查看: 2117|回复: 2
[求助] vmware安装homeassistant失败
发表于 2023-12-6 22:14:40 | 显示全部楼层 |阅读模式
INFO: Using udev information from host
INFO: Starting local supervisor watchdog...
[__main__] Initializing Supervisor setup
[supervisor.docker.network] Can't find Supervisor network, creating a new network
[supervisor.bootstrap] Seting up coresys for machine: qemux86-64
[supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/amd64-hassio-supervisor with version 2023.11.6
[supervisor.docker.supervisor] Connecting Supervisor to hassio-network
[supervisor.resolution.evaluate] Starting system evaluation with state initialize
[supervisor.resolution.evaluate] System evaluation complete
[__main__] Setting up Supervisor
[supervisor.api] Starting API on 172.30.32.2
[supervisor.hardware.monitor] Started Supervisor hardware monitor
[supervisor.dbus.manager] Connected to system D-Bus.
[supervisor.dbus.agent] Load dbus interface io.hass.os
[supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
[supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
[supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
[supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
[supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
[supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
[supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
[supervisor.host.services] Updating service information
[supervisor.host.sound] Updating PulseAudio information
[supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
[supervisor.host.network] Updating local network information
[supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
[supervisor.docker.monitor] Started docker events monitor
[supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
[supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-cli versions: []
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2023.10.0
[supervisor.plugins.cli] Starting CLI plugin
[supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/amd64-hassio-cli with version 2023.10.0 - 172.30.32.5
[supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-dns versions: []
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2023.06.2
[supervisor.plugins.dns] Starting CoreDNS plugin
[supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/amd64-hassio-dns with version 2023.06.2 - 172.30.32.3
[supervisor.plugins.dns] Updated /etc/resolv.conf
[supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-audio versions: []
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2023.10.0
[supervisor.plugins.audio] Starting Audio plugin
[supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/amd64-hassio-audio with version 2023.10.0 - 172.30.32.4
[supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-observer versions: []
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2023.06.0
[supervisor.plugins.observer] Starting observer plugin
[supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/amd64-hassio-observer with version 2023.06.0 - 172.30.32.6
[supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-multicast versions: []
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2023.06.2
[supervisor.plugins.multicast] Starting Multicast plugin
[supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/amd64-hassio-multicast with version 2023.06.2 - Host
[supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
[supervisor.docker.interface] No version found for ghcr.io/home-assistant/qemux86-64-homeassistant
[supervisor.homeassistant.core] No Home Assistant Docker image ghcr.io/home-assistant/qemux86-64-homeassistant found.
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
[supervisor.homeassistant.core] Using preinstalled landingpage
[supervisor.homeassistant.core] Starting HomeAssistant landingpage
[supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
[supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
[supervisor.os.manager] Detect Home Assistant Operating System 11.2 / BootSlot A
[supervisor.store.git] Cloning add-on https://github.com/esphome/home-assistant-addon repository
[supervisor.store.git] Cloning add-on https://github.com/hassio-addons/repository repository
[supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository
[supervisor.store] Loading add-ons from store: 71 all - 71 new - 0 remove
[supervisor.addons] Found 0 installed add-ons
[supervisor.backups.manager] Found 0 backup files
[supervisor.discovery] Loaded 0 messages
[supervisor.ingress] Loaded 0 ingress sessions
[supervisor.resolution.check] Starting system checks with state setup
[supervisor.resolution.check] System checks complete
[supervisor.resolution.evaluate] Starting system evaluation with state setup
[supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
[__main__] Running Supervisor
[supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
[supervisor.addons] Phase 'initialize' starting 0 add-ons
[supervisor.addons] Phase 'system' starting 0 add-ons
[supervisor.addons] Phase 'services' starting 0 add-ons
[supervisor.core] Skipping start of Home Assistant
[supervisor.addons] Phase 'application' starting 0 add-ons
[supervisor.misc.tasks] All core tasks are scheduled
[supervisor.core] Supervisor is up and running
[supervisor.homeassistant.core] Home Assistant setup
[supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2023.11.3
[supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2023.11.3.
[supervisor.host.info] Updating local host information
[supervisor.resolution.check] Starting system checks with state running
[supervisor.resolution.checks.base] Run check for no_current_backup/system
[supervisor.resolution.module] Create new suggestion create_full_backup - system / None
[supervisor.resolution.module] Create new issue no_current_backup - system / None
[supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
[supervisor.resolution.checks.base] Run check for free_space/system
[supervisor.resolution.checks.base] Run check for pwned/addon
[supervisor.resolution.checks.base] Run check for multiple_data_disks/system
[supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
[supervisor.resolution.checks.base] Run check for docker_config/system
[supervisor.resolution.checks.base] Run check for trust/supervisor
[supervisor.resolution.checks.base] Run check for security/core
[supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
[supervisor.resolution.evaluate] Starting system evaluation with state running
[supervisor.host.manager] Host information reload completed
[supervisor.resolution.fixup] Starting system autofix at state running
[supervisor.resolution.fixup] System autofix complete
[supervisor.store.git] Update add-on https://github.com/hassio-addons/repository repository
[supervisor.store.git] Update add-on https://github.com/home-assistant/addons repository
[supervisor.store.git] Update add-on https://github.com/esphome/home-assistant-addon repository
[supervisor.store.git] Can't update https://github.com/home-assistant/addons repo: Cmd('git') failed due to: exit code(128)
cmdline: git fetch -v --update-shallow --depth=1 -- origin
stderr: 'fatal: unable to access 'https://github.com/home-assistant/addons/': Failure when receiving data from the peer'.
[supervisor.resolution.module] Create new suggestion execute_reset - store / core
[supervisor.resolution.module] Create new issue corrupt_repository - store / core
[supervisor.store.git] Can't update https://github.com/esphome/home-assistant-addon repo: Cmd('git') failed due to: exit code(128)
stderr: 'fatal: unable to access 'https://github.com/esphome/home-assistant-addon/': Failure when receiving data from the peer'.
[supervisor.resolution.module] Create new suggestion execute_reset - store / 5c53de3b
[supervisor.resolution.module] Create new issue corrupt_repository - store / 5c53de3b
[supervisor.store.git] Can't update https://github.com/hassio-addons/repository repo: Cmd('git') failed due to: exit code(128)
stderr: 'fatal: unable to access 'https://github.com/hassio-addons/repository/': Failed to connect to github.com port 443 after 21027 ms: Couldn't connect to server'.
[supervisor.resolution.module] Create new suggestion execute_reset - store / a0d7b954
[supervisor.resolution.module] Create new issue corrupt_repository - store / a0d7b954
[supervisor.store] Loading add-ons from store: 71 all - 0 new - 0 remove
[asyncio] Task exception was never retrieved
future: exception=StoreGitError()>
File "/usr/src/supervisor/supervisor/store/git.py", line 136, in pull
await self.sys_run_in_executor(
File "/usr/local/lib/python3.11/concurrent/futures/thread.py", line 58, in run
File "/usr/local/lib/python3.11/site-packages/git/remote.py", line 1014, in fetch
res = self._get_fetch_info_from_stderr(proc, progress, kill_after_timeout=kill_after_timeout)
File "/usr/local/lib/python3.11/site-packages/git/remote.py", line 853, in _get_fetch_info_from_stderr
proc.wait(stderr=stderr_text)
File "/usr/local/lib/python3.11/site-packages/git/cmd.py", line 600, in wait
raise GitCommandError(remove_password_if_present(self.args), status, errstr)
git.exc.GitCommandError: Cmd('git') failed due to: exit code(128)
The above exception was the direct cause of the following exception:
File "/usr/src/supervisor/supervisor/store/repository.py", line 108, in update
await self.git.pull()
File "/usr/src/supervisor/supervisor/jobs/decorator.py", line 296, in wrapper
raise err
File "/usr/src/supervisor/supervisor/jobs/decorator.py", line 289, in wrapper
return await self._method(obj, *args, **kwargs)
File "/usr/src/supervisor/supervisor/store/git.py", line 178, in pull
raise StoreGitError() from err
supervisor.exceptions.StoreGitError
raise err
raise err
[supervisor.docker.manager] Cleaning hassio_cli application
[supervisor.docker.manager] Cleaning hassio_dns application
[supervisor.docker.manager] Cleaning hassio_audio application
[supervisor.docker.manager] Cleaning hassio_multicast application
[supervisor.docker.manager] Starting homeassistant
[supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
[supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repository
[supervisor.store.git] Loading add-on /data/addons/core repository
[supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2023.11.3: 500 Server Error for http+docker://localhost/v1.43/images/create?tag=2023.11.3&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
[supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
[supervisor.homeassistant.core] Watchdog found Home Assistant failed, restarting...
发表于 2023-12-7 10:46:39 | 显示全部楼层
网络问题,请科学
发表于 2023-12-7 10:50:43 | 显示全部楼层
等着啊,等着就好了,要不就搞个高科技,一会就好了
GMT+8, 2025-12-16 23:26 , Processed in 1.069479 second(s), 14 queries , MemCached On.
