查看: 3145|回复: 6
[技术探讨] 捡垃圾插排修改固件
发表于 2023-12-14 22:22:33 | 显示全部楼层 |阅读模式
substitutions:
  node_name: cmcc-powerboard
  node_id: cmcc_powerboard
  node_name_friendly: ${node_name}
esphome:
esp8266:
  board: esp_wroom_02
  restore_from_flash: false
wifi:
  ap:
    ssid: "Hotspot"
    password: "12345678"
captive_portal:
logger:
    level: DEBUG
api:
ota:
web_server:
  port: 80
#插排电源按钮
binary_sensor:
  - platform: gpio
    internal: true
    pin:
      number: 4
      inverted: true
      mode:
        input: true
        pullup: true
    on_press:
      then:
        - switch.toggle: switch_button
#通电指示灯
light:
  - platform: binary
    output: poweron_output_gpio5
    internal: true
  - platform: binary
    internal: true
    output: buled1
  - platform: binary
    internal: true
    output: redled1
interval:
  - interval: 1s
    then:
      if:
        condition:
          wifi.connected:
        then:
          - light.turn_on: buled
          - light.turn_off: redled
        else:
          - light.turn_off: buled
          - light.turn_on: redled
output:
  - platform: gpio
    pin:
      number: 15
      inverted: true
  - platform: gpio
    pin: GPIO16
    inverted: true
  - platform: gpio
    pin: GPIO14
    inverted: true
  - id: poweron_output_gpio5
    platform: gpio
    pin:
      number: 5
      inverted: true
button:
  - platform: output
    output: output_gpio15
    duration: 50ms
    internal: true
switch:
  #虚拟开关
  - platform: template
    restore_mode: RESTORE_DEFAULT_ON
    lambda: |-
      return id(switch_gpio0).state ? true: false;
    turn_on_action:
      - switch.turn_on: switch_gpio0
      - switch.turn_on: switch_gpio12
      - light.turn_on: light_power_status_output_gpio5
    turn_off_action:
      - switch.turn_off: switch_gpio12
      - switch.turn_off: switch_gpio0
      - light.turn_off: light_power_status_output_gpio5
  #干路继电器
  - platform: gpio
    pin:
      number: 0
      inverted: true
    on_turn_on:
      then:
        - button.press: button_output_gpio15
    on_turn_off:
  #分路继电器
  - platform: gpio
    pin:
      number: 12
      inverted: true
    on_turn_on:
      then:
    on_turn_off:
#重启
  # - platform: restart
  #   name: "${node_name_friendly}-Restart"
  #   id: ${node_id}_restart
  # #重置
  # - platform: factory_reset
  #   name: ${node_name}-factory-reset
  #   id: ${node_id}_factory_reset
1.zip
1.05 KB, 下载次数: 18
参与人数 1金钱 +16 收起 理由
sorrypqa + 16 感谢楼主分享!
发表于 2023-12-15 10:54:44 | 显示全部楼层
大佬,可否公布以下型号呢
发表于 2023-12-15 11:22:47 | 显示全部楼层
谢谢分享!现在对使用8266和普通继电器的插排没兴趣(家里10来个4控插排本身每年要消耗300度电),现在都用怕了,准备打板搞ESP32+多路磁保持继电器改装普通插排
发表于 2023-12-15 16:31:37 | 显示全部楼层
sorrypqa 发表于 2023-12-15 11:22
谢谢分享!现在对使用8266和普通继电器的插排没兴趣(家里10来个4控插排本身每年要消耗300度电),现在都用 ...
你这样,可以省电吗?多搞2套呗,我想要,
发表于 2023-12-15 22:09:59 | 显示全部楼层
16路50A磁保持继电器的控制器,全开平均耗电0.5W,如果是16路30A普通继电器的控制器全开耗电16W,这就差别,我之前买的4控插排,全开耗电4W左右,我的锐龙笔记本上网听歌耗电才9W,这破插排耗电4W,这怎么忍受???
发表于 2023-12-16 00:55:21 | 显示全部楼层
楼主用的什么编程看着不错能告诉我一下吗
vitc 手机认证
发表于 2023-12-17 20:24:27 | 显示全部楼层
用的esphome
GMT+8, 2025-12-16 00:00 , Processed in 1.025508 second(s), 16 queries , MemCached On.
