查看: 2607|回复: 2
[求助] MQTT 链HA 自动发现多个开关现在只能实现一个想添加多个
发表于 2023-11-19 11:08:15 | 显示全部楼层 |阅读模式
这里是源码用的是ESP32 Ard IDE      谁帮我看看如何添加第二个开关呢 怎么加都加不上去
#include <WiFi.h>          //wifi连接
#include <PubSubClient.h>  //mqtt通讯库
WiFiClient espClient;
PubSubClient client(espClient);
const char *wifi_ssid = "qqqq";               //wifi 账号
const char *wifi_password = "123456789";      //wifi密码
const char *mqtt_server = "139.***.***.***";  //MQTT_IP
const char *mqtt_ssid = "****";              //MQTT_账号
const char *mqtt_password = "*****";     //MQTT_密码
const char *mqtt_ID = "测试数据";             //MQTT_客户ID
const int mqtt_Port = 1883;                   //MQTT端口
int
  key_kk = 32;   //定义数字2
char resp1[] = R"({
"~": "homeassistant/light/bedroom",
  "name": "开关",
  "unique_id": "bedroom_light",
  "cmd_t": "~/set",
  "stat_t": "~/state",
  "schema": "json",
  "brightness": true})";
void callback(char *topic, byte *payload, unsigned int length) {  //回调函数
  Serial.print("Message arrived [");
  Serial.print(topic);
  Serial.print("] ");
  String s = "";
  for (int i = 0; i < length; i++) {
    s = s + (char)payload;
  Serial.println(s);
  if (s == "{\"state\":\"ON\"}") {
    digitalWrite(key_kk, HIGH);
    client.publish("homeassistant/light/bedroom/state", (char *)s.c_str());
  if (s == "{\"state\":\"OFF\"}") {
    digitalWrite(key_kk, LOW);
//WIFI 设置重连
void setup_wifi() {
  delay(10);
  Serial.println();
  Serial.print("链接WIFI账号: ");
  Serial.print(wifi_ssid);
  Serial.println();
  WiFi.mode(WIFI_STA);  //wifi 模式
  WiFi.begin(wifi_ssid, wifi_password);
  while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(".");
  randomSeed(micros());
  Serial.println("");
  Serial.println("WiFi 链接成功");
  Serial.print("IP 地址: ");
  Serial.println(WiFi.localIP());
void reconnect() {
  // 循环直到我们重新连接
  while (!client.connected())  //客户端是否链接
    Serial.println("正在链接MQTT客户端...");
    if (client.connect(mqtt_ID, mqtt_ssid, mqtt_password))  //clientID, userName, userPassword
      client.publish("homeassistant/light/bedroom/config", resp1);          //订阅个开关HA主题
      client.subscribe("homeassistant/light/bedroom/set");                  //开关订阅
      Serial.println("链接MQTT网络成功");
    } else {
      Serial.print("链接MQTT客户端失败");
      Serial.print(client.state());
      Serial.println(" 五秒后再次尝试");
      delay(5000);
void mqtt_cl()  //MQTT重连
  if (!client.connected()) { reconnect(); }
void setup() {
   Serial.begin(115200);
   pinMode(key_kk, OUTPUT);  // 初始化IO设置成输出
   setup_wifi();
   client.setServer(mqtt_server, mqtt_Port);  //链接MQTT
   client.setCallback(callback);              //回调函数
   mqtt_cl();                                 //MQTT重连
void loop() {
  mqtt_cl();  //MQTT重连
  client.loop();
发表于 2023-11-19 13:25:28 | 显示全部楼层
一个开关实体,对应一个单独的topic
你这只有一个topic,当然只有一个开关了
另一个开关按键,就要再加一个不同的topic
 楼主| 发表于 2023-11-19 15:13:12 | 显示全部楼层
我就是不懂如何加 我加过一个 但是回调函数还是调用之前的
GMT+8, 2025-12-17 07:24 , Processed in 0.787042 second(s), 9 queries , MemCached On.
