查看: 3798|回复: 4
[求助] 安装Node-RED后,报错无法启动
发表于 2023-11-29 22:31:37 | 显示全部楼层 |阅读模式
悬赏5金钱未解决
安装好Node-RED,提示报错,日志如下,新手无从下手,如何关闭SSL选项或放入证书文件?求大神解答,感激不尽!!
[21:13:22] FATAL: SSL has been enabled using the 'ssl' option,
[21:13:22] FATAL: this requires an SSL certificate file which is
[21:13:22] FATAL: configured using the 'certfile' option in the
[21:13:22] FATAL: add-on configuration.
[21:13:22] FATAL:
[21:13:22] FATAL: Unfortunately, the file specified in the
[21:13:22] FATAL: 'certfile' option does not exist.
[21:13:22] FATAL:
[21:13:22] FATAL: Please ensure the certificate file exists and
[21:13:22] FATAL: is placed in the '/ssl/' directory.
[21:13:22] FATAL:
[21:13:22] FATAL: In case you don't have SSL yet, consider getting
[21:13:22] FATAL: an SSL certificate or setting the 'ssl' option
[21:13:22] FATAL: to 'false' in case you are not planning on using
[21:13:22] FATAL: SSL with this add-on.
[21:13:22] FATAL:
[21:13:22] FATAL: Check the add-on manual for more information.
21:13:22] FATAL: s6-rc: warning: unable to start service init-nginx: command exited 1/run/s6/basedir/scripts/rc.init: warning: s6-rc failed to properly bring all the services up! Check your logs (in /run/uncaught-logs/current if you have in-container logging) for more information./run/s6/basedir/scripts/rc.init: fatal: stopping the container.s6-rc: info: service nodered: stopping[21:13:23] INFO: [color=var(--success-color)]Service Node-RED exited with code 256 (by signal 15)
 楼主| 发表于 2023-11-29 22:40:00 | 显示全部楼层
自己摸索着,在配置那一栏,拉到SSL,选项关闭了,就可以正常启动了
flim 手机认证
发表于 2024-7-24 13:33:33 | 显示全部楼层
我关了也不行,不知道啥原因
发表于 2025-2-3 15:59:15 | 显示全部楼层
flim 发表于 2024-7-24 13:33
我关了也不行,不知道啥原因
你好,你后来解决了吗,我也是ssl改了false也不行
flim 手机认证
发表于 2025-2-7 10:38:04 | 显示全部楼层
可以了,后来发现我没保存上,哈哈。好像是我点错了保存按钮
GMT+8, 2026-1-17 22:31 , Processed in 0.097447 second(s), 10 queries , MemCached On.
