查看: 3159|回复: 8
[求助] 怎么把小爱播方的文本内容加上变量?
发表于 2023-11-5 14:54:45 | 显示全部楼层 |阅读模式
小爱同学播方text后面的文字内容如何替换成文字加变量,让小爱播放房间温度和湿度。。我试了加变量提示报错!
需要替换的地方
需要替换的地方
被替换的地方
被替换的地方
发表于 2023-11-5 15:44:57 | 显示全部楼层
用这个:
 text: >-
    欢迎回家!当前室内温度是 {{ states('sensor.0x00158d0008ce9e71_temperature') }} 摄氏度,湿度是
    {{ state_attr('sensor.0x00158d0008ce9e71_humidity', 'humidity') }}%。
 楼主| 发表于 2023-11-5 16:27:57 | 显示全部楼层
你这个是放到哪里截图我看看吗?我就是想让小爱播放环境温湿度
发表于 2023-11-5 16:58:11 | 显示全部楼层
就是自动化里面啊,调用小爱的speaker服务啊
发表于 2023-11-5 18:46:29 | 显示全部楼层
整点播报怎么设置?谢谢!
 楼主| 发表于 2023-11-5 19:08:50 | 显示全部楼层
好的 我是在nodered里面播报的 现在可以了 我试试自动化
发表于 2023-11-5 20:04:16 | 显示全部楼层
{"text":"我的小主人优优,您的最新体重为{{payload}}斤"}
发表于 2023-11-5 20:44:17 | 显示全部楼层
        "id": "3cf60ddc3d8a32de",
        "type": "function",
        "z": "0af7ec16ee706e56",
        "name": "function 3",
        "func": "let battery_level=20;\nmsg.payload = {\n    "data": {\n        "entity_id": "media_player.xiaomi_lx5a_c964_play_control",\n        "text": `主人,门锁电量${battery_level},请及时充电`\n    }\n}\n\nreturn msg;",
        "outputs": 1,
        "timeout": "",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 340,
        "y": 700,
        "wires": [
                "8d1f0d64d8ce669d"
        "id": "8d1f0d64d8ce669d",
        "type": "api-call-service",
        "name": "小爱音箱",
        "server": "39747b58.21e974",
        "version": 5,
        "debugenabled": false,
        "domain": "xiaomi_miot",
        "service": "intelligent_speaker",
        "areaId": [],
        "deviceId": [],
        "entityId": [
        "data": "",
        "dataType": "json",
        "mergeContext": "",
        "mustacheAltTags": false,
        "outputProperties": [],
        "queue": "none",
        "x": 500,
        "y": 700,
        "wires": [
        "id": "bd5a2683856b72b0",
        "type": "inject",
        "name": "",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 190,
        "y": 700,
        "wires": [
                "3cf60ddc3d8a32de"
        "id": "39747b58.21e974",
        "type": "server",
        "name": "Home Assistant",
        "version": 5,
        "addon": true,
        "connectionDelay": true,
        "cacheJson": true,
        "heartbeat": false,
        "heartbeatInterval": "30",
        "areaSelector": "friendlyName",
        "deviceSelector": "friendlyName",
        "entitySelector": "friendlyName",
        "statusSeparator": "at: ",
        "statusYear": "hidden",
        "statusMonth": "short",
        "statusDay": "numeric",
        "statusHourCycle": "h23",
        "statusTimeFormat": "h:m:s",
        "enableGlobalContextStore": true
 楼主| 发表于 2023-11-5 20:45:48 | 显示全部楼层
大哥 你这个正和我意  谢谢
GMT+8, 2025-12-17 07:24 , Processed in 1.299640 second(s), 8 queries , MemCached On.
