查看: 2810|回复: 0
[求助] 请教大佬! esphome sht3xd 连接巴法云问题
发表于 2023-10-11 18:39:25 | 显示全部楼层 |阅读模式
大佬们,我家里用HA和esphome连接nodemcu+sht3x模块可以正常使用由于单位没有ha,端口映射连接上也获取不到设备
想实现单位的nodemcu+sht3x和能连接家里的ha
问题1 目前用esphome连接巴法云,开关可以使用。这个sht3x不能设置state_topic参数,巴法云无法获取温湿度参数。
问题2 ha通过插件可以同步给巴法云,不能巴法云连接ha,按巴法云的配置方法mqtt提示错误
请大佬帮助!
esphome:
  friendly_name: nodemcu
esp8266:
  board: nodemcuv2
logger:
api:
ota:
wifi:
  ssid: 22
  password: 114441411
  ap:
captive_portal:
i2c:
  sda: 4
  scl: 5
  scan: true
  - platform: sht3xd
    temperature:
      name: "Living Room Temperature"
    humidity:
      name: "Living Room Humidity"
    address: 0x44
    update_interval: 5s
    state_topic: "sht004" 这里出现问题
    command_topic: "sht004"这里出现问题
mqtt:
  broker: bemfa.com
  port: 9501
  client_id: 06b453f1d1a34bfab31587dccb3ad20c
  topic_prefix: /esp1
  on_message:
    - topic: /esp1/test
      then:  # int value = atoi(x.c_str());
         lambda: |-
            if (x.c_str() == "on"){
                  id(wind).turn_on();
                }else{
                  id(wind).turn_off();
            ESP_LOGD("main", "The current version is %s", x.c_str());
switch:
  - platform: gpio
    pin: D5
    inverted: True
    state_topic: "wind006"
    command_topic: "wind006"
  - platform: gpio
    pin: D6
    inverted: True
    state_topic: "air006"
    command_topic: "air006"
GMT+8, 2025-12-18 15:08 , Processed in 1.012819 second(s), 11 queries , MemCached On.
