查看: 1643|回复: 1
[已解决] 小米AI音箱一代,ttl接入键盘按什么都不没用,无法刷机
发表于 2023-10-28 13:54:39 | 显示全部楼层 |阅读模式
小米AI音箱一代,按论坛的方法,按什么f+enter,或者ctrl+c都不能停,,一段时间没用了。然后就不能连网,想着上来找找刷机方法。又不成功,哪位大神帮忙看下。ttl进入后走到这就不动了,看了下和论坛里的都不一样。mibt_mesh[1476]: sig_handler:15
bl31 reboot reason: 0xd
bl31 reboot reason: 0x1
system cmd  1.
AXG:BL1:d1dbf2:a4926f;FEAT:E0DC318C:2000OC:F;EMMC:800;NAND:0;READ:0;0.0;CHK:0;
sdio debug board detected
TE: 24160
BL2 Built : 18:30:39, Aug 28 2018. axg g56303a2-dirty - liang.yang@droid11-sz
set vcck to 1140 mv
set vddee to 1070 mv
Board ID = 4
CPU clk: 1200MHz
DDR low power enabled
DDR3 chl: Rank0 16bit @ 792MHz
bist_test rank: 0 27 00 4f 36 12 5b 26 00 4d 37 10 5f 00 00 00 00 00 00 00 00 00 00 00 00 612   - PASS
Rank0: 256MB(auto)-2T-11
AddrBus test pass!
NAND init
page0 page0->bbt:
0000000000000000000000000000000000000000000000000000000000000000
page0 bbt:
Load FIP HDR from NAND, src: 0x0000c000, des: 0x01700000, size: 0x00004000
Load BL3x from NAND, src: 0x00010000, des: 0x01704000, size: 0x00080000
NOTICE:  BL31: v1.3(release):a1a8551
NOTICE:  BL31: Built : 15:59:55, Nov  9 2017
NOTICE:  BL31: AXG normal boot!
NOTICE:  BL31: BL33 decompress pass
[Image: axg_v1.1.3268-b93dd79 2017-12-01 14:22:18 huan.biao@droid12]
OPS=0x43
79 4c 69 f1 f0 61 4 8e c7 6a 39 69 bl30:axg ver: 9 mode: 0
bl30:axg thermal0
[0.014523 Inits done]
secure task start!
high task start!
low task start!
ERROR:   Error initializing runtime service opteed_fast
U-Boot 2015.01 (Dec 24 2019 - 07:00:02), Build: jenkins-Mico_s12a_ota_publish-379
DRAM:  256 MiB
Relocation Offset is: 0ef17000
register usb cfg[0][1] = 000000000ff89690
NAND:  nand id: 0x98 0xf1
128MiB, SLC, page size: 2048, OOB size: 64
NAND device id: 98 f1 80 15 f2 16
NAND device: Manufacturer ID: 0x98, Chip ID: 0x98 (Toshiba A revision NAND 1Gib TC58BVG0S3HTA00 )
oob avail size 6
Creating 1 MTD partitions on "A revision NAND 1Gib TC58BVG0S3HTA00 ":
0x000000000000-0x000000200000 : "bootloader"
A revision NAND 1Gib TC58BVG0S3HTA00  initialized ok
nand id: 0x98 0xf1
PLANE change!
aml_nand_init obmul=1,oobfree.length=8,oob_size=64
oob avail size 8
bbt_start=20 env_start=24 key_start=32 dtb_start=40
nbbt: info size=0x400 max_scan_blk=24, start_blk=20
nbbt : phy_blk_addr=20, ec=0, phy_page_addr=0, timestamp=1
nbbt free list:
blockN=21, ec=-1, dirty_flag=0
blockN=22, ec=-1, dirty_flag=0
blockN=23, ec=-1, dirty_flag=0
aml_nand_scan_rsv_info 1251: page_num=1
aml_nand_scan_rsv_info 1254
nbbt valid addr: 280000
aml_nand_bbt_check 1389 bbt is valid, reading.
aml_nand_read_rsv_info:397,read nbbt info to 280000
nenv: info size=0x10000 max_scan_blk=32, start_blk=24
nenv : phy_blk_addr=25, ec=547, phy_page_addr=0, timestamp=1103
nenv free list:
blockN=24, ec=547, dirty_flag=1
blockN=26, ec=6, dirty_flag=1
blockN=27, ec=-1, dirty_flag=0
blockN=28, ec=-1, dirty_flag=0
blockN=29, ec=-1, dirty_flag=0
blockN=30, ec=-1, dirty_flag=0
blockN=31, ec=-1, dirty_flag=0
aml_nand_scan_rsv_info 1251: page_num=32
nenv valid addr: 320000
nkey: info size=0x8000 max_scan_blk=40, start_blk=32
nkey : phy_blk_addr=33, ec=0, phy_page_addr=0, timestamp=2
nkey free list:
blockN=32, ec=0, dirty_flag=1
blockN=34, ec=-1, dirty_flag=0
blockN=35, ec=-1, dirty_flag=0
blockN=36, ec=-1, dirty_flag=0
blockN=37, ec=-1, dirty_flag=0
blockN=38, ec=-1, dirty_flag=0
blockN=39, ec=-1, dirty_flag=0
aml_nand_scan_rsv_info 1251: page_num=16
nkey valid addr: 428000
ndtb: info size=0x20000 max_scan_blk=44, start_blk=40
ndtb : phy_blk_addr=40, ec=1, phy_page_addr=0, timestamp=3
ndtb free list:
blockN=41, ec=0, dirty_flag=1
blockN=42, ec=-1, dirty_flag=0
blockN=43, ec=-1, dirty_flag=0
aml_nand_scan_rsv_info 1251: page_num=64
ndtb valid addr: 500000
tpl: off 8388608, size 8388608
NAND bbt detect factory Bad block at 6000000
Creating 6 MTD partitions on "A revision NAND 1Gib TC58BVG0S3HTA00 ":
0x000000800000-0x000001000000 : "tpl"
0x000001000000-0x000001800000 : "boot0"
0x000001800000-0x000002000000 : "boot1"
0x000002000000-0x000004000000 : "system0"
0x000004000000-0x000006000000 : "system1"
0x000006000000-0x000008000000 : "data"
aml_key_init 170
MMC:
uboot env amlnf_env_read : ####
aml_nand_read_rsv_info:397,read nenv info to 320000
In:    serial
Out:   serial
Err:   serial
[store]To run cmd[amlnf dtb_read 0x1000000 0x20000]
sub cmd dtb
new argv[1] dtb_read
do_dtb_ops(): argc 4
arg 0: amlnf
arg 1: dtb_read
arg 2: 0x1000000
arg 3: 0x20000
do_dtb_ops() read
amlnf_dtb_read: ####
aml_nand_read_rsv_info:397,read ndtb info to 500000
do_dtb_ops(): 131072 bytes read : OK
      Amlogic multi-dtb tool
      GZIP format, decompress...
      Multi dtb detected
      Multi dtb tool version: v2 .
      Support 5 dtbs.
        aml_dt soc: xiaomi platform: s12c variant: v01
        dtb 0 soc: xiaomi   plat: s12   vari: v1
        dtb 1 soc: xiaomi   plat: s12a   vari: v01
        dtb 2 soc: xiaomi   plat: s12c   vari: v01
        dtb 3 soc: xiaomi   plat: s12c   vari: v02
        dtb 4 soc: xiaomi   plat: s12c   vari: v03
      Find match dtb: 2
amlkey_init() enter!
amlnf_key_read key data len too much
aml_nand_read_rsv_info:397,read nkey info to 428000
[EFUSE_MSG]keynum is 4
Hit Enter or space or Ctrl+C key to stop autoboot -- :  0
Saving Environment to aml-storage...
uboot env amlnf_env_save : ####
aml_nand_save_rsv_info:656, nenv: valid=1, pages=32
aml_nand_save_rsv_info:716,save info to 330000
aml_nand_write_rsv:520,write info to 330000
[burnup]Rd:Up sz 0x3ad440 to align 0x1000
save_power_post ...
## Booting Android Image at 0x01080000 ...
reloc_addr =f0344e0
copy done
load dtb from 0x1000000 ......
      Single dtb detected
   Uncompressing Kernel Image ... OK
   kernel loaded at 0x01080000, end = 0x017b7808
   Loading Ramdisk to 0eea7000, end 0f004ba8 ... OK
   Loading Device Tree to 000000000ee9b000, end 000000000eea62bf ... OK
Starting kernel ...
uboot time: 1530226 us
domain-0 init dvfs: 4
[    0.290807@1] ff803000.serial: clock gate not found
get key is 0x00 , curr_boot is boot0
Booting from boot0
/dev/mtdblock4 is ready now.
[    1.317726@1] i2c i2c-1: [aml_i2c_xfer] error ret = -5 (-EIO)
[    1.317846@1] i2c i2c-1: token 1, master_no(1) 300K addr 0x3c
Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
rm: can't remove '/tmp/tmp.LDTWs0': No such file or directory
Please press Enter to activate this console.
[    5.383711@1] cyttsp 0-0008: Failed to request firmware touch.cyacd
[    5.384342@1] cyttsp 0-0008: Failed to update firmware;
[    7.152565@0] name: mac_wifi, size 17
[    7.170213@2] name: mac_bt, size 17
micocfg[984]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[984]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[984]: UNLOCK fd: 3.
micocfg[984]: LOCK:ret(0) fd(3), path(26): /var/lock/device.info.lock.
micocfg[984]: cfg get: success: /data/etc/device.info k:sn v:18090/700500932335
micocfg[985]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[985]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[985]: UNLOCK fd: 3.
micocfg[985]: LOCK:ret(0) fd(3), path(26): /var/lock/device.info.lock.
micocfg[985]: cfg get: success: /data/etc/device.info k:mac_wifi v:E0:B6:55:1E:AE:1C
micocfg[986]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[986]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[986]: UNLOCK fd: 3.
micocfg[986]: LOCK:ret(0) fd(3), path(26): /var/lock/device.info.lock.
micocfg[986]: cfg get: success: /data/etc/device.info k:mac_bt v:E0:B6:55:41:5B:99
micocfg[987]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[987]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[987]: UNLOCK fd: 3.
micocfg[987]: LOCK:ret(0) fd(3), path(26): /var/lock/device.info.lock.
micocfg[987]: cfg get: success: /data/etc/device.info k:miio_did v:268811760
micocfg[988]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[988]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[988]: UNLOCK fd: 3.
micocfg[988]: LOCK:ret(0) fd(3), path(26): /var/lock/device.info.lock.
micocfg[988]: cfg get: success: /data/etc/device.info k:miio_key v:5y9Ri5gLZgHWKERY
micocfg[989]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[989]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[989]: UNLOCK fd: 3.
micocfg[989]: LOCK:ret(0) fd(3), path(26): /var/lock/device.info.lock.
micocfg[989]: cfg get: success: /data/etc/device.info k:board_id v:4
micocfg[993]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[993]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[993]: UNLOCK fd: 3.
micocfg[993]: cfg get: success: /usr/share/mico/system.cfg k:buildts v:1693823263
micocfg[995]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[995]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[995]: UNLOCK fd: 3.
micocfg[996]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[996]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[996]: UNLOCK fd: 3.
micocfg[996]: bt_enable_set  argv[1] 1
micocfg[996]: LOCK:ret(0) fd(3), path(28): /var/lock/bluetooth.cfg.lock.
micocfg[996]: cfg update success: /data/bt/bluetooth.cfg k:enable v:1
micocfg[997]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[997]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[997]: UNLOCK fd: 3.
micocfg[997]: LOCK:ret(0) fd(3), path(28): /var/lock/messaging.cfg.lock.
micocfg[997]: cfg get: success: /data/etc/messaging.cfg k:super_admin v:1353515352
micocfg[998]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[998]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[998]: UNLOCK fd: 3.
micocfg[998]: LOCK:ret(0) fd(3), path(23): /var/lock/miio.cfg.lock.
micocfg[998]: cfg update success: /data/etc/miio.cfg k:registed v:true
micocfg[1000]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[1000]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[1000]: UNLOCK fd: 3.
micocfg[1000]: cfg get: success: /usr/share/mico/system.cfg k:channel v:release
micocfg[1043]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[1043]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[1043]: UNLOCK fd: 3.
ledserver[1041]: Build Time: Sep  4 2023 10:54:43
ledserver[1041]: starting
ledserver[1041]: LOCK:ret(0) fd(8), path(28): /var/lock/nightmode.cfg.lock.
ledserver[1041]: No 'sleep_mode_flag' setting in configuration file '/data/etc/nightmode.cfg'
ledserver[1041]: UNLOCK fd: 8.
ledserver[1041]: cfg get: success: /data/etc/nightmode.cfg k:sleep_mode v:normal
ledserver[1041]: cfg get: success: /data/etc/nightmode.cfg k:total v:night
ledserver[1041]: cfg get: success: /data/etc/nightmode.cfg k:light v:night
ledserver[1041]: cfg get: success: /data/etc/nightmode.cfg k:volume v:night
ledserver[1041]: cfg get: success: /data/etc/nightmode.cfg k:start v:22:00
ledserver[1041]: cfg get: success: /data/etc/nightmode.cfg k:stop v:06:00
ledserver[1041]: handle_show start
ledserver[1041]: start_show effect_id is 4 is_working is 0
ledserver[1041]: start_show end
ledserver[1041]: thread_push_led start
ledserver[1041]: handle_show stop
ledserver[1041]: thread_push_led end
crond[1063]: crond (busybox 1.27.2) started, log level 5
micocfg[1069]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[1069]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[1069]: UNLOCK fd: 3.
micocfg[1073]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[1073]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[1073]: UNLOCK fd: 3.
micocfg[1073]: cfg get: success: /usr/share/mico/system.cfg k:channel v:release
ledserver[1041]: have_led:1 wakeup_led_update:0 led_changed:1
ledserver[1041]: light_show_control 4
ledserver[1041]: open_light start
ledserver[1041]: light_show_effect 4
[   11.477375@3] wlan: Loading MWLAN driver
[   11.477945@2] vendor=0x02DF device=0x9145 class=0 function=1
[   11.481496@2] SDIO: max_segs=1024 max_seg_size=131072
[   11.486340@2] rx_work=1 cpu_num=4
[   11.493631@2] Request firmware: mrvl/sdsd8977_combo_v2.bin
[   11.853644@0] pdm_dclk is : 0
[   13.046844@0] invalid toddr src
[   13.894323@2] WLAN FW is active
[   14.012593@0] get_channel when STA is not connected
[   14.016155@2] get_channel when AP is not started
[   14.018735@3] wlan: version = SD8977-16.84.9.p22-C4X16C544.P7-GPL-(FP84)
[   14.023480@3] wlan: Driver loaded successfully
[   14.303279@1] BT: Loading driver
[   14.306823@1] BT FW is active(0)
[   14.306861@1] BT: FW already downloaded!
[   14.320435@3] BT: Driver loaded successfully
[   14.388940@1] get_channel when STA is not connected
[   14.389551@3] get_channel when STA is not connected
[   14.395215@3] get_channel when STA is not connected
[   14.398405@3] get_channel when STA is not connected
[   14.405089@3] get_channel when STA is not connected
[   14.544078@1] wlan: wlan0 START SCAN
发表于 2023-10-28 22:10:37 | 显示全部楼层
板子上的传输点选择的不对吧,我的mini也出现过这种情况,无法控制,
GMT+8, 2025-12-18 14:12 , Processed in 0.350192 second(s), 8 queries , MemCached On.
