查看: 2766|回复: 1
[求助] 官网温控器下这两个参数是什么意思?
发表于 2023-10-10 13:53:04 | 显示全部楼层 |阅读模式
min_cycle_duration time | integer (optional)
Set a minimum amount of time that the switch specified in the heater option must be in its current state prior to being switched either off or on. This option will be ignored if the keep_alive option is set.
keep_alive time | integer (optional)
Set a keep-alive interval. If set, the switch specified in the heater option will be triggered every time the interval elapses. Use with heaters and A/C units that shut off if they don’t receive a signal from their remote for a while. Use also with switches that might lose state. The keep-alive call is done with the current valid climate integration state (either on or off). When keep_alive is set the min_cycle_duration option will be ignored.
想请教一下大家,官网温控器的这两个参数是什么意思呀?
yybl 手机认证
发表于 2023-10-11 16:23:09 来自手机 | 显示全部楼层
个人理解
keep_alive  触发开后持续时间,在该时间内如果没再次收到开的信号将关机
min_cycle_duration  开关间隔时间,此时间内不能变更开关状态
GMT+8, 2025-12-18 15:04 , Processed in 0.124893 second(s), 7 queries , MemCached On.
