查看: 2575|回复: 2
[技术讨论] 大佬看看我的蓝牙怎么了?怎么修复?谢谢
发表于 2023-12-1 14:43:23 | 显示全部楼层 |阅读模式
root@armbian:~# systemctl status bluetooth
● bluetooth.service - Bluetooth service
     Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor pre>
     Active: failed (Result: exit-code) since Fri 2023-12-01 14:40:47 CST; 15s >
       Docs: man:bluetoothd(8)
    Process: 3760 ExecStart=/usr/libexec/bluetooth/bluetoothd--noplugin=sap (co>
   Main PID: 3760 (code=exited, status=203/EXEC)
Dec 01 14:40:47 armbian systemd[1]: Starting Bluetooth service...
Dec 01 14:40:47 armbian systemd[3760]: bluetooth.service: Failed to locate exec>
Dec 01 14:40:47 armbian systemd[3760]: bluetooth.service: Failed at step EXEC s>
Dec 01 14:40:47 armbian systemd[1]: bluetooth.service: Main process exited, cod>
Dec 01 14:40:47 armbian systemd[1]: bluetooth.service: Failed with result 'exit>
Dec 01 14:40:47 armbian systemd[1]: Failed to start Bluetooth service.
l
 楼主| 发表于 2023-12-1 15:13:24 | 显示全部楼层
     Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
     Active: failed (Result: exit-code) since Fri 2023-12-01 15:10:28 CST; 4s ago
    Process: 4058 ExecStart=/usr/libexec/bluetooth/bluetoothd--noplugin=sap (code=exited, status=203/EXEC)
   Main PID: 4058 (code=exited, status=203/EXEC)
Dec 01 15:10:28 armbian systemd[1]: Starting Bluetooth service...
Dec 01 15:10:28 armbian systemd[4058]: bluetooth.service: Failed to locate executable /usr/libexec/bluetooth/bluetoothd--noplugin=sap: No such file or directory
Dec 01 15:10:28 armbian systemd[4058]: bluetooth.service: Failed at step EXEC spawning /usr/libexec/bluetooth/bluetoothd--noplugin=sap: No such file or directory
Dec 01 15:10:28 armbian systemd[1]: bluetooth.service: Main process exited, code=exited, status=203/EXEC
Dec 01 15:10:28 armbian systemd[1]: bluetooth.service: Failed with result 'exit-code'.
Dec 01 15:10:28 armbian systemd[1]: Failed to start Bluetooth service.
再传一次,上面的不全
完全按照大神的方法安装的,蓝牙就是不启动,请赐教,谢谢
发表于 2023-12-2 14:29:38 | 显示全部楼层
/usr/libexec/bluetooth/bluetoothd(空格?)--noplugin=sap
GMT+8, 2025-12-8 10:45 , Processed in 1.064219 second(s), 12 queries , MemCached On.
