查看: 8476|回复: 3
[技术探讨] 求助大神!为啥我添加的传感器左手机上不显示
发表于 2018-1-2 18:41:22 | 显示全部楼层 |阅读模式
按照群友的教程一步一步的做的为什么我就遇上难题了???mqtt:
  broker: 192.168.31.170
  port: 1883
  client_id: home-assistant-1
  keepalive: 60
  username: pi
  password: raspberry
  discovery: true
light:
  - platform: mqtt
    state_topic: "stat/S1/POWER"
    command_topic: "cmnd/S1/POWER"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: true
light 2:
  - platform: mqtt
    state_topic: "stat/S2/POWER"
    command_topic: "cmnd/S2/POWER"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: true
light 3:
  - platform: mqtt
    state_topic: "stat/S3/POWER1"
    command_topic: "cmnd/S3/POWER1"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: true
sensor 1:
  - platform: mqtt
    state_topic: "tele/PIR/SENSOR"
    unit_of_measurement: "°C"
    value_template: "{{ value_json['DHT11'].Temperature }}"
  - platform: mqtt
    unit_of_measurement: "%"
    value_template: "{{ value_json['DHT11'].Humidity }}"
binary_sensor:
  - platform: mqtt
    qos: 1
    state_topic: "/cmnd/PIR/POWER"
    payload_on: "ON"
    payload_off: "OFF"
    device_class: motion
binary_sensor 2:
  - platform: mqtt
    state_topic: "stat/S5/POWER"
    command_topic: "cmnd/S5/POWER"
    qos: 1
    payload_on: "1"
    payload_off: "0"
    device_class: opening
网页正常
网页正常
Sonoff正常
Sonoff正常
就是手机上没有
就是手机上没有
发表于 2018-1-2 21:41:23 | 显示全部楼层
还要在customize.yaml中定义
binary_sensor:
  homebridge_hidden: false
 楼主| 发表于 2018-1-2 23:22:08 | 显示全部楼层
已有大师解决好了homebridge 里没有添加传感器
 楼主| 发表于 2018-1-2 23:24:42 | 显示全部楼层
binary_sensor:
谢谢你的回答!已经解决好!
GMT+8, 2025-9-5 13:13 , Processed in 1.108946 second(s), 15 queries , MemCached On.
