查看: 3825|回复: 2
[经验分享] 南京水费脚本-免抓cookie
发表于 2023-11-24 10:21:09 | 显示全部楼层 |阅读模式
之前的水费是需要自己去抓Cookie,然后填在配置文件中,现在不需要了,使用了带带弟弟OCR通用验证码识别SDK免费开源版,来进行验证码识别,并进行模拟登陆。这边只取了水费信息,如果需要其他的可以自己修改。然后在Node-Red中执行这个脚本就可以了。
之前插件的地址 南京水费插件,也做了更新。
import requests
import random
import ddddocr
from fake_useragent import UserAgent
ua = UserAgent()
user_Agent = ua.random
headers = {
    "User-Agent": user_Agent,
    "Accept": "text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9",
    "Accept-Language": "zh-CN,zh;q=0.9",
    "Accept-Encoding": "gzip, deflate, br",
    "DNT": "1",
    "Connection": "cloes"
ocr = ddddocr.DdddOcr()
if __name__ == '__main__':
    num = random.uniform(0, 1)
    # Verification code
    img_src = 'https://www.jlwater.com/captcha?' + str(num)
    print("Verification code url: " + img_src)
    r = requests.get(img_src, headers=headers)
    # save cookie
    cookies = r.cookies.items()
    cookie = ''
    for name, value in cookies:
        cookie += '{0}={1};'.format(name, value)
    # save Verification code img
    # with open("yzm.jpeg", "wb") as f:
    #     f.write(r.content)
    res = ocr.classification(r.content)
    print("The code is:", res)
    # login
    url = "https://www.jlwater.com/user/ajaxLogin"
    payload = {
        "mobile": "填写你的手机号",
        "password": "抓包查看下加密后的",
        "code": res,
        "url": ""
    headers = {
        "cookie": cookie
    res = requests.post(url, data=payload, headers=headers)
    # water fee
    url = "https://www.jlwater.com/waterFee/getConsWaterFeeSummary"
    payload = {'consNo': '你的户号'}
    response = requests.request("POST", url, headers=headers, data=payload)
    print(response.text)
可以使用Node-Red直接调用 exec 节点调用。然后生成MQTT传感器。
function toDecimal2(x) {
    var f = Math.round(x * 100) / 100;
    var s = f.toString();
    var rs = s.indexOf('.');
    if (rs < 0) {
        rs = s.length;
        s += '.';
    while (s.length <= rs + 2) {
        s += '0';
    return s;
const prefix = "home/sensor/water_fee"
let msg_config = []
msg_config = [
        "topic": "homeassistant/sensor/water_fee/config",
        "payload": {
            "~": prefix.replace("button", "sensor"),
            "name": "water_fee",
            "state_topic": "~/state",
            "unique_id": "water_fee",
            "icon": "mdi:water",
            "json_attributes_topic": "~/info"
        "topic": `${prefix.replace("button", "sensor")}/state`,
        "payload": toDecimal2(msg.payload.waterFee)
        "topic": `${prefix.replace("button", "sensor")}/info`,
        "payload": msg.payload
return [msg_config];
接入如图所示
接入图
接入图
发表于 2023-11-24 13:18:51 | 显示全部楼层
我又来了 江宁不算南京 哈哈
江宁水务抓了cookie用了好久了 非常稳定
发表于 2024-12-23 16:42:40 | 显示全部楼层
用的nodered里面的exec,提示no module
Command failed: python3 /python/water_free/water.py
  File "/python/water_free/water.py", line 1, in <module>
    import requests
ModuleNotFoundError: No module named 'requests'
GMT+8, 2026-1-14 21:13 , Processed in 0.368566 second(s), 12 queries , MemCached On.
