查看: 3557|回复: 6
[技术探讨] zha异常好几天了?
发表于 2023-11-22 12:04:23 | 显示全部楼层 |阅读模式
zha集成出问题好几天了,有没有大佬指点下,是哪里出问题了,报错日志如下:ha和zha的网关都重启了5-6次了。还是设备全部不可用。
Logger: homeassistant.config_entries
Source: config_entries.py:402
First occurred: 11:59:56 (1 occurrences)
Last logged: 11:59:56
Error setting up entry socket://192.168.0.67:6638 for zha
  File "/usr/local/lib/python3.11/site-packages/zigpy_znp/api.py", line 684, in _skip_bootloader
    result = await responses.get()
  File "/usr/local/lib/python3.11/asyncio/queues.py", line 158, in get
    await getter
asyncio.exceptions.CancelledError
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 402, in async_setup
    result = await component.async_setup_entry(hass, self)
  File "/usr/src/homeassistant/homeassistant/components/zha/__init__.py", line 164, in async_setup_entry
    await zha_gateway.async_initialize()
  File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 224, in async_initialize
    raise exc
  File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 209, in async_initialize
    await self.application_controller.startup(auto_form=True)
  File "/usr/local/lib/python3.11/site-packages/zigpy/application.py", line 213, in startup
    await self.connect()
  File "/usr/local/lib/python3.11/site-packages/zigpy_znp/zigbee/application.py", line 115, in connect
    await znp.connect()
  File "/usr/local/lib/python3.11/site-packages/zigpy_znp/api.py", line 726, in connect
    self.capabilities = (await self._skip_bootloader()).Capabilities
  File "/usr/local/lib/python3.11/site-packages/zigpy_znp/api.py", line 683, in _skip_bootloader
    async with async_timeout.timeout(CONNECT_PROBE_TIMEOUT):
  File "/usr/local/lib/python3.11/site-packages/async_timeout/__init__.py", line 141, in __aexit__
    self._do_exit(exc_type)
  File "/usr/local/lib/python3.11/site-packages/async_timeout/__init__.py", line 228, in _do_exit
    raise asyncio.TimeoutError
TimeoutError
发表于 2023-11-22 16:04:59 | 显示全部楼层
HA是在那里安装的,是不是zigbee网关没有连接上
 楼主| 发表于 2023-11-22 16:34:48 | 显示全部楼层
ha是装在威联通的nas虚拟机上,zigbee的网关,不是直接插在主机上的,是走的wifi协议,跟ha链接,不是usb协议,还是放的老位置,就这2天不行了。不知道哪里出错
发表于 2023-11-22 16:39:47 | 显示全部楼层
噢,我的HA在PVE上安装着,网关是USB的,每次重启PVE后就要重新拔叉一次网关。
 楼主| 发表于 2023-11-22 16:45:21 | 显示全部楼层
祁连山路 发表于 2023-11-22 16:39
噢,我的HA在PVE上安装着,网关是USB的,每次重启PVE后就要重新拔叉一次网关。 ...
我拔usb通断电,重启网关,重启ha都试了,不知道哪里出错,代码没有看懂。
发表于 2023-11-22 20:57:15 来自手机 | 显示全部楼层
是不是网关的ip地址变了?重新在ha中设置一下
 楼主| 发表于 2023-11-23 11:12:28 | 显示全部楼层
没有,ip地址对的
GMT+8, 2026-1-16 03:16 , Processed in 1.698813 second(s), 15 queries , MemCached On.
