查看: 13533|回复: 4
[求助] 求助:HOMEBRIDGE运行报错
PAUL
发表于 2017-5-29 16:46:48 | 显示全部楼层 |阅读模式
运行homebridge命令之后,能出现设置的代码,但是有报错,iOS设备也发现不了homebridge。错误提示如下:
重装homebridge也没解决,求教大神是哪里的问题/。
活跃会员
发表于 2017-5-30 21:59:59 | 显示全部楼层
hb运行时如果出现dns错误
May 22 16:17:19 orangepione homebridge[6714]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=nodejs>
May 22 16:17:19 orangepione homebridge[6714]: *** WARNING *** The program 'nodejs' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
May 22 16:17:19 orangepione homebridge[6714]: *** WARNING *** Please fix your application to use the native API of Avahi!
May 22 16:17:19 orangepione homebridge[6714]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat? ... =DNSServiceRegister>
May 22 16:17:19 orangepione nodejs[6714]: *** WARNING *** The program 'nodejs' uses the Apple Bonjour compatibility layer of Avahi.
May 22 16:17:19 orangepione nodejs[6714]: *** WARNING *** Please fix your application to use the native API of Avahi!
May 22 16:17:19 orangepione nodejs[6714]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=nodejs>
May 22 16:17:19 orangepione nodejs[6714]: *** WARNING *** The program 'nodejs' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
May 22 16:17:19 orangepione nodejs[6714]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat? ... =DNSServiceRegister>
执行楼主(如出现DNS错误 执行命令sudo apt-get install avahi-daemon avahi-discover libnss-mdns libavahi-compat-libdnssd-dev)解决
https://bbs.hassbian.com/thread-48-4-1.html
教程狂人论坛风云人物
发表于 2017-6-1 12:44:04 | 显示全部楼层
重装吧!!!!
尝试过萝卜,我想你一定会忘记青瓜
发表于 2017-6-13 16:55:38 | 显示全部楼层
谢谢分享
发表于 2017-6-30 14:49:20 | 显示全部楼层
启动homebridge前重启 avahi-daemon和 dbus
GMT+8, 2025-10-23 08:44 , Processed in 0.117010 second(s), 12 queries , MemCached On.
