.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/lib789/WiFi/WiFiUdp.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/lib790/FS/FS.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/lib790/FS/vfs_api.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/liba61/Update/HttpsOTAUpdate.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/liba61/Update/Updater.cpp.o
Archiving .pioenvs/esphome-web-74dd2c/lib789/libWiFi.a
Compiling .pioenvs/esphome-web-74dd2c/libbfe/ESPAsyncWebServer-esphome/AsyncEventSource.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/libbfe/ESPAsyncWebServer-esphome/AsyncWebSocket.cpp.o
Archiving .pioenvs/esphome-web-74dd2c/lib790/libFS.a
Compiling .pioenvs/esphome-web-74dd2c/libbfe/ESPAsyncWebServer-esphome/WebAuthentication.cpp.o
Archiving .pioenvs/esphome-web-74dd2c/liba61/libUpdate.a
Compiling .pioenvs/esphome-web-74dd2c/libbfe/ESPAsyncWebServer-esphome/WebHandlers.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/libbfe/ESPAsyncWebServer-esphome/WebRequest.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/libbfe/ESPAsyncWebServer-esphome/WebResponses.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/libbfe/ESPAsyncWebServer-esphome/WebServer.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/lib43b/DNSServer/DNSServer.cpp.o
Archiving .pioenvs/esphome-web-74dd2c/lib43b/libDNSServer.a
Compiling .pioenvs/esphome-web-74dd2c/libe94/ESPmDNS/ESPmDNS.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/lib606/libsodium/crypto_aead/chacha20poly1305/sodium/aead_chacha20poly1305.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib606/libsodium/crypto_core/ed25519/core_ed25519.c.o
Archiving .pioenvs/esphome-web-74dd2c/libbfe/libESPAsyncWebServer-esphome.a
Compiling .pioenvs/esphome-web-74dd2c/lib606/libsodium/crypto_core/ed25519/core_ristretto255.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib606/libsodium/crypto_core/ed25519/ref10/ed25519_ref10.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib606/libsodium/crypto_hash/crypto_hash.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib606/libsodium/crypto_hash/sha256/cp/hash_sha256_cp.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib606/libsodium/crypto_hash/sha256/hash_sha256.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib606/libsodium/crypto_onetimeauth/crypto_onetimeauth.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib606/libsodium/crypto_onetimeauth/poly1305/donna/poly1305_donna.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib606/libsodium/crypto_onetimeauth/poly1305/onetimeauth_poly1305.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib606/libsodium/crypto_scalarmult/crypto_scalarmult.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib606/libsodium/crypto_scalarmult/curve25519/ref10/x25519_ref10.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib606/libsodium/crypto_scalarmult/curve25519/scalarmult_curve25519.c.o
Archiving .pioenvs/esphome-web-74dd2c/libe94/libESPmDNS.a
Compiling .pioenvs/esphome-web-74dd2c/lib606/libsodium/crypto_stream/chacha20/ref/chacha20_ref.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib606/libsodium/crypto_stream/chacha20/stream_chacha20.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib606/libsodium/crypto_stream/crypto_stream.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib606/libsodium/crypto_verify/sodium/verify.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib606/libsodium/sodium/codecs.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib606/libsodium/sodium/core.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib606/libsodium/sodium/runtime.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib606/libsodium/sodium/utils.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib61b/noise-c/backend/openssl/cipher-aesgcm.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib61b/noise-c/backend/ref/cipher-aesgcm.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib61b/noise-c/backend/ref/cipher-chachapoly.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib61b/noise-c/backend/ref/dh-curve25519.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib61b/noise-c/backend/ref/hash-blake2b.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib61b/noise-c/backend/ref/hash-blake2s.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib61b/noise-c/backend/ref/hash-sha256.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib61b/noise-c/backend/sodium/cipher-aesgcm.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib61b/noise-c/backend/sodium/cipher-chachapoly.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib61b/noise-c/backend/sodium/dh-curve25519.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib61b/noise-c/backend/sodium/hash-blake2b.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib61b/noise-c/backend/sodium/hash-sha256.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib61b/noise-c/crypto/aes/rijndael-alg-fst.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib61b/noise-c/crypto/blake2/blake2b.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib61b/noise-c/crypto/blake2/blake2s.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib61b/noise-c/crypto/chacha/chacha.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib61b/noise-c/crypto/donna/curve25519-donna-c64.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib61b/noise-c/crypto/donna/curve25519-donna.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib61b/noise-c/crypto/donna/poly1305-donna.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib61b/noise-c/crypto/sha2/sha256.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib61b/noise-c/crypto/sha2/sha512.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib61b/noise-c/crypto/x25519/x25519.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib61b/noise-c/protocol/cipherstate.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib61b/noise-c/protocol/dhstate.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib61b/noise-c/protocol/errors.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib61b/noise-c/protocol/handshakestate.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib61b/noise-c/protocol/hashstate.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib61b/noise-c/protocol/internal.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib61b/noise-c/protocol/names.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib61b/noise-c/protocol/patterns.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib61b/noise-c/protocol/rand_os.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib61b/noise-c/protocol/rand_sodium.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib61b/noise-c/protocol/randstate.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib61b/noise-c/protocol/signstate.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib61b/noise-c/protocol/symmetricstate.c.o
Compiling .pioenvs/esphome-web-74dd2c/lib61b/noise-c/protocol/util.c.o
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/Esp.cpp.o
Archiving .pioenvs/esphome-web-74dd2c/lib61b/libnoise-c.a
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/FirmwareMSC.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/FunctionalInterrupt.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/HWCDC.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/HardwareSerial.cpp.o
Archiving .pioenvs/esphome-web-74dd2c/lib606/libsodium.a
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/IPAddress.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/IPv6Address.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/MD5Builder.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/Print.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/Stream.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/StreamString.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/Tone.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/USB.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/USBCDC.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/USBMSC.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/WMath.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/WString.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/base64.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/cbuf.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/esp32-hal-adc.c.o
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/esp32-hal-bt.c.o
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/esp32-hal-cpu.c.o
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/esp32-hal-dac.c.o
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/esp32-hal-gpio.c.o
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/esp32-hal-i2c-slave.c.o
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/esp32-hal-i2c.c.o
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/esp32-hal-ledc.c.o
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/esp32-hal-matrix.c.o
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/esp32-hal-misc.c.o
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/esp32-hal-psram.c.o
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/esp32-hal-rgb-led.c.o
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/esp32-hal-rmt.c.o
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/esp32-hal-sigmadelta.c.o
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/esp32-hal-spi.c.o
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/esp32-hal-time.c.o
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/esp32-hal-timer.c.o
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/esp32-hal-tinyusb.c.o
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/esp32-hal-touch.c.o
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/esp32-hal-uart.c.o
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/firmware_msc_fat.c.o
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/libb64/cdecode.c.o
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/libb64/cencode.c.o
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/main.cpp.o
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/stdlib_noniso.c.o
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/wiring_pulse.c.o
Compiling .pioenvs/esphome-web-74dd2c/FrameworkArduino/wiring_shift.c.o
Archiving .pioenvs/esphome-web-74dd2c/libFrameworkArduino.a
Linking .pioenvs/esphome-web-74dd2c/firmware.elf
RAM:   [=         ]  12.4% (used 40592 bytes from 327680 bytes)
Flash: [=====     ]  49.1% (used 900485 bytes from 1835008 bytes)
Building .pioenvs/esphome-web-74dd2c/firmware.bin
esp32_create_combined_bin([".pioenvs/esphome-web-74dd2c/firmware.bin"], [".pioenvs/esphome-web-74dd2c/firmware.elf"])
Wrote 0xed410 bytes to file /config/.esphome/build/esphome-web-74dd2c/.pioenvs/esphome-web-74dd2c/firmware-factory.bin, ready to flash to offset 0x0
========================================================================================================= [SUCCESS] Took 36.45 seconds =========================================================================================================
INFO Successfully compiled program.
INFO Resolving IP address of esphome-web-74dd2c.local
ERROR Error resolving IP address of esphome-web-74dd2c.local. Is it connected to WiFi?
ERROR (If this error persists, please set a static IP address: https://esphome.io/components/wifi.html#manual-ips)
ERROR Error resolving IP address: Error resolving address with mDNS: Did not respond. Maybe the device is offline., [Errno -3] Temporary failure in name resolution
root@esphome:/config# ^C
root@esphome:/config# printenv
HOSTNAME=esphome
PWD=/config
TZ=Asia/Shangha1
HOME=/root
USERNAME=
LANG=C.UTF-8
PASSWORD=
TERM=xterm
PLATFORMIO_GLOBALLIB_DIR=/piolibs
SHLVL=1
LC_ALL=C.UTF-8
PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
_=/usr/bin/printenv
OLDPWD=/config/.esphome/platformio/packages/framework-arduinoespressif32/libraries/WiFi/src
发表于 2023-12-17 16:22:20 | 显示全部楼层
你的ESPHOME 是安装 在什么机子上?X86 还是ARM???
 楼主| 发表于 2023-12-25 13:03:48 | 显示全部楼层
x86 ,虚拟机 ubuntu 系统里的docker内
发表于 2023-12-25 15:18:04 | 显示全部楼层
多试几次有可能 是网络问题。 也有可能 是ESPHOME服务器 或者他们的库有问题。 多试几次就应该正常了。 记得出国旅游
 楼主| 发表于 2024-1-3 23:07:49 | 显示全部楼层
ekingfan 发表于 2023-12-25 15:18
多试几次有可能 是网络问题。 也有可能 是ESPHOME服务器 或者他们的库有问题。 多试几次就应该正常了。  ...
又测试好几次,科学上网也准备了,还是一样的报错完全没有头绪
 楼主| 发表于 2024-1-4 23:05:11 | 显示全部楼层
不知什么原因,现在可以用了,虽然编译ESP32-C3还是报错但是ESP32没问题了
 楼主| 发表于 2024-1-4 23:11:45 | 显示全部楼层
记录一下处理错误的方法供后人参考
如果报错类似   undefined reference to `vtable for esphome::bme680_bsec::BME680BSECComponent
清除编译文件然后重新编译就行了 (根据https://github.com/esphome/issues/issues/2586
GMT+8, 2025-12-8 10:30 , Processed in 0.923166 second(s), 11 queries , MemCached On.
