查看: 5208|回复: 3
[基础教程] 使用docker-compose快速部署HA相关容器
发表于 2023-10-24 18:05:44 | 显示全部楼层 |阅读模式
最近迁移系统,感觉一个个弄有点零碎,虽然很简单,但是毕竟需要一个个pull-run,复制配置文件等等,有点麻烦
整理了一下,使用docker-compose节省了手动pull和run的时间,记录一下顺便分享一下
只弄了ha、nodered、esphome、mpd、zigbee2mqtt、portainer、ddns-go 7个
其他必须的比如mosquitto、nginx,非必须的mysql我是直接部署在系统里的,略
下面正式开始
docker部署
curl -fsSL https://get.docker.com/ | sh
等待完成后添加镜像加速
vim /etc/docker/daemon.conf
添加内容:
    "registry-mirrors" : [
    "https://registry.docker-cn.com",
    "http://hub-mirror.c.163.com",
    "https://docker.mirrors.ustc.edu.cn",
    "https://cr.console.aliyun.com",
    "https://mirror.ccs.tencentyun.com"
重启docker
systemctl restart docker
docker-compose
安装
curl -L https://github.com/docker/compose/releases/download/2.23.0/docker-compose-`uname -s`-`uname -m` -o /usr/local/bin/docker-compose
chmod +x /usr/local/bin/docker-compose
两行代码分别执行,第一行代码下载太慢的话手动去下载后放入/usr/local/bin目录
然后执行第二行
完成后可以使用`docker-compose --version`查看是否成功
容器部署
  • 提前创建数据卷
    docker volume create esphome
    docker volume create ddns_go
    docker volume create homeassistant
    docker volume create mpd
    docker volume create nodered
    docker volume create portainer
    docker volume create zigbee2mqtt
  • 创建docker-compose.yml文件,记住在哪儿创建的
       services:
         ESPHome:
           container_name: "ESPHome"
           image: "esphome/esphome:latest"
           network_mode: "host"
           restart: "always"
           volumes:
             - "esphome:/config"
         ddns-go:
           container_name: "ddns-go"
           environment:
             - "TZ=Asia/Shanghai"
           image: "jeessy/ddns-go:latest"
           restart: "always"
           volumes:
             - "ddns_go:/root"
         homeassistant:
           container_name: "homeassistant"
           environment:
           image: "docker.io/homeassistant/home-assistant:latest"
           privileged: true
           restart: "always"
           volumes:
             - "homeassistant:/config"
         mpd:
           container_name: "mpd"
           devices:
             - "/dev/snd:/dev/snd"
           image: "schumyhao/mpd:latest"
           restart: "always"
           volumes:
             - "/var/lib/docker/volumes/mpd:/var/lib/mpd"
             - "/var/lib/docker/volumes/mpd/database:/var/lib/mpd/database"
             - "/var/lib/docker/volumes/mpd/mpd.conf:/etc/mpd.conf"
             - "/var/lib/docker/volumes/mpd/mpd.log:/var/lib/mpd/mpd.log"
             - "/var/lib/docker/volumes/mpd/music:/var/lib/mpd/music"
             - "/var/lib/docker/volumes/mpd/playlists:/var/lib/mpd/playlists"
             - "/var/lib/docker/volumes/mpd/state:/var/lib/mpd/state"
             - "/var/lib/docker/volumes/mpd/sticker.sql:/var/lib/mpd/sticker.sql"
         nodered:
           container_name: "nodered"
           environment:
           image: "nodered/node-red:latest"
           restart: "always"
           volumes:
             - "nodered:/data"
         portainer:
           container_name: "portainer"
           image: "6053537/portainer-ce:latest"
           network_mode: "bridge"
           ports:
             - "9000:9000/tcp"
             - "8000:8000"
           restart: "always"
           volumes:
             - "/var/run/docker.sock:/var/run/docker.sock"
             - "portainer:/data"
         zigbee2mqtt:
           container_name: "zigbee2mqtt"
           environment:
           image: "docker.io/koenkk/zigbee2mqtt:latest-dev"
           restart: "always"
           volumes:
             - "/var/lib/docker/volumes/zigbee2mqtt/data:/app/data"
       version: "3.6"
       volumes:
         ddns_go:
           external: true
         portainer:
           external: true
         esphome:
           external: true
         homeassistant:
           external: true
         nodered:
           external: true
  • mpd需要提前创建文件和文件夹
    cd /var/lib/docker/volumes/mpd
      mkdir music playlists
      touch database mpd.log mpd.pid state sticker.sql
      vim mpd.conf
       mpd.conf内容
music_directory    "/var/lib/mpd/music"
  playlist_directory "/var/lib/mpd/playlists"
  db_file            "/var/lib/mpd/database"
  log_file           "/var/lib/mpd/mpd.log"
  pid_file           "/var/lib/mpd/mpd.pid"
  state_file         "/var/lib/mpd/state"
  sticker_file       "/var/lib/mpd/sticker.sql"
  audio_output {
      type                       "alsa"
      name                     "My ALSA Device"
      device                    "hw:1,0"
      mixer_type             "software"
这里使用的device是usb声卡,hw后面两个数字分别是card,device,使用`aplay -l`查看声卡,按需修改
4. 启动docker-compose:在创建docker-compose.yml文件的目录
docker-compose up
5. 全部变成running后`ctrl + c`退出,容器会全部停止
6. 修改zigbee2mqtt配置文件configuration.yaml
homeassistant: true
   permit_join: false
   mqtt:
     base_topic: zigbee2mqtt
     server: mqtt://192.168.xx.xx        //mqtt服务器地址
     user: mqtt                                   //mqtt服务器用户名。密码
     password: 'xxxxxxx'
   serial:
     port: tcp://192.168.xxx.xx:1024     //我的是用的无线,有线自行修改
7. 完成后执行`docker-compose start`启动,到这一步容器基本上都能运行了,只差配置文件了,自行解决~
有些系统默认不会开放端口,比如centos,手动开启一下
firewall-cmd --zone=public --add-port=8123/tcp --permanent
firewall-cmd --zone=public --add-port=1880/tcp --permanent
firewall-cmd --zone=public --add-port=6052/tcp --permanent
firewall-cmd --zone=public --add-port=9000/tcp --permanent
firewall-cmd --zone=public --add-port=9876/tcp --permanent
firewall-cmd --reload
参与人数 3金钱 +40 收起 理由
隔壁的王叔叔 + 10 感谢楼主分享!
flyice + 10 感谢楼主分享!
dscao + 20 感谢楼主分享!
Ari 手机认证
发表于 2023-10-25 11:18:40 | 显示全部楼层
很不错的,就是映射的这个目录看起来好复杂,
发表于 2023-10-26 17:10:02 | 显示全部楼层
非常不错,不过我已经搭好了。。。抛弃core
 楼主| 发表于 2023-10-27 13:20:26 | 显示全部楼层
只有mpd这种有子目录要映射的才需要写绝对路径复杂些,直接映射数据卷的话还是很方便的
GMT+8, 2025-11-30 16:36 , Processed in 1.227348 second(s), 14 queries , MemCached On.
