- 积分
- 230
- 金钱
- 217
- 威望
- 0
- 贡献
- 0
- HASS币
- 0
- 积分
- 230
- 金钱
- 217
- HASS币
- 0
楼主 |
发表于 2023-12-4 21:54:01
显示全部楼层
23-12-04 21:35:04 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
23-12-04 21:35:04 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
23-12-04 21:35:04 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
23-12-04 21:35:04 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
23-12-04 21:35:04 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
23-12-04 21:35:04 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
23-12-04 21:35:04 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
23-12-04 21:35:05 INFO (MainThread) [supervisor.host.services] Updating service information
23-12-04 21:35:05 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-12-04 21:35:05 WARNING (SyncWorker_0) [supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
23-12-04 21:35:06 INFO (MainThread) [supervisor.host.network] Updating local network information
23-12-04 21:35:07 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
23-12-04 21:35:07 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
23-12-04 21:35:07 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
23-12-04 21:35:08 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2023.10.0
23-12-04 21:35:09 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
23-12-04 21:35:13 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/amd64-hassio-cli with version 2023.10.0 - 172.30.32.5
23-12-04 21:35:13 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2023.06.2
23-12-04 21:35:14 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
23-12-04 21:35:20 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/amd64-hassio-dns with version 2023.06.2 - 172.30.32.3
23-12-04 21:35:20 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
23-12-04 21:35:21 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2023.10.0
23-12-04 21:35:21 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
23-12-04 21:35:27 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/amd64-hassio-audio with version 2023.10.0 - 172.30.32.4
23-12-04 21:35:27 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2023.06.0
23-12-04 21:35:27 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2023.06.2
23-12-04 21:35:28 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
23-12-04 21:35:33 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/amd64-hassio-multicast with version 2023.06.2 - Host
23-12-04 21:35:34 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 1 Home Assistant secrets
23-12-04 21:35:34 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/qemux86-64-homeassistant with version 2023.11.3
23-12-04 21:35:35 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 11.1 / BootSlot A
23-12-04 21:35:36 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repository
23-12-04 21:35:36 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
23-12-04 21:35:36 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
23-12-04 21:35:37 INFO (MainThread) [supervisor.store] Loading add-ons from store: 71 all - 71 new - 0 remove
23-12-04 21:35:37 INFO (MainThread) [supervisor.addons] Found 2 installed add-ons
23-12-04 21:35:37 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
23-12-04 21:35:37 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
23-12-04 21:35:37 INFO (MainThread) [supervisor.ingress] Loaded 2 ingress sessions
23-12-04 21:35:37 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
23-12-04 21:35:37 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-12-04 21:35:37 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
23-12-04 21:35:37 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-12-04 21:35:37 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
23-12-04 21:35:37 INFO (MainThread) [__main__] Running Supervisor
23-12-04 21:35:37 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
23-12-04 21:35:37 INFO (MainThread) [supervisor.addons] Phase 'initialize' starting 0 add-ons
23-12-04 21:35:38 INFO (MainThread) [supervisor.addons] Phase 'system' starting 0 add-ons
23-12-04 21:35:38 INFO (MainThread) [supervisor.addons] Phase 'services' starting 1 add-ons
23-12-04 21:35:38 ERROR (MainThread) [supervisor.addons.addon] Add-on core_samba has invalid options: Missing required option 'password' in Samba share (core_samba). Got {'username': 'homeassistant', 'password': None, 'workgroup': 'WORKGROUP', 'compatibility_mode': False, 'veto_files': ['._*', '.DS_Store', 'Thumbs.db', 'icon?', '.Trashes'], 'allow_hosts': ['10.0.0.0/8', '172.16.0.0/12', '192.168.0.0/16', '169.254.0.0/16', 'fe80::/10', 'fc00::/7']}
23-12-04 21:35:38 WARNING (MainThread) [supervisor.addons] Can't start Add-on core_samba
23-12-04 21:35:43 INFO (MainThread) [supervisor.core] Start Home Assistant Core
23-12-04 21:35:43 INFO (SyncWorker_0) [supervisor.docker.manager] Starting homeassistant
23-12-04 21:35:45 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
23-12-04 21:36:00 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-12-04 21:36:00 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to NOT_RUNNING
23-12-04 21:36:02 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state startup
23-12-04 21:36:02 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-12-04 21:36:02 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
23-12-04 21:36:02 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/esphome/home-assistant-addon repository
23-12-04 21:36:03 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/hassio-addons/repository repository
23-12-04 21:36:03 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/home-assistant/addons repository
23-12-04 21:36:05 INFO (MainThread) [supervisor.store] Loading add-ons from store: 71 all - 0 new - 0 remove
23-12-04 21:36:17 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to RUNNING
23-12-04 21:36:17 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
23-12-04 21:36:17 INFO (MainThread) [supervisor.addons] Phase 'application' starting 1 add-ons
23-12-04 21:36:18 ERROR (SyncWorker_0) [supervisor.docker.manager] Image homeassistant/amd64-addon-configurator:5.7.0 does not exist for addon_core_configurator
23-12-04 21:36:18 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_repair - addon / core_configurator
23-12-04 21:36:18 INFO (MainThread) [supervisor.resolution.module] Create new issue missing_image - addon / core_configurator
23-12-04 21:36:18 WARNING (MainThread) [supervisor.addons] Can't start Add-on core_configurator
23-12-04 21:36:24 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
23-12-04 21:36:24 INFO (MainThread) [supervisor.core] Supervisor is up and running
23-12-04 21:36:24 INFO (MainThread) [supervisor.host.info] Updating local host information
23-12-04 21:36:24 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
23-12-04 21:36:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
23-12-04 21:36:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
23-12-04 21:36:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
23-12-04 21:36:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
23-12-04 21:36:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
23-12-04 21:36:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
23-12-04 21:36:24 INFO (MainThread) [supervisor.resolution.module] Create new suggestion create_full_backup - system / None
23-12-04 21:36:24 INFO (MainThread) [supervisor.resolution.module] Create new issue no_current_backup - system / None
23-12-04 21:36:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
23-12-04 21:36:24 INFO (MainThread) [supervisor.host.services] Updating service information
23-12-04 21:36:24 INFO (MainThread) [supervisor.host.network] Updating local network information
23-12-04 21:36:25 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-12-04 21:36:25 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
23-12-04 21:36:25 INFO (MainThread) [supervisor.host.manager] Host information reload completed
23-12-04 21:36:25 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
23-12-04 21:36:25 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
23-12-04 21:36:25 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-12-04 21:36:25 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
23-12-04 21:36:25 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-12-04 21:36:25 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
23-12-04 21:36:25 INFO (MainThread) [supervisor.resolution.fixups.addon_execute_repair] Installing image for addon %s
23-12-04 21:36:25 INFO (MainThread) [supervisor.docker.interface] Downloading docker image homeassistant/amd64-addon-configurator with tag 5.7.0.
23-12-04 21:36:52 WARNING (MainThread) [supervisor.utils.pwned] Can't fetch HIBP data: Timeout |
