查看: 8653|回复: 2
[求助] hass.io 安装homebridge插件,一启动就停止 以及ios客户端空白
发表于 2018-1-2 14:41:24 | 显示全部楼层 |阅读模式
Ubuntu16.04  vm虚拟机环境,从这个地址:https://github.com/olivierguerriat/hassio-addons
安装homebridge插件,失败
Logs:
starting version 3.2.2
This add-on is deprecated and doesn't work anymore.
Please uninstall this one and use Franck Nijhof's add-on instead:
https://github.com/hassio-addons/repository/tree/master/homebridge
Your existing configuration should be used transparently.
config.json配置如下:
    "bridge": {
        "name": "Homebridge",
        "username": "CC:22:3D:E3:CE:30",
        "port": 51826,
        "pin": "123-45-678"
    "platforms": [
    "platform": "HomeAssistant",
    "name": "HomeAssistant",
    "host": "http://192.168.0.157:8123",
    "password": "",
    "supported_types": ["fan", "garage_door", "input_boolean", "light", "lock", "media_player", "rollershutter", "scene", "switch"]
    "logging": ture
        "platform": "config",
        "port": 8766,
        "log": "/var/log/homebridge.stdout.log",
        "error_log": "/var/log/daemon.log",
        "restart": "sudo systemctl restart homebridge.service"
 楼主| 发表于 2018-1-2 14:44:04 | 显示全部楼层
补充下,前几天重装虚拟机之前,安装homebrigge插件正常,手机也也能搜索到网桥。
发表于 2018-2-26 09:40:08 | 显示全部楼层
我碰到刚解决~ "host": "http://192.168.0.157:8123", 这里要改成http://172.17.0.1:8123
GMT+8, 2025-12-25 07:54 , Processed in 0.399993 second(s), 16 queries , MemCached On.
