查看: 7817|回复: 14
[经验分享] 10块钱的联想智能插座:无损拆机+免焊接刷esphome
发表于 2023-11-26 15:38:52 | 显示全部楼层 |阅读模式
咸鱼买了十几个联想智能插座,esp8266ex芯片,10元/个。
这款插座比较小巧,插在插排上不会和其他插头打架,目前为止少见的小体积并且可以无损拆解的国标五孔插座,已经将家里的大块头智能插座全部替换成这一款了。
超声波焊接工艺,可以无损开盖,免焊接刷机。无损拆机详见前面的帖子:https://bbs.hassbian.com/thread-23429-1-1.html
免焊接刷机,使用废旧网口里面的四根弹片,GPIO0直接和esp芯片的外壳连接即可,另外需要将第四个弹片弯折90度,探入rx脚的背面与tx脚接触,手扶刷机。
刷机完成之后,塑料盖板的边缘涂上有机硅胶水或者免钉胶,把外壳重新黏合在一起,固化24小时后即可正常插拔使用,效果十分完美。
esphome yaml配置文件如下:
common/common.yaml
esphome:
esp8266:
  board: esp01_1m
  restore_from_flash: false
wifi:
  ssid: !secret wifi_ssid
  fast_connect: true
  reboot_timeout: 30min
  ap:
    ssid: "${node_id} hotspot"
    password: !secret ap_password
logger:
    level: INFO
api:
  password: !secret api_password
  reboot_timeout: 1h
ota:
  password: !secret ota_password
web_server:
  port: 80
  include_internal: true
  version: 1
text_sensor:
  - platform: version
  - platform: wifi_info
    ip_address:
    bssid:
    mac_address:
  - platform: template
  - platform: uptime
    update_interval: 15min
    internal: true
    on_raw_value:
      then:
        - text_sensor.template.publish:
            state: !lambda |-
              int seconds = round(id(${node_id}_raw_up_time).raw_state);
              int days = seconds / (24 * 3600);
              seconds = seconds % (24 * 3600);
              int hours = seconds / 3600;
              seconds = seconds % 3600;
              int minutes = seconds /  60;
              seconds = seconds % 60;
              return (
                (days ? String(days) + "d " : "") +
                (hours ? String(hours) + "h " : "") +
                (minutes ? String(minutes) + "m " : "") +
                (String(seconds) + "s")
              ).c_str();
  - platform: wifi_signal
binary_sensor:
  - platform: status
switch:
  - platform: restart
plug-lenovo.yaml
substitutions:
  button_pin: GPIO13
  relay_pin: GPIO15
  led_state_pin: GPIO2
  led_relay_pin: GPIO0
  node_name: plug-lenovo
  node_id: plug_lenovo
  node_name_friendly: ${node_name}
packages:
  common: !include common/common.yaml
esphome:
  name_add_mac_suffix: true
binary_sensor:
  - platform: gpio
    pin:
      number: $button_pin
      inverted: true
      mode:
        input: true
        pullup: true
    on_press:
      then:
        - logger.log: "TOGGLE switch..."
        - switch.toggle: ${node_id}_switch
light:
  - platform: monochromatic
    output: ${node_id}_relay_led_pinout
    default_transition_length: 200ms
  - platform: status_led
    pin:
      number: $led_state_pin
      inverted: true
output:
  - platform: esp8266_pwm
    pin:
      number: $led_relay_pin
      inverted: true
switch:
  - platform: safe_mode
  - platform: gpio
    pin: $relay_pin
    on_turn_on:
      then:
        - light.turn_on: ${node_id}_relay_led
    on_turn_off:
      then:
        - light.turn_off: ${node_id}_relay_led
参与人数 2金钱 +15 收起 理由
cvip + 5 高手,这是高手!
DDDear + 10 大神666!
发表于 2023-11-26 17:20:40 | 显示全部楼层
分享一下购买链接啦
 楼主| 发表于 2023-11-26 17:42:27 | 显示全部楼层
搜索一下 联想智能插座。我买那家已经没了,因为我打包了。
发表于 2023-11-26 17:45:46 | 显示全部楼层
厉害,其实我去年买的博联的那些个开关都还没有用完。哈哈
发表于 2023-11-26 20:24:01 | 显示全部楼层
这款插座,自带esp芯片的是吗,
 楼主| 发表于 2023-11-26 20:57:20 | 显示全部楼层
bugensui 发表于 2023-11-26 20:24
这款插座,自带esp芯片的是吗,
是的。上面有拆机图片,是esp8266ex
发表于 2023-11-26 23:10:27 | 显示全部楼层
没了
涨价了?
发表于 2023-11-27 10:43:32 | 显示全部楼层
请问这个有功率监测功能吗?
 楼主| 发表于 2023-11-28 18:43:25 | 显示全部楼层
yingkkk 发表于 2023-11-27 10:43
请问这个有功率监测功能吗?
没有。目前没找到小巧好拆的功率插座
 楼主| 发表于 2023-11-28 18:46:43 | 显示全部楼层
咸鱼有很多吧。20元左右的打包砍价试试。我买那家标价29元一个,砍价到10元一个
GMT+8, 2025-9-14 03:32 , Processed in 0.242831 second(s), 9 queries , MemCached On.
